substantiated rumors of gen 4 production
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by austingreen, May 1, 2012.
  1. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    Lots of PR... Companies never slow down, if you slow down, you are overtaken. But they gave more quality review time for new products coming to the market. You can see it on all of their new cars.
    Toyota is the largest manufacturer in the world, with highest spending in R&D and they have to push out most models...
  2. spwolf
    3,156
    440
    Eastern Europe
    they started 3rd shift last month and voila - Corolla best selling compact on the market, as I told austin it will be once its availability improves :)
  3. austingreen
    austingreen Senior Member
    13,690
    4,224
    Austin, TX, USA
    I said I doubt they would want to buy from ford. For the prius they brought it in house from aisin. With Ford building in house, I can not see why toyota would pay aisin to build a plant only for them for psd. Denso doesn't and never has made these components. They are not heavy, which means shipping costs are not high.
    This "balabering" as you call it came from the toyoda family originally, as you might know if you actually read my post. I was pointing out what they and financial analysts considered mistakes for electric me. No one in toyota management ever mentioned the plan to build prii in North America as a mistake.
    As to NUMMI I was not assigning blame. It is what it is. With NUMMI at under capacity there was no reason to build blue water or san antonio. The plant had problems even before Toyota became involved. After paying for construction in Mississippi and Texas they needed to reduce capacity somewhere. They decided to cut their most expensive plant, firing workers and angering the union. Having an empty plant that the taxpayers in Mississippi helped pay for wasn't making them happy either. It was the right business decision, but the wantanabe rapid expansion was not. Toyoda apologized for the closing of the NUMMI plant and blamed it on Toyota over expanding.
  4. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I agree.
    But Toyota themselves- "Akio Toyoda"- cited rapid expansion in a push to become the world largest auto manufacturer as a potential reason for some of the problems they faced.
    To me? If you look back over the 70's, 80's even early 90's...The Japanese automakers did something slightly different than American Automakers at that time.
    American automakers usually significantly changed or updated their vehicles every few years. In the late 60's early 70's...a span of 3 years, could mean a huge difference between a vehicle with the same name...it was rapid change.
    Japanese automakers through the same period were much more conservative. Change in a model line came much slower. And if it worked? They kept it.
    I think that's what eventually led to the success and reputation for long term quality that helped Toyota and Honda rise to great heights.
    My fear or concern, is that now ontop, is Toyota becoming the very animal that it once hunted, with the same strengths...but also the same weaknesses?
  5. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Maybe 'quality in quantity' would be more accurate. :)
  6. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Quite true, but you have to put his comments in cultural and corporate context. Toyoda e.g. apologized to the US congress for problems with Prius brakes, even though he knew, we (Prius owners) knew, and later everybody else nothing was wrong with them. Most americans cannot parse Toyota 'speak, in which customer dissatisfaction *is* a problem Toyota takes ownership of, even if the problem is the consumer ignorance or FUD.
    Quality decreased at Toyota for a while. They went from being the perennial Yankees of baseball to just another play-off team. Meanwhile Ford won the minors, and GM continues to be my local Albuquerque team, toiling in quality obscurity.
  7. lamebums
    lamebums Member
    101
    30
    Southern Ohio
    Hi all--
    As a heads up, I may be opening up a big can of worms here.
    I'm leery of buying any vehicle, regardless of what make or model is, if the VIN number begins with "1".
    I don't know the cause, rhyme, or reason (and I'm not going to level any accusations because I'd be hitting a hornet's nest), but it seems that vehicles made here in the States are much more likely to be... rubbish. It runs across brand names and lines. I had the misfortune of driving an '05 Cavalier a while back and it was probably the worst car I've driven in my entire life. (It was made at the Lordstown assembly plant in Ohio.)
    A quick scan of Car Complaints reveals a truly outsized number of complaints for supposedly-"reliable" Japanese cars just because they had the brand name. But look at the 2001-present Honda Accord, which is filled with transmission and brakes horror stories. (1,192 brakes stories from the 2008 Accord alone). Scores of transmission failure stories out there, as well. Where's the Accord made, at least the North American version? Marysville, Ohio.
