Cost of ownership
Discussion in 'Prius c Main Forum' started by nudriver, Mar 20, 2012.
  1. nudriver
    nudriver Member
    267
    28
    los angeles
    What about upkeep? Is the car cheap to own? Can most mechanics work on it without specialized knowledge? Are parts cheap like with most Toyotas? Do parts break often? Insurance costs?
  2. justlurkin
    justlurkin Señor Member
    499
    63
    Long Island, NY
    The Prius is one of the cheapest vehicles to own in terms of maintenance costs.
    - Regular cars with automatic transmissions require a brake job every 20,000 miles or so. Prius on average will go past 100,000+ miles before needing a brake job, due to the use of electrical regenerative braking.
    - Regular cars with automatic transmissions usually require a transmission fluid change every 30,000 miles or so. Prius uses a simple planetary gearset as its transmission, with no gear-shifting wear-and-tear. Toyota recommends no Prius transmission fluid change for the life of the car, though here on Priuschat we recommend a drain-and-refill every 60,000 miles or so. Still cheaper than a normal car.
    - Regular cars have timing belts, alternators and starter motors that eventually wear out and require replacement. The Prius has none of those things.
    As far as normal maintenance goes, changing oil and filter on the Prius is done the same way as on normal cars. Engine air filter and cabin air filter you can do yourself without any tools. No specialized knowledge necessary for normal maintenance.
    Prius is mechanically SIMPLER than normal cars (see what I wrote above regarding the transmission and absence of a timing belt, alternator and starter). The complexity is in the control electronics. The mechanical simplicity means less potential failure points, so the Prius is just as, if not more mechanically reliable than normal cars.
    As far as insurance costs go, in my state (New York) hybrids don't cost more to insure than normal cars.
    Bottom line: Total cost of ownership for Prius is awesomely low.
  3. miscrms
    miscrms Plug Envious Member
    2,079
    526
    Phoenix, AZ
    No data yet on the C, but here's how the big Prius stacks up in 5 year TCO on consumer reports. Note that the Prius is an IV, and still does well against much smaller stripped vehicles. Based on that I'd think a C should kick butt in TCO.
    Honda Fit Base: $26,250
    Toyota Corolla Base: $26,250
    Smart ForTwo: $26,750
    Scion xD base: $27,000
    Toyota Yaris: $27,500
    Mazda Versa Hatch: $28,000
    Toyota Prius IV: $28,750
    Mini Cooper Base: $28,750
    Mazda 2: $29,000
    Chevy Aveo: $29,500
    VW Golf TDI: $29,750
    Ford Fiesta: $29,750
    Toyota Matrix Base: $30,000
    Honda Civic LX: $30,000
    VW Jetta TDI: $30,000
    Fiat 500: $30,350
    Mazda 3 sedan: $31,500
    Hyundai Elantra: $31,750
    Toyota Camry LE: $33,250
    Kia Soul: $33,500
    Hyundai Sonata: $33,750
    Chevy Cruze LS: $33,750
    Honda Accord LX: $33,750
    Nissan Sentra SL: $34,250
    Ford Fusion SE: $34,500
    Ford Focus Hatch: $34,750
    Chevy Malibu: $34,750
    Nissan Altima S: $36,000
    Chrysler 200: $42,500
  4. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Why would this list compare a base Fit or base Corolla to a Prius IV ?
  5. pmike
    pmike Member
    237
    81
    Central Florida
    TCO takes the following into consideration: Depreciation, Financing, Insurance, State Fees, Fuel, Maintenance and Repairs.
    If you skim through this blog you can see what things fail on Priuses and at what mileages: http://lusciousgarage.com/blog/cat/repair/
  6. rightwinger
    rightwinger New Member
    here on earth
    thank for the info
