Power converter cover
Discussion in 'Prius v Main Forum' started by tanasit, Apr 30, 2012.
  1. tanasit
    tanasit Member
    399
    60
    Philadelphia
    When I first saw that the power converter is exposed with a high voltage warning sign, I wasn't feeling comfortable if I has to work inside the engine room. As you can see below:
    Also there is a wire cover missing as mentioned here:
    http://priuschat.com/forums/prius-v-technical-discussion/107794-missing-wires-cover.html
    So I looked for the pieces and found them to be Toyota parts that were not included in the US version. I ordered them from Japan and installed as you can see below:
    These are the brackets (stock on the left and the new one is on the right with extra slot to hold the cover).
    There are also covers for the coolant reservoir for both the engine and the converter, but I didn't care for those.
    2 people like this.
  2. PRPrius
    PRPrius Active Member
    327
    198
    where did you buy the cover? I wonder if it would fit my PiP.
  3. tanasit
    tanasit Member
    399
    60
    Philadelphia
  4. nedear88
    nedear88 My 1st Prius.
    246
    142
    San Bruno, California
    Thanks Tanasit for the great pictures and information. I just order the whole set. I notice that after car wash water sipped inside the inverter housing and the fuse box area. I want to keep the inverter dry after car wash.
  5. syscon
    syscon Member
    329
    43
    Edm. Alberta
    Kind of expensive $135.00 for a piece of plastic!
  6. schinia
    schinia Member
    162
    25
    cape carteret,nc
  7. tanasit
    tanasit Member
    399
    60
    Philadelphia
    No instructions but rather simple: remove the bracket to the left of the inverter and remove the 2 harnesses BEFORE puling out the bracket. Note that the top harness connector you have to press on the tap to pull it out but the lower one you must pull the tap UP. Install the included bracket that has extra slot to catch the plastic pin lock, insert the harnesses back. To install the cover, there is a hole on the outside of the right wall of the inverter so you have to insert the felt covered peg on the bottom right of the cover in to that hole first. Push the plastic pin lock in. If you want a cleaner look, you have to cut the bottom of the cover to blend in with the top panel. As for the big hole which I assume it's for other model, I put the emblem over as seen below:
    I later decided to cut the bottom part.
  8. TruSound
    TruSound Member
    246
    32
    The 818
    Toyota not including these small 10 dollar bits of Plastic on all versions of the Prius is completely rediculious...but you knew that, $135 for the inverter cover...even more rediculious.
  9. tanasit
    tanasit Member
    399
    60
    Philadelphia
    Agreed.
  10. DGH
    DGH Thread Terminator
    365
    93
    Wales, WI
    It's an outrage, boo on Toyota!
  11. slazerow
    slazerow New Member
    Il
    Just wondering if the cover reduces the whining noise associated with the inverter. I agree they should really include the cover as standard equipment.
  12. xliderider
    xliderider Senior Member
    8,125
    3,265
    Honolulu, HI
    From item description:
    "Inverter Cover Come With Sound Absorbing Material On The Back Side"
