NOOB Question.. Lower Wheel Weight = Worse Fuel Economy ???
Discussion in 'Prius c Accessories and Modifications' started by Melissa5588, May 15, 2012.
  1. Melissa5588
    Melissa5588 New Member
    Tampa Fl
    Hi everyone! I'm Melissa and I have A black C1. Ive had the hardest time deciding between wheels. I'm tempted to get the Enkei PF01 (17inch in matte black) However paired with the lightest tires that I found each wheel would weigh 1.2 lbs heavier than the stock wheel. I got this car for MPG's So the reason i'm hesitant is because I'm scared this is going to hurt my fuel economy. So then I looked at the lighter route. SSR Type F (16inch matte black) I am madly in love with these wheels but the price is a little steep, which I dont mind too much because they are beautiful! But when I was talking to one of my freinds on FB he said this - "actually Toyota has a bulletin for aftermarket wheel. it says lower or higher weight wheels will adversely effet mileage. heavier will rob mileage due to weight and lower weight will also loose miles due to less rotational inertia"
    The SSR's with the Continental tires I was looking at are 4 lbs per wheel lighter..
    Please tell me what you think. Id hate to spend $2,200 on a wheel/tire set up and lose MPG's on top of it! Thanks everyone :)
  2. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I seriously doubt that Toyota would say something that incorrect.
    A lighter tire+wheel combination will improve gas mileage, but by such a small amount that you won't be able to measure it.
    Different tires will most likely change your fuel economy enough that if you are keeping close track you will be able to see a difference. The rolling resistance of you tires greatly evershadows and difference in wheel+tire weight.
  3. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Less weight will result in better mileage. However this may be drowned out if you use wider wheels/tires which will have poorer aerodynamics than thinner wheels/tires.
    There are more complicated issues having to do with weigh at the rim versus weigh at the hub, but a lack of LRR tires and bigger tires blocking more air will be your main issues.
    Now F8L will come by and explain it all better than I can. ;)
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    You know how far you can go on $2,200 in gas?
  5. Melissa5588
    Tampa Fl
    31,777 Miles..
    I got the C1 instead of the C4 so I had some wiggle room for Audio and Wheels. I got the base model and gave my self a budget to play with. thanks for your concern
  6. hnx676
    hnx676 Junior Member
    Singapore
    Nice wheels... My votes go to SSR... Since you are in love with these wheels I would say go for it... just get some LRR tyres to go with them and I think you should be doing fine...
  7. F8L
    19,011
    4,083
    Grass Valley, CA.
    Unfortunately that is not the case. I have tried lightweight 17s as a replacement for my OE 15s and in every test I could conceive I observed a net loss of 4-9mpg depending on the tire choice and driving techniques. LRR tires will not mitigate this loss.
    As already stated by xs650 and Jimbo:
    1. Lighter wheels/tires are good for acceleration and braking but do not contribute much to mpg. The investment on super lightweight wheels will not be returned in fuel savings within the lifetime of the car.
    2. The lightest tires are not neccessarily the best for gas mileage and may not fit your needs based on specific driving conditions. You are better off determining what your needs are then finding a LRR tire that meets those needs. Unfortunately there are not as many choices above 16".
    3. Upsizing your wheels will result in a mpg loss. It is inevitable. No one has found a way to get around the loss. You can, however, reduce the loss by limiting yourself to a Plus 1 upsize (16"), keep the stock offset if possible and use the best LRR tire available which is the Energy Saver A/S or Ecopia EP100. The 16" wheels looks nicer, especially if the spokes extend to the edge of the wheel making the wheel look larger. Handling will also improve. A Plus 2 upsize will drop mpg considerably 4+mpg in my experience with the GenII and what others have also experienced. I was losing around 7mpg with my 17s and the Primacy MXM4 which is a LRR tire. :eek:
    4. Don't go for the hellaflush look. Choose a wheel offset that will reduce the chance of rubbing and keep the wheel/tire tucked in the wheel well and out of the air stream. You will also want to maintain a narrow tire width to reduce friction and aerodynamic penalties for increased frontal area. Lastly face wheel design can affect areodynamics so try to choose one with a smooth face and trasitions. I realize this affects appearance and aerodynamic wheels may not be aesthetically pleasing.
    If you purchased the car for mpg then you really should reconsider this upgrade unless you drive less than 12,000 miles a year. In which case the mpg loss won't add up to much in annual fuel expenditures.
  8. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Now where did that inertia come from, I wonder ?
  9. hnx676
    Singapore
    Well said... Especially point 3... But if I am TS I would still go for it cos life is just too short for letting such a nice set of wheels go... :D I am having 15" and IMHO they are just a bit too small for the look department...
  10. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,519
    Santa Fe, NM
    There is no such bulletin from Toyota regarding wheels. Do as others have suggested: find the best LRR tire, the narrower the better, then get the wheel to match it. You'll spend a lot more time seeing the MPG gauge than the wheels.
  11. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    You are welcome. I totally understand the desire to pimp the ride...
    Daizy likes this.
  12. SageBrush
    11,627
    2,533
    Southwest Colorado
    I understand 'pimping' the interior; after all, the owner sits in it for hours and hours. The money people will spend on wheels has always amazed me.
  13. Melissa5588
    Tampa Fl
    Thanks to everyone who answered my questions most of you were very informative and helped me make my decision.
  14. F8L
    19,011
    4,083
    Grass Valley, CA.
    We expect pictures and a full report after installation. ;)
  15. Melissa5588
    Tampa Fl
    The wheels wont be here until July, but I sure will post pics and let you know how they are!
  16. Absolutly Red Hot
    155
    83
    91
    SoCal
    You own a Prius, you have already beat the general public in mpg. Go for it and get the Bling your heart desires. Make your car a statement of just how cool you are. Stand out and be proud of what you drive. Your the one that has to find it where you parked it last. How cool is it when you experence that "Hey there is my Car" moment. Enjoy
  17. dannahan
    dannahan regular dude
    orange
    so what wheels did you get?
  18. Melissa5588
    Tampa Fl
    The matte black SSR type F 16inch with the 38mm offset. 6.5 inches wide
  19. Surrylic
    Surrylic Junior Member
    122
    Winchester VA
    Wow 4lbs lighter? Good choice tho, I like the look.
  20. GraeSack
    GraeSack New Member
    30
    Lacey, WA
    I'll forward this idea, lighter wheels will see the most MPG benefit when the Prius c is driven mostly in an urban/suburban setting. More acceleration/decelerations with less rotational inertia. Benefit will be lower on the highway. Both driving conditions would benefit from lower unsprung weight. As a relatively light car, a decrease in unsprung weight will always be to your advantage. Try to make every change improve performance.
