Finally, a high quality primer for mainting custom made bare aluminum parts.
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Mike500, May 20, 2012.
  1. Mike500
    Mike500 Senior Member
    2,593
    766
    For years, I have struggled with the yellow and green "zinc chromate" primers that the Ford Motor Comany developed for painting aluminum aircraft in the 1920's.
    I painted some of my aluminum specially made custom chassis bars and braces with zinc chromate, which is "strictly" controlled and not very available in many markets, since "chromate" is a carcinogen.
    Finally, I looked around extensively for several months for a subsitute. Eureka! I have found it.
    It's called Rust-Oleum Auto Primeer Self Etchng.
    It can be had at Walmart (in the Automotive section, if you can find it.
    About a buck and a half, more, it is readily available at all Home Depots;
    Autorf Sspr Auto Prime Self Etchng-249322 at The Home Depot
    The stuff lays down well to a smooth flat finish, and is desighed to take high quality automotive or other paint.
    It is a dark gray, when dry. It's really high quality stuff.
    Now, you can have the "custom made" chassis braces in the color you really want.
  2. xliderider
    xliderider Senior Member
    8,056
    3,222
    Honolulu, HI
    Hmm, any comment or ideas about this comment left on the Home Depot link you provided?
    " It does not stay on and after allowing the suggested dry time, it can be wiped off with a wet paper towel. We waited an additional twenty-four hours and it is the same. It is powdery and comes out of the can spotty."
    Are there any surface prep steps the user might have missed? Thanks.
  3. Mike500
    2,593
    766
    The guy making the comment sure dooesn't understand painting aluminum. Surface prep is everything. You need to sand it to a rough surface with 180 wet or dry sandpaper, not steel wool.
    Then, again, he might have tried to paint "anodized" aluminum; a "no go" from the start.
    After sanding, I wash it off with a degreaser or "Dawn" dishwashing liquid, dry and paint.
    Hope this helps,
    Mike
  4. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Anybody can paint, even elephants!
    The trick is getting the paint to properly adhere to surface to being painted!
    Proper prep work is 99% of the process.
    It's a must, otherwise why waste your time! :eek:
  5. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    That's why I love my powder coater. Plus, he's only a few minutes from the house.
