Can Smart Keys be Reprogramed?
Discussion in 'Gen 3 Prius Technical Discussion' started by JohnCleary, Mar 9, 2012.
  1. JohnCleary
    JohnCleary Junior Member
    SoCal
    I purchased a smart key on ebay and took it to a dealership today, well $55 later and they could not program it. Said "possible already programmed". Is this true or can a smart key from one car be programmed to another car?
    John
  2. Royal5280
    Royal5280 New Member
    49
    Dallas
    Good Question. I would have thought there is a way to wipe it clean and reporgram. Can you wife it clean yourself? I just ordered one, and had it programed. $250 later.....
    (It does include the AC option, hopefully that was programmed correctly).
  3. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    They can be reprogrammed, but you will need to find someone with thevrightvequipment and know how.
  4. h00ktern
    h00ktern Member
    135
    40
    Absolutely correct. I know because I have a 2011, the means to do it, and successfully did it. If you were nearby, I would do it for you. :juggle:
    Your dealer failed because they did not "Reset" the SKS module in Techstream (which requires a new seed value to be entered.) If you can convince them to try, they will succeed also.
    I am beating a dead horse, but because of what you just experienced, and what others have gone through, I have concluded that Toyota is not in control, and dealers are just making easy money off of the owners who have no other (apparent) options. I look to the $55 charge they stuck you with as nearly theft. You paid, they failed, and you got nothing for your money. It's a shame, really.
    Edit: I need to qualify something - if you didn't have the correct remote model, then I can't rightly say they ripped you off - however, in that case, they should have known it was the wrong model remote. Look on the back and see if it has the following - "FCC ID: HYQ14ACX", "IC: 1551A-14ACX", "RLVDE1408-0265" and "DENSO 14ACX". If it does, and it is not broken, then I stick to my guns.
    JimY4 likes this.
  5. Royal5280
    49
    Dallas
    Thanks for the research Hook. Would you be able to wipe it for him so he can take it back in and they can do what they already charged him for?
  6. qbee42
    3,081
    No. You don't "wipe it clean" - the car is programmed to the fob, not the other way around. After you do a seed reset on the ECU, you have a very limited amount of time to add fobs. This is done for security reasons.
  7. h00ktern
    h00ktern Member
    135
    40
    Tom's correct. I wish I could; it would be a whole lot less stressful for the owners. The best I can offer right now is to assist those who are near enough by me to use my stuff.
    I've been considering another option to address this, but need to check out a few things before I even mention it.
  8. JohnCleary
    SoCal
    ***UPDATE***
    First of all thanks for your responses.
    The answer is YES, previously programmed Smart Keys can be reprogrammed. I took my prius to Pop-A-Lock in Riverside (951)992-1096, Art was able to reset the car to accept the used fob. Art told me he had a lot of success with GenIII fob's
  9. Mike500
    Mike500 Senior Member
    2,593
    767
    Sounds much like programming a Genie garage door owner. The opener is programmed to accept the remotes. There is a short time frame for this to be done, once the program button is pushed.
  10. h00ktern
    h00ktern Member
    135
    40
    Yes, it is, once you're able to 'push the button'. Toyota made that a real PITA, and a somewhat expensive proposition. But it can be done, thankfully.
  11. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    I bought new fobs for my Honda, and it was an easy do-it-yourself deal to get the car to accept them.
  12. mad-dog-one
    1,181
    421
    Whereabouts Unknown
    I don't know where you are in SoCal, but Pop-a-lock in Riverside programmed both of my Gen 3 Prii to accept previously use smartkeys.
  13. cglz4au
    cglz4au New Member
    Alabama
    Don't mean to resurrect an older thread but I can also confirm that used Ebay keys can easily be programmed to your vehicle with the right equipment and the right locksmith. I just had it done earlier today in Atlanta. The locksmith came highly recommended by several others in the area. It took him less than 30 min to reset the SKS module, sync both of my keys and laser cut my spare. If any of you would like his info, please feel free to PM me. The guy really knows his stuff. His prices are also very reasonable. He even replaced my SK's battery for free :).
    faridsk and mbkga like this.
  14. mbkga
    mbkga New Member
    I'd like that information
  15. colbertfan1
    colbertfan1 Junior Member
    37
    I had an old key fob from my wrecked Prius. They cut a new key and synced it to my new Prius for $55.
  16. mbkga
    mbkga New Member
    In Atlanta - ToyoTechs (770) 457-9991
    Successfully reprogrammed a Camry smart key I purchased on Ebay for $40.
  17. faridsk
    faridsk New Member
    Can U please give me the name and number?
  18. Dravor
    Dravor Junior Member
    66
    Ashburn, Virginia
    If the battery dies on the FOB does it need to be reprogrammed?
    Thanks!
  19. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    No, it does not need to be reprogrammed.
    SCH-I535
  20. ovni
    ovni Member
    243
    91
    Sugar Land, TX
    Used keys can be programmed. I use the same equipment the dealer uses and program used keys almost on a daily basis. The dealer tells people it doesn't work to make the customer buy a NEW key from them. More money!!
    alejandrolevin likes this.
