One year behind the wheel
Discussion in 'Chevrolet Volt' started by gwmort, Mar 30, 2012.
  1. gwmort
    gwmort Active Member
    985
    211
    Delaware
    Today is the one year anniversary of when I took delivery of my Volt.
    Here are the stats:
    21,035 total miles traveled
    14,132 EV miles
    6,903 gas miles
    EV UF = 67%
    Displayed mpg = 107 mpg
    total actual gallons consumed = 197 gal
    CS mode mpg = 35 mpg
    I don't measure kwh used and the 2011 doesn't display it, but assuming EPA consumption rates (36 kwh/100 miles) it used 5,087 kwh. At my electric rate (12 cents per kwh) it consumed $610 worth of electricity. I note that about 1/2 of my charging is at work so I only paid for around $300 of the electric cost.
    My displayed oil life is still at 55%, I have not changed it yet at all. The only routine maintenance costs were two tire rotations at 7,500 and 15,000 miles.
    It was in twice for warranty coverage, the first time to replace a squeaky panel in the dash which probably wouldn't have been noticed if the car wasn't so incredibly quiet in the first place. The second was to investigate a problem I had with the original 110v EVSE overheating, it was replaced with a beefier unit, likely the one that is being swapped in from the latest recall.
    My daily commute is generally gas free. I get free charging at work. I have longer trips about once a week on average that would make a Leaf impractical for me.
    During last summer I was routinely getting AER readings around 38-42 miles. When temps dropped below 50 degrees or so I started to see marked reductions in range with the lowest being about 28 miles when the temps were below freezing. This winter was fairly mild in Delaware and I only had the ICE start due to extreme cold twice the whole year. I never had the ICE start for engine maintenance mode, but like I said I use a little gas at least once a week. As temps have been rising this spring the AER has been increasing again.
    I am a big guy and it took a little getting used to how to get in and out of the car. Once in the drivers seat I find it comfortable and roomy. I have a family of four and my kids (7 and 8) fit perfectly in the backseats, adults not so much, although I have had some shorter adults back there tell me it is fine. The hatchback is very roomy for storage, remarkably so with the rear seats folded down.
    I did not renew the XM after the free three month trial period. I have free Onstar for 5 years and use it all the time. My favorite feature is I can have the operator download directions directly into the in dash navigation. I used to get frustrated with the specificity needed in my old Toyota navigation system and much prefer being able to talk to a person about where I want to go.
    The car's performance and handling are difficult for me to explain to anyone that hasn't experienced high power silent EV acceleration and highway travel. There is nothing quite like it. Its intangible or quantifiable, but one of my favorite things about the car. When asked how sporty it is I usually tell people "its not a porsche or anything but it is very sporty, sort of like my old pontiac was".
    The volt has lived up to or exceeded my every expectation. The personal Volt advisor assigned by GM was wonderful customer service the first 6 months proactively checking up with me and answering all my questions and helping with the two warranty items mentioned above. I also got a really nice welcome gift with a commemorative book and a digital camcorder from Chevy.
    I will never purchase another conventional car again, nor another that does not plug in. Gas is for chumps and the sooner I can be totally free of it the better.
    I have endeavored to fairly and objectively share my experiences here on PC to help others learn about this revolutionary new vehicle. I sometimes feel like I've had the same conversations many times and grow weary. It is my intent to withdraw from posting in the future and leave you all to your prii discussions. I will respond to this thread if anyone has any questions about my first year with the Volt.
    10 people like this.
  2. bajapat
    bajapat Junior Member
    72
    southington ct
    65 dollars a moth for gas not to shabby.... I spend that in a week right now....
    Less then a month till i get mine.
  3. Fore
    Fore Don't look back!
    494
    107
    Yes, but production is suspended because of?
  4. drinnovation
    drinnovation EREV for EVER!
    2,027
    586
    65
    CO
    They are down for two reasons
    1) Because they can produce 6000 Volt's month now, and that is still faster than they have been selling, or even were projected to sell. (Even if they sold 45,000 this year, 6000 a month is still more supply than demand). Shutting down for a short period will help align supply/demand and reduces costs.
    2) They are retooling parts of the plant so that it can also produce Malibus. This will make the plant more cost effective.
    Both of these moves will help reduce the costs of the Volt increasing its viability for GM to keep producing it.
    To gwmort.. thanks for the report. You'll be missed if you stop posting.
  5. Sabby
    Sabby Active Member
    295
    127
    SoCal
    Nice. It sounds like the volt was a great fit for your use pattern.
  6. gwmort
    985
    211
    Delaware
    Whether anyone else is buying them,or what political ramifications may swirl around the Volt are of no concern to me. I bought the car because I believed in what it could do and it has delivered.
    Basically gas free daily driving and no restrictions on where I can go or how fast.
  7. caffeinekid
    caffeinekid Duct Tape Extraordinaire
    334
    44
    Houston
    By the end of 4 years, you will have "saved" ~ $3700.00. Nice. :D
  8. bajapat
    72
    southington ct
    And will have been driving a sweet car
    iPhone ?
