carfart horn
Discussion in 'Prius c Accessories and Modifications' started by actiondonkey, Mar 25, 2012.
  1. actiondonkey
    actiondonkey Member
    91
    30
    A guy cut me off today and I honked the horn at him; man that horn sucks! Dude shot me a bird and I felt like I deserved it because the horn sounds like the C taking a carfart. Any advice or experience to share in changing out the horn would be great. I assume a horn can be purchased online and just swapped out but I'd hate to fry something if the power draw is different. Thanks in advance if anyone has some info.
  2. hnx676
    hnx676 Junior Member
    Singapore
    Had a similar experience so I ordered a pair of PIAA HO-12 compact twin horns kit. It just arrived in the mail but I have not had time for installation yet..
    The original horn in my prius c is a single horn from Denso and it is connected with a single wire... So I probably need to make a Y connectors to connect both the horns that comes in the kit.. And most after market horn require ground connection too...
    I also take a look in the fuse box under the hood, the horn is running on a 10A so as long as what you connected does not go beyond that I guess it's ok...
  3. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
    any horn period requires a ground connection.. that's how anything electrical works.. the stock horn just uses it's own mount as the ground. any aftermarket horn should be able to be installed easily.. don't worry about power draw, as no aftermarket company would make something that would overwhelm the stock wiring.. and if so, then they would provide a relay harness that would tap power from the battery.
    and for the record, when i first read the title of this thread... i thought you were actually looking for a horn that sounded like a fart to be used in a vehicle.. instead of describing the oem horn..
    which btw, i've had to use quite often since i've owned this vehicle... odd.. i never really had to use the horn that much when i was driving other cars... but as you're learning to drive economically and really.. REALLY paying attention to your surroundings.. you'll find more and more stupid drivers on the road..
    RocMills likes this.
  4. BrunoPuntzJones
    107
    28
    heh, I thought the same
  5. Rebound
    Rebound Senior Member
    3,995
    2,643
    Portland, OR
    There's a great DIY horn upgrade already on PriusChat. Take a look at the photos and see if it looks similar to your Prius C.
  6. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    I vote GP-5 Diesel Horn, you can hear it 5 miles away, imagine how it sounds 5 feet away. Any bird you honk at will loose that hand when the monstrous sound wave rips it off!
    Second choice is the above mentioned PIAA HO-12 Air Horn.
    Loud enough to make your point!
  7. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
  8. Kirkuleez
    Kirkuleez New Member
    220
    24
    Oshkosh, Wisconsin
    Yeah, my old Echo had a real wussy horn as well. Apparently in Japan, horns are used as a friendly thing, where here in the U.S. horns are used as an angry F-you sorta thing lol!! My first Fit I think was that way to.
  9. actiondonkey
    actiondonkey Member
    91
    30
    Hook up a big tweet or megaphone behind the grill, run to a small amp and input from a pad/phone with the fart soundboard app. Play while driving through walmart pakring lot sunday after church and the youtube would go viral.
    In all seriousness thanks for the recommendations. Wife says the OEM horn has to go and actually something along the lines of dustoff's links are what I was looking for but didn't know they were so pricey! I could get her a megaphone & small amp for that much ;)
  10. cpfans4
    cpfans4 Junior Member
    42
    illinois
    Had to use my horn today as I was driving in a parking lot. People don't look all the time they listen and since in ev mode the prius is almost stealth this lady almost pulled out from an unloading zone into my c.
  11. formula
    formula Member
    320
    32
    CA
    put the train horn under the hood. :)
  12. p00kienrayray
    p00kienrayray Active Member
    720
    135
    Long Beach, CA
    The guy flipped you off bc your horn sucks?? WTH is wrong with people these days?
  13. loaddown
    loaddown Loaddown
    34
    St Lucie West, FL
    If you want to connect both the high and low frequency horns to the single mount of the Prius C, you can get the idea from this discussion:
    Fiamm Highway Blaster Horn Install - Hyundai Forums : Hyundai Forum
    There are some clear pictures that show connections that are similar to our cars.
    Here is a Prius example. I like the simplicity of adding, rather than replacing the horn:
    http://priuschat.com/forums/gen-iii...ons/64808-side-turn-signals-upgrade-horn.html
  14. loaddown
    loaddown Loaddown
    34
    St Lucie West, FL
    The only problem between a Prius and a Prius C, it seems, is that you can access the horn on a Prius by just removing the top fascia and emblem. Squall seems to think you have to remove the whole bumper cover on a "C". Has anyone removed the top fascia on a "C" without removing the bumper cover?? It looks like you could flex it a little and it would come out!
  15. hnx676
    Singapore
    Done the horns upgrade a few weeks ago.. I was also looking for ways to get to the horns without removing the front bumper.. But unfortunately due to the way the top fascia was mounted, it's not possible to be removed without taking out the front bumper...
  16. SquallLHeart
    826
    247
    San Jose, CA
    not think.
    know.
    there's less effort removing the front bumper in the first place... than try to avoid doing so.
    i suppose you can partially remove the front bumper, but eh.. still more effort trying to wiggle in there to access the horn than just taking the bumper off completely.
    2 people like this.
  17. loaddown
    loaddown Loaddown
    34
    St Lucie West, FL
    Thanks. I trust your experience. I will study your uploaded diagram and try to get my confidence up for this.
  18. SquallLHeart
    826
    247
    San Jose, CA
    if you need actual photos, or anything else.. (i.e. tools required, bigger pictures, etc..) just let me know.
    i've been taking apart cars for years.. :D
    Toyota and Scions so far have been the easiest. most times, you can yank away at panels and figure out how something comes apart.. find a nut, screw, bolt, clip, or another panel that's in the way? well, do what you have to, and continue yanking.. lol :p
  19. donny612
    donny612 "Captain Jack Sparrow"
    117
    Apex, NC
    I'd really like a train horn...but where to put the compressor and the horns themselves...:D
  20. hota**priusc-3
    hota**priusc-3 Junior Member
    brookhaven p.a
    here is something a little cheaper and sound cool,i had a high and low off a old caddy late 70s made a mount wired them together and wow sound so weird coming from a prius.....and it works fine...
