Normal for brakes to make squeak/hiccup if pressed deeply and released?
Discussion in 'Gen 2 Prius Main Forum' started by monsieurpooh, Apr 15, 2012.
  1. monsieurpooh
    monsieurpooh Junior Member
    ca
    Is it normal for the Prius's brakes to make a low-pitched squeak (kind of like something wet rubbing against something, or a burp), when I press it semi-deeply and release? The only reason I'm worrying is that I ran over a camouflaged flat metal object on the road today while changing lanes, and it could've weighed anywhere from a soda can to a heavy shovel -- it clunked against the bottom of my car loudly, then got propelled into the air and barely missed a car behind me. It seems trivial but I'm paranoid because I just got the car (used, great condition) and that happened on my first day. I don't remember if it was squeaking before the shovel incident. My girlfriend says her 3rd gen prius does it too but I have yet to verify it.
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,830
    Clearwater, Florida
    If something metal hit the bottom of my car loudly I would take a look under the car for damage. Do you know the general area of the hit? It may be worth putting it on a lift for a full undercarriage inspection and while its up there have the transmission fluid changed too since this is a fairly old car and new to you.
    I always change all the fluids on any used car I buy no matter how they look. I recommend changing the Inverter coolant also. Many how too's here and lots of You Tubes on that too as its a fairly easy DIY.
    As far as the brakes once in a while when you press the brakes it engages a small motor up front that creates vacuum for the brakes. This motor when running makes a faint tickity tickity noise for a few seconds while it runs. It only runs for a few seconds then shuts off.
    If you have good hearing you'll hear it all the time.
    You can make this brake vacuum motor run by sitting at a light with engine off and press the brakes firmly a few times and then listen.
    Hopefully thats it. If thats not the noise get the car up in the air and find out what it hit asap.
  3. monsieurpooh
    ca
    It happens exactly on release. It is something mechanical, doesn't sound like an engine. It's a burp, not a tickity tick
  4. Jay Danz
    Jay Danz New Member
    Have you found anything out about this? I'm noticing it on my '08 Prius. It sounds like a weird burp, almost like someone's tapping a low-pitched car horn.
  5. Britprius
    Britprius Senior Member
    5,194
    1,918
    Herefordshire England
    This is a well known Prius problem. It is caused by a small amount of air in the brake system. It often gets worse with altitude, however it is not dangerous. It can usually be cured by bleeding the brakes. There is a Toyota service bulletin out for this, see below. Also much information in this link. Do not attempt to bleed the brakes yourself unless you have studied the many posts here on the subject. It is not the same as bleeding normal car brakes, and will likely end up with an expensive trip to the dealers.
    My Brakes are Barking at Me
    T-SB-0307-08.pdf
    John (Britprius)
  6. Jay Danz
    Jay Danz New Member
    Thanks John! I'm consoled by the long the five-page thread detailing the same thing. I got my Prius used and it makes interesting noises that this former combustion-only driver isn't used to.
