Prius C Engine = Gen 1 Prius
Discussion in 'Prius c Main Forum' started by X HCH2, May 10, 2012.
  1. X HCH2
    X HCH2 Member
    119
    Upstate SC
    I'm a Prius newbie, but was wondering if the C engine is the same as the 1500 used in the earlier Prius?
    Except for the beltless and other exterior differences.
    X
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Toyota claims 70% of the parts have had some change, but yes, it is the same engine as the Gen 1 and 2 Prius, so it is a well proven, reliable engine.
    Bigboi likes this.
  3. BGGirl
    BGGirl Member
    480
    84
    Kentucky
    I will also be a Prius newbie when my C finally arrives so what is the difference between the Prius Gen 1/2 engine and the Gen III?
  4. usnavystgc
    3,159
    990
    Tucson, AZ
    The Gen I/II (and the "C") use the 1.5 liter Atkinson cycle engine whereas the Gen III uses a 1.8 liter Atkinson cycle engine. Both have proven highly reliable and efficient.
  5. formula
    formula Member
    320
    32
    CA
    great engine. I really love the beltless system.
  6. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
  7. BGGirl
    BGGirl Member
    480
    84
    Kentucky
  8. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Prius c engine compression ratio is the highest so far. It was bumped to 13.4 from 13.0.
    Prius c engine warms up faster as it was designed to be a city car with many short trips. A lot of engineering efforts were put in to achieve 50 MPG in the real-world with a smaller battery pack.
    Bigboi and JimboPalmer like this.
  9. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
    Yes, even with the ICE idling and doing what it does....
    it still uses gas as thrifty as can be....like lawn mower.
    AND you can speed up pretty fast if needed, and barely touts the mpg.
    I tell everyone that nothing runs off the engine.
    The hot rodders and car fanatics say huh? what powers the steering?
    I say electric assisted. Electric steering.
    They say ohhh, haha power steering. I say electric assisted
    Just like my Scion.
    Just that I couldnt prove the Scion...now I can with the C
    I have noticed this between the 3G and C.
    My C warms up and shuts down very shortly after I take off in the morn.
    But I hit stop lights, and then gas it and it kicks on again, but shuts down if I let off the gas.
    My '12 P3 on the other hand, the ICE will run for 3-5 times for a few minutes each. after I start (even in warmer weather)
    Still gets over 50 avg. no issues there!
  10. PeterHaas
    PeterHaas Member
    152
    29
    Monterey Bay, CA
    "Toyota claims 70% of the parts have had some change, but yes, it is the same engine as the Gen 1 and 2 Prius, so it is a well proven, reliable engine."
    The improvements to the 1NZ-FXE engine are quite significant in the Prius c over the Gen 1 and Gen 2 Priuses.
    Even more significant is the Gen 3-type HSD, in which there is a compound gear and a second planetary gear for the MG2, and which allows for a 2.5 times increase in MG2 speed, relative to MG1, and, thereby, the MG2 to be as small in cross-section as the MG1, thereby saving considerable space.
    This update is, at some level, in all 2010 and later Priuses, including the Prius c.
    Also, a change was made in the lubrication system to use ATF-WS.
    The 2016 and later Priuses, but not the Prius c, have a further redesigned HSD (Gen 4), and which further improves the efficiency of the HSD.
    Bigboi likes this.
  11. Bigboi
    Bigboi Member
    136
    26
    Las Vegas
    2015 Prius c
    Correct me if I'm wrong but if the 2015 Prius C has the same engine as the Gen 1 Prius, then... The 2015 Prius C has an engine that was developed approximately 19 years ago? To me, that is kind of a bummer. I was thinking it would be newer and slicker, maybe an engine developed 5 years ago... But oh well. I still love my C no matter how old the engine tech is!
  12. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    If you buy a Lamborghini, the engine was first developed in 1964. A Corvette engine traces its origins to 1955. Toyota still sells cars with the A engine, designed in 1978. The 1.8 liter Prius engine is 10 years old.
    Refinement of a design is not all bad. The Gen 1 had a redline of 4500 RPMs, Gen 2 5000 RPMs, The c has no specified redline but owners have not reported RPMs above 4900.
    priusmagic and Bigboi like this.
