How to include pictures
Discussion in 'PriusChat Website Questions' started by nerfer, Mar 20, 2008.
  1. gabrie
    gabrie New Member
    new york
    I do not think you can upload more pictures after reaching the limit, but this is more a question for Danny. I am also looking for ways to reuse an attachment that you have uploaded, but you can not make it through the window of the attack is. Once it's there, that is. (But you may find the attachment in previous post, how to use the method of 'image' link to its URL (bringing the tip called the 'Insert Image')).
    Unless you are a heavy user of the picture, when they reached the limit (if any) of disk space would be cheaper and the limit will be raised. :cheer2:
  2. daniel
    14,487
    1,519
    Spokane, WA
    True. At that point you have to delete some of your old attachments. I've had to do that a few times in the 8 years I've been on Prius Chat. (Since I'm too lazy to sign up for and use a picture hosting site.)
    ETP likes this.
  3. hsnyder
    hsnyder Junior Member
    44
    Have searched and can't find answer to this question, but I'm trying to some embed pics from Picasa web albums and can't seem to get them to show inline in the post.
    Anyone know how to do this?
    Possible, even?
    Thanks!
  4. Danny
    Danny Admin/Founder
    7,093
    2,117
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    You have to right click on the Picasa photo and select "Copy Image URL", then click the button in the editor that looks like a photo of a tree. Paste the url of the photo, click "Insert" and you're done.
    The code should look like this:
    Code:
    [IMG]https://lh5.googleusercontent.com/-vtVQgZBEeM0/SXZLj36kADI/AAAAAAAACps/NwRPiKswtF8/s816/DSC_1094.JPG[/IMG]
    And the final product like this:
  5. hsnyder
    44
    Danny - Awsome. Thank you. Let's see:
    Et voila!
    Thanks!
    ETP likes this.
  6. bwilson4web
    15,989
    Curious image rotation:
    If you open the image in a separate browser window, it is oriented properly. I also tried the "rotate" buttons to no effect.
    As background, I stitched two images together in OpenOffice but to make the text readable, I rotated them before stitching them together using a screen-shot program. Then I rotated the image 90 degrees before saving it as a file. I also used iPhoto to make sure it is rotated.
    I can not rule out some 'meta data' still in the image. Just not having a lot of luck.
  7. JimLudden
    JimLudden Member
    83
    31
    Taos, NM
    2024 Prius Prime
    I do not see the paper-clip icon on the editor toolbar. I do see an image icon, but it only allows a reference to a URL.
    Could this be due to the new server? (Seems unlikely.)
  8. Tideland Prius
    16,433
    It appears related to the new server. I haven’t heard anything back from Danny when I asked for an update.
