Losing MPG?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by harleyamyc, Feb 11, 2012.
  1. harleyamyc
    harleyamyc New Member
    florida
    Just purchased a 2010 Prius with 17's (after market) rims. Wondering now if the change in rim size/style will cause my MPGs to go way down. Anyone know if this will make a big difference?
  2. ockevin
    ockevin Active Member
    493
    148
    Orange County
    Very small difference...around 1-2 mpg
  3. harleyamyc
    florida
    thanks for the reply :) Traded in my 09 Maxima...which about killed me (but the 20mpg was killing me worse) Just didn't want it do be an extreme drop.
  4. NineScorpions
    NineScorpions Economy, Meet Style!!
    375
    64
  5. qbee42
    3,076
    Yes, as pointed out above. Another big factor is the tire attached to the rims. It's easy to drop four or five mpg with the typical tires attached to 17s.
  6. ockevin
    493
    148
    Orange County
    True...I have the LRR Michellin tires on my 17's
  7. F8L
    19,011
    4,083
    Grass Valley, CA.
    So do I. :)
  8. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    That's really only true with the factory 17". Wider and less aerodynamic rims will cause further drop.
  9. F8L
    19,011
    4,083
    Grass Valley, CA.
    I am inclinded to agree but I'm not confident enough to make such a statement. I'd love borrow a set of OEM 17s to see if they increase my mpg vs. my lightweight (15-16lbs) Centerline RPMs. I find it hard to believe that the possible better aerodynamics of a 24lbs wheel would improve mpg over a 15lb wheel. I'm willing to test the idea though. :) For the record my wheels are the same width as OEM 17s and I run the same width tire.
  10. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    Remember you have a Gen II and we're talking about the Gen III. You've reported that the Gen II seems to do worse with larger wheels in terms of mpg hit. You can do the test once you get your BP with solar ;)
    I do think aerodynamics is a factor, especially at highway speed, but it's less of a factor than weight.
  11. F8L
    19,011
    4,083
    Grass Valley, CA.
    I know. I'm hoping to eat crow with regard to the loss on the GenIII. If so the the 17s will go on the GenIII. :)
  12. qbee42
    3,076
    The loss contribution from weight increases with stop and go, and bumpy roads.
    The contribution from rolling resistance is fairly uniform.
    The contribution from aerodynamic drag goes up exponentially with speed.
    If you look at those three factors, it's easy to see why there isn't one answer of which is worse: weight or aerodynamics. It all depends on the driving conditions.
  13. wilgilb
    wilgilb New Member
    Weeki Wachee, Fl
    Prius uses low rolling resistance tires.
    Also, if the outside diameter of the new tires is larger than the outside diameter of the originals.
    The size of the metal wheel is not important, but wider tires add rolling resistance.
  14. bisco
    51,023
    well said, and higher pressure will decrease the 'footprint'. o/p may also want to switch to 15" wheels.
