2012 Prius Three rim size
Discussion in 'Gen 3 Prius Accessories and Modifications' started by shrktank, Feb 26, 2012.
  1. shrktank
    shrktank New Member
    56
    Imperial,Mo
    Hello
    I am thinking of getting some nice rims for my 2012 Prius.
    I have no idea of what size I should get. I went to tirerack.com and they list 15, 16 and 17 as available for the Prius.
    I know they are not 17's, but not sure if 15 or 16. Also what else do I need to know to order the proper ones
    Thanks
  2. F8L
    19,011
    4,082
    Grass Valley, CA.
    15s standard and 17" optional on the model Five. 5x100 bolt pattern with a 45mm offset on the 15s and 50mm on the 17s.
  3. SuperchargedMR2
    SuperchargedMR2 Diehard Rams Fan
    673
    179
    Vancouver, WA
    These are the OEM offsets but you can be more aggressive with aftermarket wheels so that the wheels are not sucked in so much. On a 7" wide wheel I think that a +40mm offset will be perfect & on a 7.5" wide wheel a +45mm offset will work great. ;)
  4. F8L
    19,011
    4,082
    Grass Valley, CA.
    On the GenIII you may be able to get away with a 40mm offset on a larger wheel but on a GenII with a lowering kit it is cutting it very close. My 17s have a 42mm offset and they sometimes rub on the outer part of the fender liner. With a stock height vehicle this wouldn't be a problem but on a dropped car it could be. :)
  5. SuperchargedMR2
    673
    179
    Vancouver, WA
    I'm going by what fits on my GenIII & the OP has a GenIII so all should be good. :cool:
  6. NineScorpions
    NineScorpions Economy, Meet Style!!
    375
    64
    what he said exactly.
  7. justana
    justana Junior Member
    60
    I just installed 18x8 ET38 BBS CH-R,and look perfect...
  8. SuperchargedMR2
    673
    179
    Vancouver, WA
    How are those not rubbing? My 16x7 +35mm offset seems to stick out a little too far on the front & I rub a little on really large bumps, that's why I'm looking at 17x7 +40mm wheels.
  9. F8L
    19,011
    4,082
    Grass Valley, CA.
    He's probably not lowered. They should in theory rub like hell. :)
  10. SuperchargedMR2
    673
    179
    Vancouver, WA
    But if you don't lower the car a little, even just the inch from Eibach springs, bigger wheels & lower profile tires just look a little goofy IMO.
  11. NineScorpions
    375
    64
    pictures por favor. I can imagine perfect...but I need to see it :D
  12. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    227
    Harrisburg, PA
    Not trying to thread jack, but what does anyone think about the fitment of Kosei K4R 17x7 5x100 50mm offset? They are only 14 lbs! They don't come up on Tire Rack unless you choose something like 97 Subaru Legacy sedan, then of course the recommended tire size is wrong.
  13. justana
    60
    Pls see attachment.... I hope you like it. I just wanna make it simple and look clean...:)
  14. justana
    60
    Its not really that bad. Its rubbing slightly when i got large bumps on over 50 mph. btw, i lowered with B&G lowering kit. 1.1" @front, 1.3" @back.... All wheels and tires look straight for me. It doesn't stick out at all. I actually wanna add spacer 5-10mm @back to look 100% perfectly straight...
  15. justana
    60
    lol
  16. ghosteh
    ghosteh Member
    146
    57
    Illinois
    I see a lot of 15" Corolla rims on ebay that are supposed to fit, but they don't seem to mention 2012 models. Is there any difference between the size, offset, etc. on the 2012 from earlier years?
    I'm in the same boat as the OP. I'd like new rims & want to stay with stock size & reuse my original tires.
    More pictures would also be appreciated.
  17. NineScorpions
    375
    64
    Looks great!
  18. SuperchargedMR2
    673
    179
    Vancouver, WA
    What size wheels & offset are the wheels? They look huge in the pics. :lol:
  19. justana
    60
    It's just 2012 BBS CH-R 18x8 ET38. Tires are 225/40/18ZR... It might look huge on couple pictures because i used fisheye lens on my camera...;)
  20. WildmanTheArtist
    WildmanTheArtist Junior Member
    Gettysburg, Pa
    Any issues with running 18x8s I have a line on factory nightshade wheels on a stock suspension Prius what size tires are you running? New to the Prius mods have an 18 Avalon but want to do some mods to my company ride a 2012 Prius
