One In 10 New Vehicles Will Be Diesel In 2015
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by massparanoia, May 2, 2012.
  1. massparanoia
    massparanoia Active Member
    697
    467
    Virginia
    You can get diesel exhaust fluid at wal mart for 7 bucks a gallon.
  2. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    uh, cleaner than before yes, virtually eliminating emissions? no.
    New 2014 rules will be even stricter than today's... thats just standard LEVIII... SULEV and such wont be reached by diesels anytime soon.
  3. spwolf
    3,156
    440
    Eastern Europe
    Base LEVIII NOx yes (slightly less than before), but for PM, 40% reduction in 2014 and 70% reduction in 2017 from current standards.
    Also much stricter fleet emissions:
    Which means that if you want to sell significant amount of diesels, they will have to do better than LEVIII in order you to sell them because fleet average is 5.3x less than LEVIII.
    Unfortunately Euro6 coming in 2014 is still considerably easier on emission than even today's LEVII (70%).
    As to the SCR, to my knowledge, it is still applied to the DPF so yes, DPF reduces fuel mpg and performance.
  4. wxman
    wxman Active Member
    636
    231
    Tennessee
    Virtually eliminating PARTICLE emissions. Even CARB acknowledges that a diesel car they tested had particle emissions that were indistinguishable from background dilution tunnel air (and CARB is ANYTHING but a diesel proponent). Direct quote from that report...
    ("California’s Informal Participation In The Particle Measurement Programme (PMP) Light Duty Inter-Laboratory Correlation Exercise (ILCE_LD)." Final Research Report, October 2008, http://www.arb.ca.gov/research/veh-emissions/pmp-ld/CARB_Golden_Vehicle_PMP_Report_Final-05JAN09.pdf (page 28))
    The 2012 MB E350 BlueTec comes very close to meeting SULEV (http://www.arb.ca.gov/msprog/onroad/cert/pcldtmdv/2012/daimler_pc_a0030427_3d0_u2_diesel.pdf). It hits the SULEV limit for NOx (0.02 g/mile); it's only slightly high on NMHC (0.015 g/mi, the SULEV limit is 0.010 g/mi) which keeps it from achieving official SULEV classification (it easily meets ULEV). So it's close enough to preclude a conclusion that diesels can't hit SULEV, IMHO.
  5. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    As far as I am aware, SCR is a separate after-treatment specifically used to reduce NOx. In fact, I believe that it would specifically be separated because contamination is a problem.
    Although it requires urea solution, it's relatively cheap and allows for more efficient combustion that produces fewer particulates. As with DPF the key problem is that diesel owners need to keep them working.
  6. Trollbait
    12,539
    Regen to clean the DPF is what reduces the MPG, and more so in low speed city driving. Manufacturers are working to decrease the number of regen cycles. Not following the field closely, they might have reduced the number from earlier gen DPFs.
    SCR fluid is sprayed into the exhaust before the catalytic convertor. The DPF plays no part with SCR. Diesels without SCR use EGR*. People would defeat the EGR on early smog control diesels. They would also defeat the EGR on gassers for the same reason.
    The reduction of performance and economy that is happening to diesels do to emission controls also happened to gassers in the late '70s and early '80s. Power and economy don't seem to be an issue for them anymore. With the gained knowledge from then, the transitory period should be shorter for diesels. We might already be past the big hump with it.
    I wouldn't rule out the change in EPA testing coloring the public's views on what emissions controls has done to diesels. It happened between DPF requirements and NOx controls.
    *It appears VW uses a NOx trap that needs to be cleaned like the DPF in the Jetta.
  7. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    If diesels are dirtier because urea is added and pumped out of the exhaust, then what about the heavy metals pumped out of petrol car exhausts from the catalysts?
    I'm sure I've read that on some roads in America where catalysts have been used for decades, that it is commercially viable to extract precious metals from the road side. Obviously that isn't going to happen, but the fact that these precious metals are there in such numbers is quite alarming isn't it?
  8. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    BMW recalling 24,000 Diesel vehicles over emission problems!
    Posted May 4th 2012 6:01PM
    BMW recalling 24,000 vehicles over emissions problem
  9. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    Hmmm....
    To be clarified...
    Urea is added to promote NOx break down...helps pumping molecular Nitrogen and Water instead! Urea is totally consumed for this purpose.
    [ame=http://en.wikipedia.org/wiki/Selective_catalytic_reduction]Selective catalytic reduction - Wikipedia, the free encyclopedia[/ame]
    The metal of catalysts does not get consumed at all. And the end of the process (end of life) it gets into the recycling procedures and viably reused.
