Failed Cruise Control install
Discussion in 'Gen 2 Prius Accessories & Modifications' started by LostBoyNZ, Jun 26, 2012.
  1. LostBoyNZ
    LostBoyNZ New Member
    I bought a Cruise Control unit for my Japanese import 2006 Prius, and got a Toyota dealer here to install it (even though it sounds easy-ish to do, I wouldn't trust myself to do that, haha). They plugged it in to the socket on the side of the steering wheel, but nothing happens when you press the buttons or such.
    They plugged the switch into their tester unit, and its working fine. It delivers the right instructions through the cable. But nothing happens when it's in my car.
    They said there's no marker on the dashboard for it either, so they didn't see how it was going to work in the first place. What they wrote on the paper was "suspect because the vehicle ECU doesn't have provision."
    I wonder, did I miss something? Or maybe it's not a mod possible on Japanese Prius?
    I asked them to leave the switch in there for now, as it would cost more to have them remove it again. Thankfully they only charged $30 for putting it in and trying it.
  2. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    Yes, you did not replace the Stop Light Switch, part# 8434020060. The Stop Light Switch for car without CC is SPST (Single Pole, Single Throw) switch whereas those fitted with CC is a DPST (Double Pole, Single Throw) switch.
    How to install a Cruise Control switch in 2004 Prius? | PriusChat
    You can follow the SSC to install it yourself or ask your dealer to install it for you.
    Vincent
  3. LostBoyNZ
    Thanks!
    I don't have the stop light switch (8434020060) or the steering wheel right lower cover (4518647010C0). This is what I purchased:
    2006 Toyota Prius Cruise Control Switch 18A174 OEM 04 05 06 07 08 09 | eBay
    I take it that includes the cable to connect the switch (8463348020) but thought I better double check :p
    Most of the instructions there look easy enough, but I don't have anything to measure torque and measuring a distance of between 0.5 and 2.4mm in such a space sounds like it'd be tricky. But is getting the torque right vital?
    Thanks again for your help :)
  4. vincent1449p
    894
    332
    Singapore
    I guess the cable did come with the switch. Otherwise, how did your dealer connect it to your car and their test car?
    Both the torque and clearance are important. I have not tried it myself but others find it difficult to access the lock nut in the confine space. My advice is to let your dealer do it since this would be a safety issue if not done correctly.
    Vincent
  5. LostBoyNZ
    Agreed, I'll ask the dealer to install it. Better than risking it.
    Thanks, I'll place an order for those parts now.
