2010 Prius 2ZR-FXE engine efficiency map
Discussion in 'Gen 3 Prius Technical Discussion' started by ken1784, Jun 1, 2009.
  1. walter Lee
    1,126
    376
    Maryland
    At 4000 RPM a Prius must be moving along
    the highway like a crazed demon from hell.:eek:
  2. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    this is europe.
    my 88hp nissan moved at 100mph with no problems for 600 miles the other day :)
    offib likes this.
  3. FrankTiger
    FrankTiger Member
    63
    118
    Madrid, Spain
    Hi Tom
    Actually it does make a lot of sense. I'm capturing OBDII data and this is the plot you asked for. It seems that there is a different path (in light-blue) for revving when the coolant temperature is below 70ºC (158ºF)
    Big hugs from Frank
    [Click here for zoom]
    CR94, swapper, Tideland Prius and 5 others like this.
  4. Currawong
    Currawong Junior Member
    Fukuoka, Japan
    That's what got me interested in the car in the first place: I saw a 2010 model accelerating at a speed I didn't think a hybrid could do. I wouldn't call my 2011 a highway demon, but I have caught myself going at speeds way above what I intended without realising.
    I found I can enact some fun by putting the car both in power and the gear selector in B (to keep the ICE running) then it's possible make very quick progress when there is little traffic in the way. I wish I'd owned this car back in Australia.
  5. Rbimd
    Rbimd Junior Member
    Indiana
  6. Rbimd
    Rbimd Junior Member
    Indiana
    Ken,
    Is there any chance you could re-publish your 2ZR-FXE engine efficiency chart?
    When PriusChat moved to its new format, the links to many old charts were lost!
  7. SageBrush
    SageBrush Senior Member
    11,627
    2,532
    Southwest Colorado
    Rbimd likes this.
  8. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    Is there anyone with a OBD reader that can provide an estimate of power loss when in high speed no-load (just about 1000rpm) of the engine?
    For 2 Gen Prius I have a friend that gave me 1kw as rough value (diff between 68km/h and 70km/h energy flow to batt)...
    Thank you in advance
  9. SageBrush
    11,627
    2,532
    Southwest Colorado
    Hobbit has said 2 kw to turn the ICE, unrelated to fuel combustion.
    Incidentally, it is this factor that provides most of the benefit of P&G: ~ 2/3rds of the time the driver is saving 2 kw.
    It is also why hybrids that can glide at high(er) speeds have quite an advantage in a hypermiler's hands if the route lets them stay below the spinning_ICE threshold.
    telmo744 likes this.
  10. 70AARCUDA
    70AARCUDA Active Member
    845
    209
    Tucson, AZ
    ...would that be 41 mph? The cross-over point where the ICE engine begins spinning the sun gear?
  11. SageBrush
    11,627
    2,532
    Southwest Colorado
    It varies by Prius generation, and whether the threshold is reached from a lower or higher value.
    For your car, ~ 45 from below, ~ 43 from above.
  12. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,000
    Fort Lee, NJ
    Although true when comparing between Gen2 and Gen3 because they have the same power split ratio, it is not true with Ford Hybrids that can go up to 85 mph with ICE off.
    The compromise to allow 85 mph ICE off operation is to increase torque split to MG1. This in effect reduces torque split to the wheels (direct mechanical drive).
    Prius ICE splits 72% of the torque to the wheels while 28% splits to MG1 (generator). Ford hybrids split less to wheels and more to generator.
    That adds conversion loss because more power end up inn MG2 (traction motor) rather than ICE turning the wheels directly.
    Although 85 mph glide has advantage, inefficiency introduced in the acceleration should negate it. Plus, you'll lose speed fast due to high wind resistance at those speed.
  13. SageBrush
    11,627
    2,532
    Southwest Colorado
    I pretty much agree with all your points. I was thinking of 50 mph Vs 40, or hilly routes.
  14. 70AARCUDA
    845
    209
    Tucson, AZ
    Q: I found the Mg1/ICE/MG2 equations & ratio-constants (applicable to Gen I & II PSD), but what are they NOW with the changed Gen III ratios & splits?
  15. PriusWise
    PriusWise New Member
    Milwaukee, Wisconsin
    That is 22 mph and 28 mph.
    Dan, 3rd gen from the sun
