Anyone have 18s on stock ride height
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Ytprius, Mar 28, 2012.
  1. Ytprius
    Ytprius New Member
    Az
    Saw a 2012 Prius today with 18 inch wheels in for oil change at local dealer. Funny thing is it wasnt lowered, no trim kit, and looked great. Anyone else here done this? How much of a hit does 18s do to mpg? I got a picture but cant figure out how to post yet.
  2. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    There aren't too many 18"-wheel Prius that look comparable to stock 17"-wheel Prius undropped and of course it all depends on the specs. Here's one example. If you're not careful, it'll look funky or goofy on stock ride height for sure. Expect a larger mpg hit with 18" wheels regardless of specs.
  3. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    from what i hear... 18's the largest you can go. i'm not sure if that's at a 215 width or not.. but i think it is. i even recall a 225 somewhere.. but that seems a little unnecessary. the cap for a genII is 17's.. the cap for genII is 18's... (without mods)
  4. HI MPG
    HI MPG Active Member
    789
    133
    93
    Orange County, CA
    Shawnb2 is running 19x8 Wedsport on his Gen III. Not sure if he has any rubbing issues...
  5. ockevin
    ockevin Active Member
    493
    148
    Orange County
    You can run 19 inch no problem or even 20s, but you need the correct offset and tire size.
  6. SoCalBPrius
    SoCalBPrius Active Member
    563
    118
    SoCal
    I have seen aftermarket 17's on stock GIII prius, don't recall seeing 18's on stock though. Please upload the pix. of what u saw as I'm very curious:).
  7. Jwb2781
    Jwb2781 Junior Member
    45
    Seattle, WA
    I had 18's on mine. Stock height....I thought it looked GREAT.
  8. GZspeed
    GZspeed Junior Member
    torrance, ca
    18's on a prius, so much for saving gas lol
  9. NineScorpions
    NineScorpions Economy, Meet Style!!
    375
    64
    here are my 18s with stock springs...
    And now with the Eibach kit...
    I am saving tons of gas even with my 18s...my last fill up was 49.1 calculated. Beats the hell out of my 12mpg Titan or my 25mpg Miata. Keep in mind my climate helps quite a bit.
  10. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    I'd have to say you had one of the few 18"-wheel Prius that don't look bad at all undropped.
  11. SoCalBPrius
    563
    118
    SoCal
    DR-33's do look good even on stock height:D. Hey Nine, I noticed your getting mighty close to the 50 mpg milestone. Pretty damn good on 18's. What psi are u currently running on your DWS?
  12. NineScorpions
    375
    64
    47 front; 45 rear. These tires have a much higher rating at 51psi than some others. The ride is pretty stiff...but to be honest I like it that way.
  13. F8L
    19,011
    4,083
    Grass Valley, CA.
    It's interesting how that works. I used to run 50/48 in my GenII 15s without any issues. The same pressure in my 17s was a bit on on the stiff side so I ran a lower setting. On the GenIII with my Ascends, 50/48 is way too stiff. So even though they are rated at 51psi max I find them way too stiff at that nothing higher than 44/42.
  14. Cecilia48
    Cecilia48 New Member
    us
    2012 Aqua
    [​IMG]Shawnb2 is running 19x8 Wedsport on his Gen III.
  15. SoCalBPrius
    563
    118
    SoCal
    Don't I know it(stiffness). When I do put back the 17's, I'm thinking of lowering the pressure a bit as I think 51-50 psi on my DWS is too jarring especially after feeling the comforts of my 15's:D.
