Plastikote My Rims..I Must Be Out Of MY MIND
Discussion in 'Gen 3 Prius Accessories and Modifications' started by priusrick, Dec 1, 2011.
  1. priusrick
    priusrick Member
    257
    40
    I'm doing it. Semi-Gloss Black on my little ole oem 15's. It might look stupid and if so I will maybe just buy some 16's when the tires die anyway. Thoughts!!!!?!??!?!?:mod:
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I wonder if you will have balance issues. Perhaps you will need to re-balance your rims...
  3. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    It will make them look smaller than they do now.
  4. priusrick
    priusrick Member
    257
    40
    Just want them black, I have black on black on the bimmer, want black on black with the prius, no one's rockin' them black on black here in Dallas, none that I have seen, $30 bucks and if they look like S I will just take em back to normal. or cap them.
  5. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    What's the durability of plastikote? I'd be thinking of a different process
  6. priusrick
    priusrick Member
    257
    40
    The product I purchased is specifically for car wheels and is supposedly scratch resistant and weather proof. Excited to find out, I'll post pics of process and final product on and off car, I might try just the spokes fronts and see how it looks. Then if it sucks I'll do whole visible part of rim, I am interested in seeing if there is a layover to make it glossier. We'll see how it goes.
  7. paui
    paui Junior Member
    36
    Bay Area, CA
    i'm also thinking of doing this. please update us what it looks like!
  8. priusrick
    priusrick Member
    257
    40
    Might be happening this weekend. I'll take pictures and update when it happens. I'm working on my bimmer also.
  9. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    Not a big fan of black wheels on a black car, but good luck with the process.
  10. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    What is the UV resistance of this paint? You might be better of going the Powder Coat route. A little more money, but the durability is going to be better that a spray cans worth of Plasticoat. They do make a version that is highly UV resistant, which means the color will stay true longer! It will eventually fade out!
  11. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    A lot more money. If you don't like it, the plasticoat pretty much peels right off
  12. ursle
    ursle Gas miser
    1,049
    192
    NH
    I think I'd just go directly to the black spinners and save the embarrassment of having the plasti peel.
    .Car To Wheel Search
  13. priusrick
    priusrick Member
    257
    40
    Here are my two options, could do another option if someone comes up with something for black. Maybe whole wheeL?
  14. TruSound
    TruSound Member
    246
    32
    The 818
    You might want to consider switching from Plastikote to powdercoat, although it'll cost you a bit more, it'll look way way better, definetily be more durable and no balance issues as mentioned earlier.
  15. priusrick
    priusrick Member
    257
    40
    I am probably going to racing 17's with LRR when I need to replace tires. (y) So Plasticote I WILL!
  16. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    First option makes wheels look larger than stock. Second option is a bit weird.
    Another option-plastikote the whole thing black and put the 2012 alloy covers on.
  17. priusrick
    priusrick Member
    257
    40
    I ended up plasticoating the whole wheel black except for center caps, lugs and air stem caps. uploadfromtaptalk1371566689995.jpg uploadfromtaptalk1371566741241.jpg [​IMG]
    LG-MS870 ? 2
  18. RaZa
    RaZa Member
    480
    93
    To be perfectly honest, I don't like the look of a black rim. To me it just looks like it's missing a hubcap, but that's just my opinion. You did a really good job on the coating. Looks like it covered well. Just keep your eyes on it for a while to make sure it holds up and doesn't peel. Well done.
