Dealer Vs. Non Dealer for Bearings
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by trip, Oct 27, 2011.
  1. trip
    trip Junior Member
    25
    Illinois
    So I'm 95% sure that I need new bearings on at least one of my front wheels on my 2008 Prius. My question(s) is:
    is this a standard repair job that doesn't vary too much from Prius to Non-Prius vehicles?
    Money is an issue as I'm sure it is for many here, so for a repair like this would you choose to take it to the dealer or to a non-dealer mechanic?
    Thanks,
    If anyone has an idea of what this might cost feel free to let me know.
    Also, wanted to ask if there anyone from Chicago-land do they have a recommendation for a good mechanic in the Western suburbs?
  2. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    Only a couple companies make bearings? SKF for one and maybe China has a factory now. I would stay away from the later. That is probably why yours have gone!Hal
  3. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    If you don't get a Toyota bearing, bet a good brand name bearing, not the cheapest bearing you can find.
    There are a few common but different ways wheel bearings are done. The Prius is not unusual.
  4. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    Tom, are you sure it is not a tire? I am guilty in changing bearings in the past only to find out it was a beat up tire. Rotate tires and see if noise moved.
    with respect to bearings and dealer vs independent, bearings are cheap for most part, <$10 (not sure for Prius). Price it out from different sources good luck
    PS try online rockauto or autoparts
  5. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,515
    Santa Fe, NM
    They should disconnect the 12V battery before starting repairs, so as to not accidentally eject the piston from the caliper, or cause a code if they have to compress the piston to get the caliper back on the rotor.
  6. trip
    trip Junior Member
    25
    Illinois
    That's a good point cyclopathic. The left front tire seems to need air the last couple of months. I attributed that to it getting cold here.
    Thanks so much for the info everyone.
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,829
    Clearwater, Florida
    The bearing assy is sold as a complete hub. The dealer will replace it free under a 3/36K warranty. If OOW the hub costs $200 last time I looked.
    I lost the driver side on my 07 at 35,000 mile and was replaced under warranty.
    It made a peculiar wup wup sound from 15 to 50 mph's.
    The telltale sign is it will change sound momentarily if you gently swerve back & forth putting load on the front end suspension.Easy to tell then which side is unhappy. At the time I had stock GY Integrities on the car so they were suspect. Bad name for one of the worlds worst tire.I swapped tires to no effect.
  8. dhancock
    dhancock 2 Prius Family
    357
    40
    Hamburg, NY (Buffalo area)
    Both of my front bearings are noisy. I got three quotes (none from dealer) which ranged from $436 to $838. The lowest & highest were with after-market parts. Quote for $487 includes Toyota bearings. I'm going with that one.
  9. Soldmytruck
    Soldmytruck Junior Member
    Portland, OR
    SKF has plants all over the world including China. Typically though you should stay away from any Chinese mfr'd bearing unless it's branded by a well known mfr.. In general large mfr's like SKF will require the plant to meet certain quality standards, so you should have some confidence when purchasing a namebrand like SKF regardless of the country of origin.
    Although, it sounds like these are part of a complete hub assembly which always sucks for the consumer because it limits your options.
    Other quality brands include Timken, Torrington, NTN, KOYO. There are others, but these are some of the more reputable mfr's. It's a pretty safe bet if the country of origin is Japan or Germany as both countries are known for producing high quality bearings.
  10. ZitterZap
    ZitterZap Member
    76
    28
    Houston, TX
    I have been expecting a bearing repair anytime on my car since the original owner of my car said that he never replaced the bearings.
    So 241,000 miles and this car still has the original bearings???
    Is that even possible?
  11. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    In a word, "yes".
    - Chris
  12. Soldmytruck
    Portland, OR
    Absolutely.
    With the technological advancements is bearing steel, precision mfg processes, and pre-shipment testing (some mfr's noise test every bearing the make) the quality of bearings is quite remarkable.
    Another equally important and often overlooked factor is the advancement of lubrication (grease) technology. Some of the greases produced these days have much better longevity than they did just 10-15 years ago. So when properly applied and sealed from contaminants the grease and therefore the bearings have an exponentially longer operational life.
  13. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    Anecdotally, I currently own four cars. All have spent their "lifetimes" in this rustbelt area that we call home. My cars range in age from 10 years to 15 and in miles from 102,000 to 170,000. All on their original bearings.
