Install OEM sunroof on non ATP V?
Discussion in 'Prius v Main Forum' started by 12Priusv5, May 18, 2012.
  1. 12Priusv5
    12Priusv5 New Member
    IL
    Any chance that a dealer or person could order the parts that would be required to convert a V without ATP to having the sunroof?
    Just thinking about it purely from a parts standpoint, the parts have to be there...in case they need to replace it. It'd probably be a list of parts...but once you had that you would just need a little enginuity....right? :D
    If nothing else...just planting a seed. I really wanted the sunroof...just couldn't justify $5K for a sunroof and a bunch of other stuff I didn't want.
  2. Wanderer
    Wanderer Hybrid neophyte
    366
    39
    Cold country
    Same here. I'll be surprised if it's doable but I've been surprised before too. W
  3. David Prius V
    David Prius V Junior Member
    28
    Tampa
    $5000 and it's a sunroof that doesn't open...Were you aware of that?
  4. vlady
    vlady Junior Member
    42
    Issaquah, WA
    There is a white V in my town with regular sunroof, looks exactly the same as on our Sienna. I guess it is available.
  5. OWG
    OWG Junior Member
    86
    Barrie, Canada
    There is a sunroof type raised outline to the roof panel, but to the point of David Prius V, it does not open.
  6. Keiichi
    Keiichi Active Member
    808
    79
    Goleta
    The correct term for what it is, is a Panoramic MOONROOF. It isn't designed to be open, just a glass window to look out from.
  7. Quentin
    Quentin Member
    335
    West Virginia
    My wife wanted the ATP so that the baby would be able to look at the sky through the moonroof. :embarassed:
    My 4Runner's moonroof has spoiled me, though. I can open the moonroof and roll down the tailgate glass and get the perfect amount of air circulation at highway and interstate speeds. It is just enough to keep you comfortable, but not so much or through such a small slot that it is loud. I can easily talk on my bluetooth setup in the 4Runner with the moonroof and tailgate glass open. It's brilliant! If I can't take the rear glass down, I don't open the moonroof. :D
  8. Keiichi
    808
    79
    Goleta
    Well, also, if you look at how the roof and the moonroof design, if it opened, I think you would have some serious problems. Engineering wise, it would not work too well the way they have it. A third party might be able to re-engineer it, but the current design, I wouldn't want it opening.
  9. 12Priusv5
    IL
    Ideally it's a sub-$2k "Panoramic View Moonroof with power sliding sunshades"
    I don't mind it not opening..all the seams create drag plus it'll mess up what little hair I do have left!
    I imagine though that the resin moonroof costs a pretty penny and the rest of the features are tacked on to make it more of a viable option!
  10. blisspacket
    blisspacket Junior Member
    32
    StAugustine FL
    Our v is a nice car; I'd trade up for a moonroof or a sunroof, but won't bite on the ATP package. Toyota could do better. I'll ck for an aftermarket product. Somebody out there has to be alert to this want....
  11. mikefocke
    4,002
    1,807
    Sanford, NC
    I've had 3 or 4 cars that only came with sunroofs and opened them maybe twice for a minute or two in the last 5 years. Loved my Porsche convertible and had the top down 90% of the time but I never saw the point of the sunroof. Takes away from the headroom and can't do much for you in a the rollover.
