Speaker Upgrades, any suggestions??
Discussion in 'Gen 3 Prius Audio and Electronics' started by clokwise, Jun 13, 2012.
  1. clokwise
    clokwise Member
    114
    Nashville
    I am looking and considering a 2010 3 without the JBL sound system. It has most everything else I need/want other than the upgraded stereo. Does anyone have any suggestions for changing out the stock speakers? How hard is it to do? I just want a good balanced, quality sound. Not really looking for slamming bass or anything just a good quality sound. Thoughts??
  2. tach18k
    tach18k Member
    406
    SoCal Beach Area
    There is tons of info and photos of change outs, look at te stickys at the top of this section.
  3. drew935
    drew935 Member
    168
    Nor Cal
  4. frodoz737
    frodoz737 Top Wrench
    4,694
    2,496
    33
    Lot of info here, but can you clarify? The 2010 Prius 3 only came equipped with the JBL, Navigation was the upgrade. Did you mean 2010 Prius 2?
  5. drew935
    drew935 Member
    168
    Nor Cal
    Frodoz, I'm guessing that it's a package 2 on a gen 3.
  6. frodoz737
    4,694
    2,496
    33
    If this is true "clokwise", your speaker only upgrade will be easy. Many albums, posts and of course Spidermans sticky to help you. Basics would be coax in rear, 2 or 3 piece components in the front with cross-overs easily mounted under the front kick or door panels. System in my Album is more than you want, but have good pics like drew935 to give some ideas. See factory info below as it applies to the 2010 Prius II Base System to assist. Good luck and ask questions. There are some good folks here.
    http://priuschat.com/attachments/img015-pdf.26082/
