Plugin PIP 2010-2012 Toyota Prius Illuminated Door Sill Protectors
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by khoakhoa, May 10, 2012.
  1. khoakhoa
    khoakhoa Junior Member
    96
    29
    san diego
    Video for Front Install:
    Video for Rear Install of:
  2. mikenewmediary
    100
    24
    Bridgewater, Ma.
    I replaced my sils with the illuminated ones.
    I am not sure why there is a video of the rear sil, as 10 year old can pry them off. :confused:
    A video of the front sil, would of been nice, as there are more panels, and some minor electric modifications.
    I did the sils myself in 90 minutes. I could of went faster, but I really took my time. :D
    Mike
  3. mrbigh
    3,686
    699
    Long Island, NY
    Everybody deserves their few minutes of glory
    and the electrical connections of the illuminated door sills????????????
  4. Jozo
    Jozo PIP PIP HOORAY!
    145
    27
    Sacramento
    It doesn't look like the rear sills are illuminated - just fancy. My dealer told me that only the front sills can be illuminated. Anyone have different info?
  5. mitch672
    mitch672 Technology Geek
    1,077
    198
    Randolph, MA
    That's correct, only the front driver and passenger sides light up, with blue LEDs, I had these on my 2010... Not worth the $, won't be adding these to my 2012 PiP
  6. gbrown
    gbrown New Member
    58
    LA
    they need to make some non lighting up ones but nicer, kind of like the rears. for $80 or so they would sell.
  7. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    Here are some stainless ones for $44..
    Prius door sill scuff plate 4door stainless trim !!! | eBay
    Some light up ones (front and rear) for $48.50 (although not at nice as the OEM ones, but almost at a 1/4 of the price:
    New LED Stainless Door Sill Scuff Plate For Toyota Prius 2009 2010 2011 | eBay
    These also light up, front and back, and look much nicer.. but cost a bit more @ $78
    BULE / RED / WHITE LED door sill scuff plate FOR TOYOTA PRIUS 2010 2011 2012 | eBay
    Only downside is, they all ship from Asia so it takes about 2+ weeks to receive.
  8. mrbigh
    3,686
    699
    Long Island, NY
    Great, nice find !!!!
  9. gbrown
    gbrown New Member
    58
    LA
    great stuff!
  10. gbrown
    gbrown New Member
    58
    LA
    the ebay ones look tape on and not snap in like the oem ones, probably keeps the costs down. still, so long as tape is good probably would be fine.
  11. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    I got the cheap light up ones.. just havent had time to install them. But it does look like the good 3M "style" thin, gray, dense, automotive double sided tape with the red backing. I have a giant roll of 3M VHB if that doesnt work, but I'm not worried about it. Just be sure to clean the area, follow it up with a alcohol wipe down and it should stick well.
  12. maverickf
    maverickf New Member
    113
    Southern California
    Would you show some pictures? I would like to see how they look like. I'm tempted to get a set for mine. :)
  13. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    Yeah, I'll post pics once I have them installed, but I dont think I'll have time this weekend. I should've gotten the $78 ones.. but I've been hanging out in the mods and accessories forum a little too much so I was trying to limit the damage. :D
  14. khoakhoa
    96
    29
    san diego
    Sorry, I got busy and didn't finish the fronts video, it had audio issues my first edit. The rears are not illuminated, there are some different ones that are but oem genuine are not led
  15. khoakhoa
    96
    29
    san diego
    For the interim
    Has no audio and is 2x speed up
    Will update with proper video with audio
    KLD_Prius_PI_Synergy likes this.
  16. khoakhoa
    96
    29
    san diego
    Here is Proper one:
  17. mwiandt
    mwiandt New Member
    Phoenix
    I've seen the official Toyota instructions for tapping in the power for the front sills, but does anyone know if you use the same taps for the rear sills as well or do you need to tie it into the rear door switches with a feed for power? I'm assuming the door switches just go to ground to complete the circuit when the door is open as is usually the Toyota way when I installed an aftermarket alarm in my old Corolla.
  18. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    I just tapped into the front sills for my rears (so front tapped into factory wiring, rears tapped intro fronts). The only issue is, your rear sills will only light up when the front door is open. I suppose if you wanted to do the rears correctly, you should tap into the rear dome light. But it is definitely much easier to just tap into the front sill if you don't mind (like me).
  19. Jozo
    145
    27
    Sacramento
    I didn't realize there were illuminated rear sills. My fronts are lit, ut not my rear sills. I have the Toyota illuminated sills.
  20. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    Some of the aftermarket ones have the rears that light up too. I guess it depends on how often someone sits in the back, but the rears that light up aren't that big of a deal, IMO. So you're not missing much. :)
