Prius C 12V battery
Discussion in 'Prius c Main Forum' started by David Beale, Apr 22, 2012.
  1. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    I hear the Prius C actually -has- a real normal sized battery! It's sealed with a vent tube of course, but wow, more than 50 A-Hr. That alone is enough to make me want a Prius C. ;) For those wondering where it is, check under the rear seat, passenger side. You have to remove paneling to get to it. I wonder if it's large because the car was the fully loaded one (for Canada).
  2. madfast
    madfast New Member
    45
    28
    NY
    here's a pic from the toyota aqua. anybody got a part number for the 12V? battery specs like group size? it looks like a bitch to access for jump start and an even bigger bitch to change. look at that tie down bracket, is it stuck to the frame, or can it be removed?
  3. Kenny_n_Steve
    Kenny_n_Steve New Member
    35
    Brooklyn Center, MN
    Holy buckets, that's a bit dumb but then again, after four years I've never needed a jump so why worry?
  4. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    i believe access to jump points is under the hood of course.
    brian van vlymen likes this.
  5. jpadc
    jpadc Type before I think too often
    343
    34
    Indianapolis and Northern Wisconsin
    2017 Prius Alpha
    I looked for jump points (like on the standard Prius) under the hood when I was at a dealer looking at one. I could not find them...
    Anyone know where they are?
  6. David Beale
    5,963
    1,988
    Edmonton Alberta
    Hmm, I think my source is incorrect. That looks like the same battery in the other Prius.
    I too looked for a jump point as in the other Prius and couldn't find one in either fuse box under the hood. Time to check the manual.
  7. caryanne
    caryanne Junior Member
    24
    Massachusetts
    Manual says you access the battery by removing the front panel under the rear seat and that's where you jump it.
  8. Daze
    Daze Prius C Owner
    92
    Utah
    Yeah i think you jump it directly at the battery terminals...i dont think they put in jump points
  9. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
    yup yup... that's where you jump it.. lol.
  10. priusCpilot
    priusCpilot Active Member
    663
    210
    LA
    The location is ideal because of the weight distribution. Once the reason why i bought the C is because they cared about reducing weight and improving handling. I believe it's just a cover with two clip screws to get to the battery.
  11. priusCpilot
    663
    210
    LA
    Thanks for posting this shot! I did not find it playing around on the Japan site but now I can see the battery better. Now if we know the size and weight it would be great.
    I wanted to replce mine with one of these lite Li-Ion battery's.
    Lithium Pros » Racing 12V Batteries
  12. B. Roberts
    B. Roberts Hypah Milah! Ayuh.
    691
    212
    used to be "Glacial" Maine and now FL
    Uh-oh!:eek: There goes all that carefully planned weight distribution work they did back in engineering!:)
    RajSesh likes this.
  13. priusCpilot
    663
    210
    LA
    Toyota's engineering department won't mind if I help improve things further. hehe
  14. madfast
    madfast New Member
    45
    28
    NY
    anybody who works for toyota, can you please look up the part number for the 12V??? i dont care which battery it is, as long as optima comes out with a replacement :D
  15. David Beale
    5,963
    1,988
    Edmonton Alberta
    Well, if you are forgetful it might be a good idea to install short leads to a connector so you don't have to remove the panel. You could also use the connector to add a solar charger. Just lay it on the cargo cover, and put it under the cargo cover then driving (for safety).
    That looks like the fully sealed Prius battery (no chance to add water). I'll give it three to four year life.
    I was surprised to see the floor of the hatch area is crash absorbent foam (removable). Interesting ideas used on this model.
  16. David Beale
    5,963
    1,988
    Edmonton Alberta
    It now appears the Prius C battery is the smaller one used in the GII Prius. It's smaller than Pearl's battery.
  17. BJ_EVfan
    BJ_EVfan Member
    75
    29
    Buffalo, NY
    Browsing around, I find this image pretty amazing. I didn't know the 12v battery was also under the seat. Good to know.
  18. BJ_EVfan
    BJ_EVfan Member
    75
    29
    Buffalo, NY
    If you're doing a mod, maybe the goal is to create 3x or 5x or even more battery capacity? That would be my goal at least. A *real* mod to the Prius C, and the only one worth wasting valuable money on, would be a mod that hacks the EV Mode button to allow unlimited speeds instead of 25mph, and a battery that had between 5 and 10 KWh storage. Of course 10 KWh probably wouldn't fit under the seat, it'd have to be a larger, modular upgrade that also takes up space where the spare tire is, but I could see it viable in the coming years with improved battery technology.
    Just imagine a Prius C with a 10 KWh battery upgrade that you can plug in and charge for under $10,000. After owning the car for several years, it would be worth the investment. Just add on the cost of the upgrade to a refinanced car loan and you'll have a fully electric capable vehicle that also gets incredible gasoline mileage. It would be more practical than a Volt since the Volt barely goes 35 miles on EV Mode and only gets 35mpg when it runs out.
    How far do you think a 10 KWh battery would pull a roughly 2500 lbs vehicle? 20 miles? Maybe more? Then getting 50mpg when the gas has to kick in? That'd be *better* than a Volt, although with only 60hp the electric engine would certainly be slower.
  19. los panda
    los panda Member
    155
    i am trying to find specs on how much the stock battery weighs, does anyone have a link to specs? or know the model number?
  20. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    It weighs 10.5 kg (23.1 lbs), the same as Gen 2 battery without SKS, S34B20R.
    Vincent
    los panda likes this.
