Installed TRD "Prius Plus" springs
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Loading..., Apr 26, 2012.
  1. Loading...
    Loading... Junior Member
    Honolulu
    I purchased the springs from the dealership two weeks ago and have been driving around with the new drop for about a week. The installation was straightforward because instructions in the box helped.
    The side to side wobble and jostling stopped, less lean when taking corners, and the ride is slightly firmer. The height is perfect for me (lowered 1.1 inches f/r) and to me, the stance makes the car look way better. I haven't had any issues with driveways or speed bumps.
    As you can see in the side by side comparison of the TRD and stock springs, the stock coil spring's length is much shorter and thinner than the TRD set.
  2. ajtozzi
    ajtozzi Junior Member
    94
    How much were the springs?
  3. Loading...
    Honolulu
    I think they go for $240? I'm an employee at a dealership so I got mines at a discount.
  4. tsair
    tsair Junior Member
    29
    Sunnyvale, CA
    Looks great. The white with black wheels looks great as well.
  5. Suckmypanthee
    Suckmypanthee New Member
    Temple City
    Do the wheels butterfly in any way? Did u have to get it re-allign? I'm looking at the Teins Springs that have a 1.5" drop but afraid that it will butterfly.
  6. xliderider
    xliderider Senior Member
    8,134
    3,273
    Honolulu, HI
    Alignment should be done after dropping the car, but after a settling in period.
  7. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Looking good. It's like looking at my cars twin
    mrfritz0528 likes this.
  8. Loading...
    Honolulu
    Do you mean camber on the wheels? Yes, lowering the car would change the camber.
  9. Loading...
    Honolulu
    Looking good! Are you on TRD Plus springs too? Your car looks lower than mines.
  10. LulzChicken
    LulzChicken Prius Enthusiast
    791
    135
    Alabama
    Both cars look great! I have a question for both of you though. Did you guys paint your stock rims or are those aftermarket? If so, how did you paint them and with what? Thank you!
  11. Loading...
    Honolulu
    The 2012 models have black wheels versus the 2010-2011 silver wheels.
  12. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    Now we really gotta meet up and chat. I got a quote from SAL of $314.10 for the springs. Have you considered or are you planing to install the rear sway bar?
    Posted from my iPhone via the Tapatalk app.
  13. Loading...
    Honolulu
    I'm not getting the rear bar. I think it'll be fine without it. I had STIs and Miata's that surely needed sway bars to squeeze the most performance out of the suspension. But I'm not planning to drive that aggressively in the Prius. My friend plans to put one in soon.
    I'll pm you my contact info.
  14. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Thx. Mine has H&Rs.
    these are the stock 15" rims that come on the 2012 Prius.......we just removed the plastic covers.
  15. sneeeky
    sneeeky Junior Member
    arcadia
    how is the ride with the trd springs compared to stock?
  16. Loading...
    Honolulu
    The ride generally feels smoother. It's firmer over bumps and is flat around corners. I would recommend these springs if you just want a mild drop but still want to improve the handling.
  17. F8L
    19,011
    4,083
    Grass Valley, CA.
    I'm glad to hear you say that. I got to drive The Critic's car to LA while it was stock and then I drove it again after he lowered the car and it did feel smoother. It felt nothing like my GenII did on Eibachs. You seem to get all the benefits of a drop but none of the negative effects unless you want a full on race spring with greater tension. If I find a set for cheap enough I may get them later in the year.
  18. rickelchilango
    rickelchilango Junior Member
    32
  19. Loading...
    Honolulu
  20. wotcher
    wotcher Member
    403
    97
    LA
    thats a great deal. ive been looking at their site for 3 wks now. i remember its always been ~ $250s-300s
