Ready to upgrade all 4 speakers
Discussion in 'Gen 3 Prius Audio and Electronics' started by kknguyen1168, Jun 15, 2012.
  1. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    hi all
    I am ready to upgrade all 4 speakers this weekend, do I need to Disconnect the Negative from Battery before I open door panel and disconnect speaker wire from speaker?
    V/r
    Khoi Nguyen
  2. DecimationX
    DecimationX Junior Member
    26
    Winston-Salem, NC
    In an unprofessional opinion....If you have to ask if you need to disconnect something to disconnect another thing or connect another thing....you probably need a pro to do it.
    However if you are stuck on DIY then I would say yes....no use in shocking yourself or causing electircal damage to something you aren't sure about
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    All 4 speakers? You have at least six if not eight (JBL).
  4. Rebound
    Rebound Senior Member
    3,996
    2,643
    Portland, OR
    The speaker disconnection itself doesn't use 12V, but since you may encounter the door locks and power windows in removing the door panels, battery disconnection is always a good precaution.
    When you re-connect the battery, you may get a "Hybrid System Error" message. And you'll completely freak. Just power the car off and on three times, and the message will clear.
  5. has been
    has been vote for anyone except Trump
    254
    46
    pacific n'west
    Khoi - you have at least 6 speakers
  6. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    hi
    I know I had 6 six speaker, but I will change only 4 speakers in the doors, the one in the dashboard will not be change, and I will not upgrade anything else at all, but for the future I would like to upgrade the AMP, but must be plug and play, hopefully they will make one soon.
    V/r
    Khoi Nguyen
  7. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    There's no reason to disconnect the battery. Not even if you're installing a new head unit... I think Spiderman has a good writeup on the install.
  8. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    If there was just one thing I could do to upgrade the 10's sound,,, it would be to replace the dash squakers. That made a huge impact in my ears.
  9. has been
    254
    46
    pacific n'west
    Just 4 of the 6, got it. Not a bad plan actually.
    Have you considered a digital processor or one of the items in the "factory sysytems upgrade" section at Crutchfiled?
    Was looking around there a bit and it seems that with all of the new factory head units with big displays and steering wheel controls these baby's really make sense for the DIY person.
    All the controls seem to remain but results in better sound.
    If the speakers are relatively close to original size (physically) it should be pretty easy.
    Good luck and please post your results.
  10. Delux
    Delux Junior Member
    Westminster, Ca
    Are the Crutchfield specs/recommendations pretty accurate? After reading on here it appears that its not all to easy to just buy some speakers and install them, im not sure if I should believe their site or not
  11. has been
    254
    46
    pacific n'west
    Crutchfield is a good place to deal with.
    The speaker info that they have is probably stock info from Toyota.
    All of there speakers do show dimensional specs from the manufacturer.
    Their information has only gotten more detailed over the years and in general the customer service is excellant. Email them.
    Ask them questions.
    That's what they are there for.
    Get a dialog going with someone there until you find out what you need to know.
  12. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    spiderman
    did you replace the dash spuakers?, if you did, did you make a lot modify for dash squakers? believe me I would like to upgrade a lot things for my Prius III 2010, but one thing that I would like to have is plug and play, because this car is mostly is electric, messing around too much, and you know what:)).
    V/r
    Khoi Nguyen
  13. Delux
    Delux Junior Member
    Westminster, Ca
    Would a set of component speakers work to replace the factory squakers?
  14. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Why yes I did, follow the A/V upgrade link in my signature. There is a link in the first post of the thread that covers the squakers replacement (document). It wasn't too bad in terms of work. Just a little trimming of the inside dash and a minor wiring task. Easy to moderate modification.
    [edit] well the document link was funky since the site upgrade so here is the link to the document.
  15. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    Delux
    I do not understand your question?
    While we are in this subject, I would like to ask everybody out there know there is the plug and play replacement for JBL amp. ? if there is then that my next project:)
    V/r
    Khoi Nguyen
  16. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Well sure, in fact there have been a few members that have done so. One member replaced the squaker with a tweeter component.
    I used a two-way coaxial 3.5" pioneer and I really like them. Puts the sound stage more in your face instead of at your knees (and muffled).
  17. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Just noticed that you have model III w/JBL... that makes things a little more interesting. The squakers in your model (2 ohms I believe) are different from mine (4 ohms). You need to make sure to get the proper speakers. There are other members that have upgraded the JBL system. If I come across those threads I will post em.
  18. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    Spiderman,
    Thanks, I really want to know if there is a direct replacement for squakers and Jbl amp., for the door speaker I replace them with 9632cf and 6032si from Infiniti.
    V/r
    Khoi Nguyen
  19. Delux
    Delux Junior Member
    Westminster, Ca
    keep me posted on if you change out your stuff, i may take your factory JBL off your hands
    Dumb question, but what is the difference between a squawker and a tweeter? I just assumed they were the same till now. I went and reviewed the pdf's you posted on the change out, damn good job. It will be a great help when I get ll the equipment. Can you share any info on your sub & amp set up? I am debating on changing speakers or just installed a sub......
  20. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    all
    I just call Tommy this afternoon to make appointment for install all 4 speakers and put all Sound deaden in all for 4 doors, he said will cost me 300 dollars for labor, I almost fell of my chair:) :(, why the hell cost so much to do that, I will find someone close by in San diego to do that, drive about 1 1/2 hours and 300 dollars for labor to do that, if I can not find someone cheaper then I will put this project on hold until after July 4, that when I be back from my vacation then I will do it myself, hope that I will not mess thing up :)
    V/r
    Khoi nguyen
