PIP TPMS/no spare tire/fix it can
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by pineprius, Dec 27, 2011.
  1. Mike500
    Mike500 Senior Member
    2,593
    767
  2. dragonfinder1
    dragonfinder1 Junior Member
    79
    oregon
    Walmart has a "Slime Pump kit". Throw away the slime and just use the air compressor. I've done that on a motorcycle tire that had a flat, the slime won't work with a tube, but the compressor doesn't need the "slime" to work. About $20.
  3. Mike500
    2,593
    767
    It wouldn't be too hard to get an old spare tire "J" bolt from the junkyard, rivet or bolt a 'strap" through the top cover, and use a "spare tire" holding "wing nit" to hold the spare behind the rear seat. A small elastic cover like a "shower cap could fit iver the tire.
    The Prius OEM jack, tools and foam holder would fit inside the spare, just like on a regular Prius.
    The wole package weighs a little over 30 pounds and can easily be removed and store, should the extra space be needed.
    Toyota should offer this option to PIP buyers.
  4. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
  5. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
    I solved the problem by Removing the Compressor, Goo Cans, Jack and toe bar from the car. I was hoping to freeup a lot of weight, but they were only 10 lbs.
    I'll call ToyotaCare.
  6. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    If the point of the J bolt is just to hold down the spare, you can just use the straps for holding down a tire that is included with the Prius Plug-in.
    Perhaps you never drive out of cell phone range. If you do drive out of cell phone range, the compressor, fix-a-flat, and jack still provide a backup to Toyota Roadside Assistance in those circumstances.
