Hard braking-warning lights come on
Discussion in 'Gen 2 Prius Main Forum' started by ernie1, Mar 16, 2012.
  1. ernie1
    ernie1 Junior Member
    67
    Sacto,Ca.
    Well after some texting bimbo cut me off and I had to slam on the brakes real hard, I get a triangular red light with a ! in the middle and a check engine light come on. Also, the mfd now has a caution light and none of the usual displays. Will these lights reset themselves? How long? What do I need to do?
  2. ernie1
    67
    Sacto,Ca.
    Well all seems okay now that the car has been driven a bit that the engine has gone through a few on-off cycles and all the lights have disappeared.
  3. johnjamis
    johnjamis Junior Member
    79
    KY
    Check to see that your brake fluid level is not low.
  4. uart
    uart Senior Member
    4,220
    1,210
    Australia
    Check you engine oil level and all the other fluid levels while you're at it.
  5. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    +2 check the fluid level.
    Also check for leaks cap/reservoir seals and brake pads. On some cars brake fluid reservoir is small, the lights get triggered when the brakes about to go out
  6. ernie1
    67
    Sacto,Ca.
    Thanks for the feedback guys. I hadn't thought about checking the fluids but that makes sense. I'll go out and check them now.
