suspension upgrade (chassis braces and bars - NOT springs or shocks)
Discussion in 'Gen 3 Prius Main Forum' started by jbpersmail, Jun 17, 2012.
  1. jbpersmail
    jbpersmail Junior Member
    47
    For those of u who have installed any of the following:
    - struct tower brace
    - struct bar
    - point under brace
    - front sway bar
    - rear sway bar
    - front chassis brace
    - center chassis brace
    questions:
    1. do u feel like any of these helped and in what way do they help?
    2. if i want to install 1 of the above, to be the most bam for the buck and to determine if i should install more, which one do u think i should get?
    3. will installing these void warrenty?
    4. will installing these affect safety?
  2. xliderider
    xliderider Senior Member
    8,055
    3,222
    Honolulu, HI
    None of them will affect the warranty. Toyota would have to prove that an aftermarket part caused something else to fail before they can deny warranty work.
  3. BreitrthnU
    BreitrthnU Can you smell the premix?
    255
    Tampa, FL
    The plus rear sway helped the rear hook for me better in the turns, almost like you can feel a grab point. I used Irv front and middle chassis bars together. That made the body feel as one and roll as one if you had it installed you would know the feeling. Very satisfied with my suspension upgrades the tein htech made it all come together. Lastly i have a tanabe front sway bar thats going in and im hoping that will give me the handling I want.
