First Fill Up - How many miles did you have on the car?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by SocialSuzy, May 7, 2012.
  1. SocialSuzy
    SocialSuzy New Member
    22
    Sacramento, CA
    Had to put my first tank of gas into the PIP today. $35.00 and had 650 miles logged on the ODO :)
    Would love to hear how many miles you were able to log until you had to fill.
  2. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    Check out the spreadsheet many of us have been contributing to.. that will give you an idea.
    So far the record holder is iRun26.2.. his first tank took him 1,613.5 miles. However, I know there are also quite a few owners here that have yet to get gas. So I think we'll see a few noteworthy numbers in the near future (or not so near future).
    http://priuschat.com/forums/toyota-prius-plug-in/106610-pip-mpg-spreadsheet.html
    (click the MPG tab at the bottom once the Google spreadsheet opens)
    But to answer your question, my first tank took me 793.6 miles (87.3MPG calculated).
  3. mitch672
    mitch672 Technology Geek
    1,077
    198
    Randolph, MA
    702 miles, however it was not empty, still had 2 pips on the gauge, it was just time, since it was 2 full weeks (used to gas up my 2010 every week), plus I wanted to make my first entry to Fuelly :)
    I would add myself to the google spreadsheet, but doesn't look simple... I did take a picture of the EV/HV display at the first fillup (before resetting it)
    I am on Fuelly, I added the KWH to the "notes", perhaps we can come up with a standard way to enter the EV/HV screen to the "notes" field in Fuelly, then you will be able to get that data onto the google spreadsheet.. Just a thought.
  4. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    My first fill up was from all highway driving whereas I drove to New York State from Michigan in my Corolla then drove back to Michigan, total miles at fill up: 373.4 miles. gallons of gas consumed: 7.441. calculated mpg: 50.16mpg also, my tank was not empty: 3 pip's
  5. banshee2008
    banshee2008 New Member
    San Jose, California
    We haven't had to fill up yet. 1320 miles so far. Won't be long, though, since we only have 42 miles of range left, apparently.
  6. crewdog
    crewdog Acting Ensign Prius Prime
    492
    388
    Woodstock, GA
  7. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    That has got to be continuous, daily EV charging,....right? Anyway, really incredibly great stats!
  8. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    I've had three fill-ups and calculated at the pump was right on with indicated consumption in the car.
    540 miles @ 59MPG indicated
    w/ 9.15 gallons pumped
    722 mile @ 75MPG indicated
    w/ 9.61 gallons pumped
    820 miles @ 91 MPG indicated
    w/ 9.17 gallons pumped three clicks after auto shutoffl!!!!!!
    Obviously, my EV ratio is higher with each tank.
  9. fberger
    fberger Junior Member
    66
    VA USA
    I drove 1039 miles before filling up, and had about 2 gallons of gas left but did not know about it due to the inaccurate gas gauge. I could have added another 50-70 miles, but it is not worth taking a chance and run out of gas on a Prius. I'd rather fill up too soon and not risk damaging the vehicle.
  10. TomE
    TomE Junior Member
    46
    Did my first fill up this morning. It took 8.4 gallons. Odometer at 786 miles, so 93.2 MPG.
  11. iRun26.2
    iRun26.2 Active Member
    819
    167
    United States
    Sort of off-topic, but, were they called '"pip's" before the Plug-in Prius came along? I'm just curious... :)
  12. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I don't know, I just got on the Mitch672's bandwagon: Quote from Mitch672:" 702 miles, however it was not empty, still had 2 pips on the gauge, it was just time, since it was 2 full weeks (used to gas up my 2010 every week), plus I wanted to make my first entry to Fuelly"
  13. o2cool
    o2cool o2cool
    48
    Palo Alto, CA
    Drove 535 miles and still had one bar. It took 8.5 gallons to fill (8.4 when nozzle automatically shut off). This works out to 63 mpg, which is just about what the display said. Since many of the miles were on two medium length trips and most of the other miles were driven by my wife (who could care less about the mpg -- she often got 36 to 38 mpg on our 2005 Prius), then I am quite satisfied with the results. On the new tank, we are more like 80 mpg. It really depends on the length of trip you take. We will not try to maximize the mpg on the PIP. We will try to minimize our total gas used. The 2005 Prius is now with my daughter. Our other car is a Subaru Outback that averages 22-24 mpg. So, our overall strategy means that whoever drives the furthest that day (usually my wife) drives the PIP.
