Interest in group buy for no-holes parking sensor
Discussion in 'Gen 3 Prius Accessories and Modifications' started by AZGeek, May 15, 2012.
  1. GCPExit12
    GCPExit12 Member
    105
    33
    Since these sensors are (hopefully) only going to be used at low speeds, it may be possible to tap into the VPNS circuitry that activates only below 15MPH? For instance run a relay to the speaker that makes the wierd noise that nobody ever hears anyway
    peterjmc and Tracksyde like this.
  2. idesi1
    idesi1 Junior Member
    55
    Houston
    I will be surely in the next group buy, but will have to wait until someone post a DIY and they success story..
    will wait n watch ... all the best guys
  3. AZGeek
    AZGeek Semi-informed Member
    627
    144
    63
    Arizona
    :cool: Thanks. That makes sense.
  4. peterjmc
    917
    189
    Clarksburg, MD
    How does one look into setting something like this up? I have no electrical engineering experience or background so I hope someone can look into this.
  5. Jordan M.
    Jordan M. Jamman85
    Really excited to hear more about this and very interested in doing a second group buy if it works out well!
  6. AZGeek
    627
    144
    63
    Arizona
    That's a pretty cool suggestion. The only downside I can think of is that the noise maker only comes on once you get moving a bit. I had noticed that if I went really slow, i.e., lining up my laser guide dot for parking in the garage, the noisemaker would go silent.
    new iPad ?
  7. peterjmc
    917
    189
    Clarksburg, MD
    So VPNS is the nosie maker? That wouldn't work for me.
    I suppose it would be difficult to tap into the radio circuitry which locks out selected input after you exceed 4mph? I would assume that would be a software control and not an electrical signal.
  8. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    692
    151
    Seattle, WA
    I just got my kit today. Here's a picture of the contents: IMG_0324.jpg
    The control box is smaller than I expected. The wire bundle with the yellow rubber band is for the speaker. The line running between the antenna tape and the control box is about six feet long. Not shown is a small push-button. The item at the upper left is a strip of "dum dum", bits of which are used to stick components to body panels.
    Next, figuring out the install . . .
  9. RiverRat
    RiverRat Junior Member
    24
    Huntington Beach CA
    I've got 95% of the kit installed.
    1. Ran the antenna in the lower part of the dam.
    2. Ran the antenna wire into the cabin through the grommet that is behind and to the left of the master brake.
    3. Bolted the ECU unit onto the black plastic cover under the steering wheel, that covers OBD port.
    4. Glued the Speaker under the switches to left of steering wheel.
    What I'm having trouble finding is a 12v source for the ecu unit. I been poking my meter around but still I've had no luck.. My car is an 2012 PIP. Anyone have a wire diagram that could help?
    I took some photo's during my install and will post shortly.
    Tracksyde likes this.
  10. Dark_matter_doesn't
    692
    151
    Seattle, WA
    Did you have to take off the wiper tray to get access to the grommet? I believe I had to when I did my fog lights.
    For power, I'd look at the threads here on the fog lights, and/or the turn-signal mirror installs. There's also a downloadable service manual either here or in the Maintenance thread.
  11. RiverRat
    24
    Huntington Beach CA
    The grommet has a Nub on the left side that is blocked. I was able to reach through and with just feel...cut off the nub. I used a very small pair of dykes. On the inside there is a hole that matches it. So to answer your questions didn't remove anything.
    Thanks for the tip on checking out the fog lights area....
  12. Judgeless
    Judgeless Senior Member
    1,821
    257
    Cleveland, OH
    This might help. The red wire is constant power the blue is accessory power.
    Did you have to take your bumper off the front or back?
  13. RiverRat
    24
    Huntington Beach CA
    This is great help. I installed in the front bumper. Just removed lower plastic cover.... Going right now to finish.
  14. Dark_matter_doesn't
    692
    151
    Seattle, WA
    I already used the nub for my fog lights. I'll have to make a new cut, but the rubber is thick as I recall.
    BTW, I don't think hooking up to constant power is a good idea. Better to hook up to power that's only hot when the ignition is on. The accessory power line is probably a better idea.
  15. AZGeek
    627
    144
    63
    Arizona
    Just received my kit in the mail on Saturday. I may try to install next weekend depending on how successful I am with some other "honey do's"...:)
    Looking forward to following those of you who have already done the install. Thanks very much for posting pics.
  16. peterjmc
    917
    189
    Clarksburg, MD
    I'm hoping my kit comes in this week ready for install this weekend! For fathers day I asked for time to work on my car. No honey dos....
    I have more than a handful of things to do to my car this weekend. Can't wait!
    GoldPianoGarden likes this.
  17. Dark_matter_doesn't
    692
    151
    Seattle, WA
    I finished my install today. The good news is that it does work, sensing and alarming when an object is about two inches from the front lip. I ran the antenna right behind the edge of the front lip, all the way across from just below the fog lights. I mounted the control module on the panel under the dash below the steering wheel, on the back edge. I won't kick it accidentally when I hit the brake pedal:
    I got the antenna cable thru the rubber plug by punching a hole thru with a narrow wood chisel, then I used a straightened wire coat hanger as a fish-tape, pushing it thru the rubber into the engine compartment. I taped the antenna wire onto the end (butted to the end of the coat hangar), greased it up and pulled it back thru. It just barely reaches the control box with little slack.
    I put the on/off switch on the panel with the button on the bottom so that I can turn it on and off, but it's awkward. I was hoping that the system would work as advertised, but . . .
    The unfortunate news is that at the lowest sensitivity setting, I'm getting occasional false alarms while I drive, when I'm braking, going downhill (?) and over uneven surfaces. It goes off at driveways into parking lots and when exiting parking lots. It also doesn't provide a series of beeps as I approach an obstacle, only a solid tone when the object is a couple of inches away. I'll probably have to leave it off unless I'm approaching some parking lot barrier or wall.
    I've got an e-mail into the Proxel contact to see if anything can be done at this point.
  18. AZGeek
    627
    144
    63
    Arizona
    That is a bit disappointing that it is still so sensitive. One would think that, if it alarms at 2 inches from a curb, it wouldn't be sending out alarms for other things further away from the dam. Let us know what you find out from Proxel.
  19. peterjmc
    917
    189
    Clarksburg, MD
  20. RiverRat
    24
    Huntington Beach CA
    I"m also getting the same type of false alarms.