    [So does Nickel from NimH Prius batteries and Lead from 12V batteries]
  10. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
  11. telmo744
    2,181
    769
    Portugal
    Good to chat about... :)
    Half-surprise, rare metals are not meant to be consumed, but...
    ...some may effectively come out of a breaking layer of a catalyst pot...and be more present in road dust than in the mining soil...
    But I wouldn't consider that a "pump out of the pipe"... ;)
  12. El Dobro
    El Dobro A Member
    7,088
    3,270
  13. wjtracy
    wjtracy Senior Member
    11,368
    3,608
    Northern VA (NoVA)
    Interesting GC, I have not heard of any such USA studies to show the enviro traces of Pt from the catalysts. Actually I am aware of studies to collect dust and see what's in it (eg; pollutants). But I have never heard that they found any Platinum in it.
  14. spwolf
    3,156
    440
    Eastern Europe
    NMOG+NOx are 2.5x worse than 2014 LEVIII SULEV standard, which will have to be warrantied for 150k miles.
    It is also 830% worse than Prius G3 NMOG+NOx emissions.
    Thats a lot worse.
  15. justlurkin
    justlurkin Señor Member
    499
    63
    Long Island, NY
    Just to clarify, metals like platinum and palladium are generally inert and resistant to corrosion, so unlike reactive heavy metals such as lead, they are not toxic to most living things.
    In fact, palladium is used by dentists in crowns and other prosthodontic devices that are put into human mouths, and platinum has been used as a jewelry metal.
    So I wouldn't classify the trace amounts of platinum or palladium coming out of a car exhaust as harmful pollution like CO or NOx.
  16. wxman
    wxman Active Member
    636
    231
    Tennessee
    I don't follow how you arrived at those numbers.
    LEVIII will actually have two "SULEV" categories - SULEV30 and SULEV20 (
    Emission Standards: USA: Cars and Light-Duty Trucks?California). The E350 BT has certified emissions of 0.015 g/mile NMHC plus 0.02 g/mile NOx, for a combined 0.035 g/mile HC+NOx. 0.035/0.030 = 1.167 times worse than the SULEV30 standard. I would think a little more robust oxidation catalyst could reduce the NMHC emissions enough to hit SULEV30? You're correct that the FUL standard has been increased to 150,000 miles.
    The Prius has certified emissions of 0.005 g/mile NMHC and 0.003 g/mile NOx, for a combined 0.008 g/mile HC+NOx (http://www.arb.ca.gov/msprog/onroad/cert/pcldtmdv/2012/toyota_pc_a0140763_1d8_pz_hevge.pdf). It will meet the SULEV20 standard when implemented. 0.035/0.008 = 4.375 times worse.
    Nissan claims to have developed a SULEV diesel car (SULEV Level Clean Diesel Technology | NISSAN | TECHNOLOGICAL DEVELOPMENT ACTIVITIES). However, since Nissan doesn't offer any diesel cars in the USA, this is just an academic achievement at this time.
  17. ETC(SS)
    7,157
    Re: One In 10 New Vehicles Will Be Diesel In 2015
    Maybe.
    Re: One In 10 New US Private Passenger Vehicles Will Be Diesel In 2015
    Aint. Gonna. Happen.
  18. spwolf
    3,156
    440
    Eastern Europe
    I was looking at wrong table... so E350 CDI - 0.035 g/m... Prius 0.008 g/m, only 530% higher than Prius? Or rather it takes more than 5 Prii to pollute the same as E350 CDI with very expensive urea and DPF systems. And Prius has no expensive DPF.
    150,000 mile requirement will probably introduce more costs for manufacturers of diesels as well.
    For instance, MB UK sells both BlueEfficiency E350 CDI with 265hp and BlueTec E350 CDI with 211hp... I assume one is EuroVI spec and other is EPA spec.
    Bluetec is $3k more expensive and you get 50hp less from same engine, just to satisfy extra emissions. Compared to 4cly turbo petrol with 204hp, it is $12k more expensive.
  19. Sergiospl
    3,938
    1,351
    28
    Diesel fumes cause cancer, says WHO | Science | guardian.co.uk
    http://press.iarc.fr/pr213_E.pdf
  20. austingreen
    austingreen Senior Member
    13,675
    4,213
    Austin, TX, USA
    But most of us already knew that.
    Diesel Engine Exhaust Causes Lung Cancer: WHO - Businessweek
    Which makes me wonder what levels are safe? Why do diesels have different numbers than gasoline engines if they are unsafe?
    It makes me glad that the US has been largely more concerned about diesels unhealthy exhaust than the reduction in greenhouse gasses. But the study does not say the newer "clean" diesels are worse than gasoline.
