What tires came with your PiP?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by iRun26.2, Mar 19, 2012.
  1. iRun26.2
    iRun26.2 Active Member
    824
    169
    United States
    Did the advanced model come with better tires?
  2. kstitt
    kstitt Junior Member
    San Bernardino
    My advanced came with Yokohama AVID S33
  3. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    My base came with these ^^^
    Paradox, didn't your Advanced come with Goodyears?
  4. badboy99
    badboy99 Member
    119
    2003 Prius
    Here are the tires:
    Goodyear Assurance Fuel Max (Passenger All-Season)
    [​IMG][​IMG]6.9Reviewer's
    Avg. Rating:
    Add Road Hazard: $46.28Set of 4: $404.00
    After rebate: $364.00
    Shipping
    Quote
    Add To
    Wish List
    Additional Tire Information
    Product Description | Specs | Surveys | Reviews | Tests | Warranty
    Yokohama AVID S33D (Passenger All-Season)
    [​IMG][​IMG]N/AReviewer's
    Avg. Rating:
    Add Road Hazard: $47.96Set of 4: $428.00
    Shipping
    Quote
  5. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    Mine have the Goodyear's too, but not same as the Assurance Fuel-Max tires I bought last year for the 2010. The tread pattern is not the same and they are only rated for with a 44 PSI maximum, not 51 PSI like the older ones.
    My guess is either Goodyear have improved the tires or they are actually different for the Japanese market.
  6. iRun26.2
    824
    169
    United States
    I did not get the Goodyear's, and I wondered if the advanced got better tires.
  7. crewdog
    crewdog Acting Ensign Prius Prime
    492
    388
    Woodstock, GA
    the Advanced i got came with the Yokohama Avid S33
  8. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Nope, both my dad and me got the Yokohama Avid S33's... I was a bit disappointed seeing them on there, but I don't know, are they in fact good tires? I couldn't find if they are in fact LRR tires. If they are not they should never have been used on a PiP IMO.
  9. F8L
    19,011
    4,083
    Grass Valley, CA.
    The AVID S33D is indeed a LRR tire and many PC members get great gas mileage with them. There have been many complaints about tramlining or quality issues like cupping, however. I decided to ask Yokohama for a trade in credit towards new tires. I ended up getting the new AVID Ascend as a replacement.
    The Goodyear Assurance Fuel Max comes in two flavors for the 195/65/15 size. The OE version sports a lower speed rating (S=112mph vs. H=130mph), lower temperature rating (B vs. A) and lower max pressure (44psi vs. 50psi). While you may never drive 130mph or even 112mph, the H-rated tire would be a better choice as far as tire construction is concerned. It is a stronger tire and less likely to suffer catastrophic failure because of the additional plys or caps and because it will dissipate heat better than the S-rated tire. Keep this in mind come replacement time. :)
  10. john1701a
    12,817
    5,303
    58
    The construction difference seems to make the OE quieter, more like the Goodyear touring tire.
  11. F8L
    19,011
    4,083
    Grass Valley, CA.
    Aye but it could also come at the cost of gas mileage if the reduction in noise is caused by tire deformation. :)
  12. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
    John, Strange that you got the Goodyear tires, while others, including mine have the Yokohama Avid S33 D P195/65R15
  13. H2OSkier
    H2OSkier Member
    276
    Well I got to see my car today and it came Goodyears. It's a base model.
  14. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    Tirerack.com lists the Bridgestone Ecopia EP20 in addition to the Goodyear Assurance Fuel Max and Yokohama AVID S33D. Anyone get those?
    I'm planning on switching out my tires post-haste. The terrible traction and noise of the Goodyear Integrity tires taught me the importance of quality tires last time.
  15. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    I got the Goodyear's on my Base model.
  16. planeflyer
    planeflyer Junior Member
    26
    Canby Oregon
  17. John in LB
    John in LB Life is good
    399
    27
    Orange County
    My Advanced came with the Yokohama AVID S33D.
  18. jverdin
    jverdin New Member
    28
    Alabama
    My Advance came with Goodyear Assurance, it was shipped to the Northeast.
    Well the battle between which one is better begins!
    Yokohama AVID S33D
    Thanks,
  19. pineprius
    pineprius 15th Hole #4
    245
    134
    NC
    With the base at $32K+, you would think it would come with Michelins, but as we all know, the Yokohama AVID S33D is a cheap tire rated at Treadwear 320 and Temp B and Traction B. This is probably the most disapointing aspect of purchasing this car. My Camry Hybrid made in Kentucy came with Michelin MXV 4's. Enough said. Toyota skimped on various PIP parts knowing the buyers would buy anyway.:spy:
  20. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
    Weren't all the PIPs, Base and Advanced, built in the same factory.
    Why the different tires?
    I got Yokohama AVID S33D on my Basic Plug-in.
    Did the tech have a Random Choice of Goodyear or Yokohama?
    Did anyone get 3 tires of one manufacturer and a 4th tire of the other ???
