Wish List for the PIP
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by ukr2, Mar 20, 2012.
  1. ukr2
    ukr2 Senior Member
    1,010
    275
    31
    Victor, NY
    As with the 2007 Prius, I wish when I let off the gas pedal that the PIP would Coast or Glide with No Power or No Regen. I know the slight regen is to make it feel like other cars, but I would rather Glide.
    I wish that if I'm in EV and I step on the Gas pedal enough to start the ICE, if I let off the gas pedal within 10 seconds, that the ICE would NOT go into Warmup mode. If I use the ICE a few times in 5 minutes, then go into ICE Warmup mode after the 3rd time. Accidential use of the ICE should not cause Warmup mode.
    I wish I could press a button and the PIP would dump the HSI and Trip data to a thumb drive. I'm now taking Photos of the displays and adding the data to Excel.
    I wish the Display Audio Car button would allow the viewing of the Tire Pressures.
    I wish the top glove compartment and the center storage both had removable shelves, like the 2007 Prius had.
    I wish 2 or 3 Homelink buttons were standard in the ceiling of the base model PIP.
    I wish the horns were upgraded at the factory.
    I wish I could add a additional battery pack whenever I need a few more EV miles, yet remove it when wanting better ICE mpg.
    I wish a Toyota Engineering Customer Advocate would read this Thread and comment on the suggestions.
    I love my Plug-In Prius, but we can always Dream.
  2. Jozo
    Jozo PIP PIP HOORAY!
    145
    27
    Sacramento
    I am waiting for a sea glass pearl PIP...please tell me that your wish list doesn't include getting a different color...do you like the color? My 2009 is Pine Mist. My dealer says the sea glass pearl is a little bit bluer. Do you know if it is? Thanks for any info.
  3. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    I also wish for more battery capacity.
    Also, I wish they would:
    1) get rid of the flying buttress
    2) put all the controls back into the MFD
    3) make SofTex an option
    4) make beige an available interior color
    5) get rid of the silver strips in front and back
    6) go back to the 2004-2005 soft touch plastics
    7) use the rims from the Liftback which has fewer spokes.
    3 people like this.
  4. greinstein
    greinstein Junior Member
    seal beach, ca
    I have a sea glass pearl PIP. Blue in bright light. Green in overcast. Love it:)
  5. waltf
    waltf New Member
    Ohio
    You mentioned you wished the base model had 2 or 3 homelink buttons on the ceiling. Does the base model have any homelink buttons anywhere?
  6. Zythryn
    Zythryn Senior Member
    6,405
    4,402
    My wish would be for a 'package' that had a greater EV range. Although another model would work as well.
  7. crewdog
    crewdog Acting Ensign Prius Prime
    492
    388
    Woodstock, GA
    I wish my personal range and endurance could match the Plug-in....
    I'd also wish for a convenient place to mount a smartphone
  8. Jozo
    145
    27
    Sacramento
    OMG! YES! I am a person who really dislikes gray! I cannot understand why we couldn't have beige inside!!!
  9. iRun26.2
    iRun26.2 Active Member
    718
    125
    United States
    Nope.
  10. kstitt
    kstitt Junior Member
    San Bernardino
    I got my sea glass pearl PIP last weekend and I couldn't be happier with the color. The color is chameleon. It was raining when I picked it up and the green color was very evident, several shades darker than pine mist. In the bright sunlight the blue comes out. It is very similar to the aqua color of our 2001 Gen I Prius. It's certainly a different color than the pine mist, but we are are very pleased with it.
  11. jbrad4
    jbrad4 Active Member
    474
    148
    Rowlett, TX
    No. But if you want homelink, You can add a homelink mirror later.
  12. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Is the ICE fairly easily invoked in EV mode? Is this happening a lot?
  13. denali
    denali Junior Member
    17
    CA
    I'd like to see a EV/HV button right on the steering wheel. I switch modes frequently enough on my commute where it gets annoying. There's even a blank button spot for it on the steering wheel.
  14. ryogajyc
    985
    165
    Reseda, CA
  15. MrTransAm
    MrTransAm Junior Member
    Tucson, AZ
    Their is no homelink for the base model. I agree this should be a standard feature on every pip since the vast majority of them will probably be parked in garages. What were they thinking? :confused:
  16. Rebound
    Rebound Senior Member
    3,972
    2,626
    Portland, OR
    I wish I needed 2 or 3 Homelink buttons. :)
  17. bilofsky
    bilofsky Privolting Member
    525
    177
    S.F. Bay Area, CA
    2014 Chevy Volt
    I would like to see a user-configurable maximum EV speed (up to the hardwired 62 mph). The EV/HV switch could override this (up to 62).
    That way I wouldn't have to think about switching to HV when entering the 55 mph freeway and back to EV at the off-ramp.
  18. ThatTallGuy
    ThatTallGuy Junior Member
    67
    Southern NH
    Yes please.
    The former would be cool. The latter violates the "level of interest must meet or exceed level of effort" rule. :)
    Cool idea. Even stack them like Legos in the trunk.
    Hear hear!
    I would add:
    I was very disappointed to learn that Lane Keep Assist disappears in the Plug-in. I wonder if there is a technical reason for that, but from here it seems pretty arbitrary.
    I'd also like the solar sunroof although I understand there's a conflict there with the advanced tech package.
  19. bilofsky
    525
    177
    S.F. Bay Area, CA
    2014 Chevy Volt
    I was disappointed too, until I read some on-line reviews and comments, which were mixed enough that I don't feel so bad about it any more.
    Still, I believe it is the only high-tech option omitted from the Advanced package, which seems a bit chintzy given the price. And we could always turn it off.
  20. NewbieOR
    NewbieOR New Member
    Oregon
    I chose Clearwater Blue Metallic and I was wondering if I made the
    right choice. I kept looking at pictures on the 'net and thinking I made
    a mistake.
    ...and then I saw it. Wow. I'm very very happy with it.
    Hopefully you'll have the same experience with the color you chose.
