Pairing cell phone to prius v
Discussion in 'Prius v Main Forum' started by boggytim, May 14, 2012.
  1. boggytim
    boggytim Junior Member
    Camarillo, CA.
    HAS ANY ONE PAIRED A LG COSMO CELL PHONE TO A PRIUS V? DOES THE ENTUNE WORK ALSO? ON THE TOYOTA CONNECT WEBSITE, IT SEEMS THAT NONE OF THE PHONES HAVE BEEN TESTED. WOULD THE SAME PHONE THAT PAIRED WITH A 2009 PRIUS PAIR WITH THE 2012 V?:confused:
  2. Wanderer
    Wanderer Hybrid neophyte
    366
    39
    Cold country
    I haven't and am not familiar with that phone but I'd say not necessarily. I've seen some say things improved and others they got worse. Your best bet is to either go to a Toyota dealership and try it (and erase afterward) or try it with a friend's v. I don't even know if the radios are identical with the gen 3 hatchback (display audio vs advanced tech).
    If I were you i would go to a dealership and try it for myself and just erase all data on the radio when done testing. W
  3. Keiichi
    Keiichi Active Member
    808
    79
    Goleta
    From the look on the Verizon site, the LG Cosmo is a standard cellphone. Entune was designed for Smartphones, to my recollection.
    From here:
    Entune FAQs- DA - Phone Compatibility
    At best, you can pair it for the phone capability, however, I have a feeling it may not be entune supported.
  4. rcturner
    rcturner Junior Member
    53
    I did a friends non-smart phone to their new V 2. No problem.
