Choosing tires
Discussion in 'Gen 2 Prius Main Forum' started by jellybug, Apr 27, 2012.
  1. jellybug
    jellybug Junior Member
    24
    South Dakota
    I
    Looking at two choices, as I narrowed them down. I am looking at the Michelin Harmony and the Michelin A/S Gas Saver.
    Michelin Harmony seems to be a great, all-around reliable tire that will go to 80k without problems.
    Michelin A/S seems to have more trouble cornering and wet traction, only goes to 65k, but has the added bonus of up to 10% increase in MPG and is $60 cheaper..
    Who has used these tires and what can you say about them?
    Thanks!
  2. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Doing a search on Prius Chat reveals the following information on the Harmony.
    Online resource for the Toyota Prius offering discussion forums, research, and shopping. - Search Results for Michelan Harmony
    Doing a search on Prius Chat reveals the following information on the Energy Savers
    Online resource for the Toyota Prius offering discussion forums, research, and shopping. - Search Results for Michelin A/S Gas Saver
    Hope this helps you in making a informative choice.
    Ron (dorunron)
  3. F8L
    19,011
    4,083
    Grass Valley, CA.
    Hands down, Energy Saver A/S of those two. The Harmony will cause mpg to drop and Energy Saver A/S will produce a gain. This is as compared to your OE tires. The fuel savings and lower cost of the A/S will save you money compared to the longer lived Harmony. Besides, they are discontinuing the Harmony with the Defender.
  4. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    I am happy with my Energy savers so far ~5000 miles I can feel a little hunting in groves in pavement, but not bad. they seem quiet, and I feel I coast further.
    I have not used the Harmonies.
  5. jellybug
    24
    South Dakota
    I
    Here's another twist. What about those Ecopia's from Bridgestone? Or the Yokohama AVID's?
  6. F8L
    19,011
    4,083
    Grass Valley, CA.
  7. jellybug
    24
    South Dakota
    I
    Is it possible or plausible to use a 205/65R/15 Tire on the '05 Prius?
  8. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Sounds way too big. If you don't want to adversely effect your fuel economy I recommend staying with (or near) the OEM size.
    The most commonly used sizes are 185/65/15 or 195/60/15, both of which have similar rolling circumference. Also, although it's a slightly larger rolling circumference, 195/65/15 is fairly popular as it tends to correct for the speedo which normally under-reports speed by a few percent.
    In the US 185/65/15 is the standard OEM size, while in Australia and some other countries 195/60/15 is the standard prius tire. Both work well.
  9. uart
    uart Senior Member
    4,220
    1,211
    Australia
    With fuel prices rising fast don't under-estimate the cost of reduced MPG if you make a bad tire choice. I've estimated that, over the life of the tires, it costs over $100 for every 2% loss of fuel economy.
    Compare even the small change of 49 MPG versus 50 MPG over 65000 miles. The extra fuel used is 65000*(1/49 - 1/50) = 26.5 gal. With fuel likely to exceed $4/gal over that time then that's easily more than $100 saved. None LRR tires are false economy.
    Basically this means that some non-LRR tires could cost you an extra $500 over the life of the tires.
  10. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Yes both the Ecopia EP100 and EP422 have a proven track record in giving good fuel economy. The EP100 is a summer tire (and excellent if you don't have snow or ice) while the EP422 is an all seasons tire. I'm not sure if it's been proven, but it's thought that the EP100's have slightly lower rolling resistance but the EP422's are slightly longer wearing. I put the EP100's on about 6 weeks ago and have been very happy with them.
    I'd say both the Ecopia's and the Michelin Energy A/S have the most proven track record in LRR and fuel saving.
  11. kammssss
    kammssss Member
    287
    86
    SoCal
    uart...are the EP100's quiet on the freeway? I think that they're a great deal.
  12. uart
    uart Senior Member
    4,220
    1,211
    Australia
    I don't have a lot to compare them with, they seem about the same as my previous set of Hankook k415's. Honestly I don't notice any excessive noise.
  13. NASCAR Mike
    NASCAR Mike Senior Member
    83
    Richmond VA
    I recently replaced the factory Yokohama AVID tires to the Michelen Energy Savers. Ride is quieter, hydroplaning is reduced and handling is about the same or slightly better.
    I have confirmed over the past 1800 miles on the Energy Savers a 1.8 MPG increase using gas receipts to calculate MPG, not the mileage lie-o-meter.
  14. Patrick Wong
    18,200
    6,500
    Very quiet. However they may not currently be available in the Prius 15" tire size.
  15. kammssss
    kammssss Member
    287
    86
    SoCal
    Yeah...I just found that out today. I bought 4 on eBay for 285 with free shipping and no tax, but then the seller tells me he has only 3 of them...damn!
