Elec Power Steering- detailed description
Discussion in 'Gen 2 Prius Accessories & Modifications' started by 200Volts, Nov 29, 2005.
  1. 200Volts
    200Volts Member
    434
    45
    Northern CA
  2. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Good article. The math is straighforward, at least for me it was.
    Figure 8 is also how most modern industrial 3-phase Variable Frequency Drive controllers work.
  3. mehrenst
    mehrenst Member
    439
    San Jose, CA
    WOW!!! :D Even if you don't want to know you should read it. :ph34r:
  4. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    wow is a major understatement... another feather in Toyota's engineering design teams cap
  5. tacopyro
    tacopyro Member
    86
    42
    Los Angeles
    reading up on power steering for my vw... was trying to read the article posted by OP but it has since been taken down quite a while now.
    found it in archive org site and alternatively found it at its origin.
    article is named "Electric power steering: one good turn deserves another"
  6. tacopyro
    tacopyro Member
    86
    42
    Los Angeles
    apparently i cant post a link since i have so few posts...
    will update the above when i get more posts approved by the moderator.
  7. tacopyro
    tacopyro Member
    86
    42
    Los Angeles