  9. Erikon
    Erikon Active Member
    819
    105
    Rochester, NY
    I feel sad that you won't post on the PC forums anymore! Yes, this is a venue for the Prius, but I think views from owners of the Volt, Leaf and all other present and future hyper FE vehicles is very important! There are things I like and dislike about the Volt, but I can say that about the Prius as well! The PiP is overpriced, the warmup cycle engaging every time you get too frisky with the throttle on short trips, plenty to criticize! High price and four seats, debatable styling, these are valid critiques of the Volt! The problem is when the arguments turn personal and devolves into a "Your car sux!" brawl! In any case, I'm glad your car is working out so well and wish you many years of EV ecstasy!:)
  10. gwmort
    985
    211
    Delaware
    Thank you. Its nothing personal to anyone here for the past year I have enjoyed the vigorous debates here. For the most part I find posters here to be respectful and courteous, if a bit entrenched in their opinions.
    Its just that now that all the numbers are out for direct comparisons between the systems involved in the PiP and Volt, a lot of the debate is gone and its just the numbers are what they are, and opinion. It is becoming less enjoyable for me.
    I love my Volt, but I think the Pip is a great car too. I think they appeal to different consumers and thats a good thing. I have owned a prius before and may own one in the future (but would prefer a BEV in the future).
  11. john1701a
    john1701a Prius Guru
    12,794
    5,276
    57
    Thank you for that too. Your effort to be constructive has been appreciated.
    Go over to GMI if you want a totally different perspective. There, the smug thrives still. The are what they are reality certainly hasn't sunk in yet. Volt is vastly superior, period.
    Hopefully, the real-world data will finally change that attitude. There is indeed a difference in consumers being targeted... and we know things will change with the next generation Volt anyway, becoming something which draws higher sales. That in itself could end the debates.
  12. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Your inputs were honest and constructive.
    Your data was non-biased non-manipulated.
    For these I thank you.
  13. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    Gwmort, thank you for sharing data with us.
    I personally believe the whole concept (yet, it works! LOL) may give good results in some commute patterns like yours. Much of my disbelief in GM Volt approach of plug-in has to do with technical matters of design, with effect like CS mode FE, while others here may have just responded less friendly a bit provoked by GM CEO Akerson comments.
    So please don't stop posting here!
  14. sxotty
    sxotty Member
    224
    28
    Pittsburgh
    Anyway I understand where you are coming from gwmort. I had posted here already so naturally involved myself in the volt discussions. It is at the point where in general everything just goes in circles though so what you are saying does make sense now. Still a shame to lose anyone with actual personal knowledge instead of just guesses and arm chair engineers.
  15. Skoorbmax
    Skoorbmax Senior Member
    2,641
    264
    Western NY
    That is a lot of miles. Have you noticed ANY change in behavior of the battery, like estimated range on a full charge? You've gone through 400 full capacity cycles already.
  16. Skoorbmax
    2,641
    264
    Western NY
    I don't blame you at all, honestly. This is a Prius forum, so there's an inevitable bias among people (including me). I'd like to think most people here are polite, but it's not always the case (including me), and it can be hard to continually fight from the back foot, which is not necessarily because you support the Volt but because it's a Prius forum.
  17. gwmort
    985
    211
    Delaware
    At the moment my AER is on the increase because of the seasonal shift and rising temperatures, I would say its about where it was at this time last year, but there wasn't any history back then for it to base it on either.
    The best I can say is it is too early to tell if I have a change in battery performance, I don't think I do. If this summer I'm not getting the 38-42 miles indicated again I'll know better.
    Should also note that most of my cycles are half cycles. I leave home at full charge, get to work at half charge, charge at work, leave work at full and get home at half, rinse and repeat. I would guess my number of "full" cycles is closer to 100 (about 2 a week on average).
  18. gwmort
    985
    211
    Delaware
    I will say I have posted on GM-volt a bit too, but I much prefer the heated discussions here over the mutual admiration society over there. As an attorney I appreciate civil yet zealous advocacy.
    When I started posting I felt there was a need to share my experience since there was so little out there on these wonderful cars. My Volt is #1883. Now there are ten thousand or more out there and information is more widely available.
  19. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Thanks for posting your data and all your constructive posts with respect. For that, I considered you a friend. Keep us updated with your data and feel free to join into future heated debates.
    I thought 2011 software can be updated so it displays the kWh consumption. I also take it that you are going to skip the fix for "battery fire".
    If I recall correctly, you are leasing your Volt. With 21k annual miles, what is your limit and how much would additional miles cost you?
  20. gwmort
    985
    211
    Delaware
    There was a software update I got at some point (during a tire rotation I believe), but it did not start displaying kwh's.
    I am leasing, I have 15k miles a year and pay 18 cents a mile above that so the 6k miles are going to be $1080, unless I cut way back the next two years. I've pretty much decided I'm going to buy at the end of the lease so I am not too concerned about it anymore.