    Or the 2007 Camry's burning excessive amounts of oil. Complaints continue about poor paint jobs, etc. Where's the Camry made? Georgetown, Kentucky.
    The Prius, on the other hand, has a tiny fraction of the number of complaints and issues. Of the 2005-2009 Prius, I'd wager that 70% of the complaints on that website are HID-related. (God, I'm glad mine doesn't have HID's.) Tell me again where the Prius is built.
    Same thing with the Yaris, which has comparatively superior reliability to the Corolla/Camry even after accounting for lower sales during those model years.
    Maybe I'm cherrypicking, but I can pick some more examples.
    From time to time you'll see a late 80's/early 90's model Geo Metro puttering around on its' three-cylinder engine. That's because a Metro is actually a rebadged Suzuki. When's the last time you saw a Chevy Corsica (circa 1994) in running condition?
    Point is, I - given my experience with both types of cars, and having watched so many friends and associates be stuck with car-repair hell - would be extremely leery of buying any vehicle made here in the States.
  8. Trollbait
    12,612
    If the transmissions hadn't been US made since 1997, there might have been something there with it being an American made problem. Civic Si's have also had problems, and their tranny can be coming from Indonesia or even Japan. Honda deciding a transmission designed for the power of a 4 cylinder would be fine behind a more powerful is just as likely a cause for the problems.
    If one took the time to dig through the gen2 threads, you would find numerous complaints and TSBs. Mine had the loose trim piece on the exterior door B pillar, that was threatening to blow off. I think the little PSD cover (IIRC,been awhile) was also on backwards. Luckily for me, the nearby wire harness was lying away from it, but it did get cut through by the cover piece on other cars.
    If there are problems at a factory, it is corporate's responsibility to fix it. It's their name on the product, and they should of done a better job of instilling their priorities to quality.
  9. austingreen
    13,690
    4,224
    Austin, TX, USA
    I've been in plants in the US and Japan and even malaysia and thailand. I can tell you with the same equiptment and training the quality really does not very much. I have also been in plants that don't invest in their employees or process, and quality falls.
    I can see how the NUMMI plant might score lower for quality than a lexus plant, union work rules sometimes can interfere with process. Management was mixed and not trained in the same way. This is quite different than what we would expect in a prius built in blue water, mississippi versus one in japan. They should have similar equipment and work rules, and time for training. In the honda example, this was a design problem not a worker problem.
    Toyoda in his apology said that the company grew too fast to train new workers. They also have been accused of ignoring quality problems to increase production rates. None of these things should impact a US made Prius.
  10. chughes123
    chughes123 Junior Member
    66
    vancouver washington
    HCCI if they can do it reliably, or an optimized Atkinson with a longer stroke but narrow tubes, direct injection instead of Multiport Fuel Injection, perhaps turbocharging.
    I'd say 60MPG highway is the high point every possible on a piston type engine. At that efficiency you're at the efficiency of a diesel.
    Carnot cycle after that?
    Hopefully in 2015 they'll have a plug-in version of the V and C and a bit longer range for the V and regular, a J1772 plug for quick charging on long road trips.
  11. ProximalSuns
    ProximalSuns Senior Member
    1,877
    PNW
    Just current Prius with 10 mile EV capability without plug in, more efficient and powerful batteries would get them to 60-70 mpg. That's three years from now.
  12. chughes123
    66
    But the engine will need to run the generator to charge the battery eventually. I don't think it would help the hwy or city EPA cycle much. I know the current Prius can do maybe a mile on EV mode and longer would be better. Bigger batteries are definitely helpful if going down a mountain for regen.
  13. ProximalSuns
    1,877
    PNW
    More efficient batteries not bigger physically. They waste less of the input so receive and store more electricity with same engine input. 10 miles on pure EV without plug-in and we get 70-80 mpg for the average commuter.
  14. spwolf
    3,156
    440
    Eastern Europe
    how do you get 10 miles of EV without plugin?
  15. ProximalSuns
    1,877
    PNW
    4th generation batteries that more efficiently take a charge and more efficiently hold and deliver more energy.
