Fuel Economy
Discussion in 'Gen 3 Prius Fuel Economy' started by ArkiePrius, Mar 14, 2012.
  1. ArkiePrius
    ArkiePrius Junior Member
    68
    Arkansas
    I have a question for all you longer term Prius owners . From what I read on PriusChat changing modes from Eco to Power to Normal only changes the mapping of the "gas pedal". If this is so , my question is does it really matter what mode you are in if you are using cruise control on a long trip, would all the modes get the same mileage?
    Arkie
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Eco mode 'relaxes' the thermostat on the A/C, so it can vary more. This might help MPG most of the year in AR.
  3. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    If you don't use the A/C, you should get the same MPG's from all 3 modes. ECO will improve mileage if you do use the A/C. It also helps with "feathering" the pedal for pulsing and gliding for those times you are in slow and go traffic.
