gen 2 vs. gen 3 mpg
Discussion in 'Gen 3 Prius Fuel Economy' started by suprat04r, Feb 15, 2012.
  1. suprat04r
    suprat04r Junior Member
    85
    las vegas
    i just recently bought a 2007 gen 2 prius. it is so far averaging me about 50 mpg.. very impressed and satisfied of course!
    i was wondering if the gen 3 mpg was similar, better, or worse?
    thx :)
  2. F8L
    19,011
    4,083
    Grass Valley, CA.
    3rd gen is generally better, especially at highway speeds. The 3rd gen also reports higher mpg than calculated by approx. 4%-6% high whereas the 2nd gen is only about 2% high. This over-reporting makes the mpg difference between generations look even higher.
  3. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    While there are driving styles and situations where they get the same mileage, in general, Gen 3 is about 5 MPG better.
  4. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    Gen 3 is better for most drivers, particularly in warm-up and on the highway.
    However, the Gen 2's smaller engine actually allows it to have greater potential efficiency and the different programming of the car made the Gen 2 easier for hypermilers wanting to push the car to the limit.
    Hence part of the excitement about the Prius c*. The 1.5L engine based on the Gen 2 plus lower weight increases the potential efficiency. Wayne Gerdes, hypermiler extraordinaire, managed to get 85mpg on a highway trip, something that the neither the Gen 2 nor Gen 3 Prius could possibly match.
    * Any excuse.
  5. djlen
    djlen Junior Member
    68
    Somerdale, NJ
    Yes, I'm driving a Gen. 3 and my dash calc. vs. the Fuelly calculation is almost always 3 mpg higher.
  6. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    We have over 66,000 miles on our Prius. The mpg gauge is over reporting 3-4 mpg 99.99% of the time.
    Only a couple of times was it right on or slightly under reporting and than the next fill up it would be off 4-5 mpg, so it was the pump stopping too soon etc.
    Someday somebody will find a way to fix this by a simple software
    download or something.
  7. SuperchargedMR2
    SuperchargedMR2 Diehard Rams Fan
    673
    179
    Vancouver, WA
    Get a ScanGaugeII if you want an exact MPG readout. :D
  8. George W
    George W Senior Member
    911
    514
    San Antonio
    I do not use Fuelly (Gen 2) but when I compare the dash indicator versus odometer calculation, the pen and paper is usually 1 mpg higher than the dash.
