Prius won't start even when jumped
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tinmanchris, Jun 25, 2012.
  1. tinmanchris
    tinmanchris New Member
    2001 Prius
    Hey guys, just wanted to say sorry for posting here as I was unable to find the GEN I forums.. I'm hoping someone here would have some knowledge on my situation.
    I have a 2001 Prius that has been sitting outside for two months as I've been away on business. When I tried starting it yesterday it was dead as expected so I got my other car and hooked up the jumper cables to the 12V battery located in the truck of the Prius. After 15 minutes of charging I tried starting it up and it didn't even try to turn. I gave it even more time and still nothing.
    What is really throwing me off is that none of the electrical components turn on or work (door locks, windows, etc) except for the daylight running lights and turn signals (both are stuck on). Computer screen doesn't light up, dash doesn't light up, everything seems dead.
    Does this mean the 12V battery is dead or that I have a bigger issue? I was expecting the jump to at least get the car started... Thanks!
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    It may be an issue with your 12V battery. Do you have another battery that you can put in its place to try?
  3. tinmanchris
    2001 Prius
    Can any 12V battery work or do I have to use one specifically for the Prius? What mainly threw me off was even with the jumper cable connected to the other car I was unable to use any of the electronic components.
  4. jdcollins5
    5,131
    1,346
    Wilmington, NC
    Yes any 12V battery will do for a temporary check. Be sure you have the polarity of the jumper cables correct or you could do some damage to the very expensive electronic components.
  5. tinmanchris
    2001 Prius
    Good to know. I will work on this tonight and see what happens. Hopefully it's just the battery... :p
  6. tinmanchris
    2001 Prius
    So turns out the 100A fuse was blown and I got a new one but it was way too tough to remove the fusebox so I decided to get it towed to the closest dealership. They replaced the 100Amp fuse and said that I most likely reversed the polarity while jumping the car. I know for a fact that I didn't do that as I researched on jumping the Prius prior to the jump and read a lot of horror stories if you reversed the polarity. Long story short the car still won't start even with the replaced fuse, they are now saying I need to replace the 12V battery as it no longer holds a charge.
    I thought the 12V battery isn't responsible for cranking the car? So what does replacing the 12V battery fix? Also can't I try trickle charging the battery before paying $200+ to replace it?
  7. Rokeby
    Rokeby Member
    3,033
    710
    75
    Ballamer, Merlin
    1. You are correct. So far, so good.
    2. The 12v battery is an essential element in getting the car started.
    The 12V battery is used to boot the various ECUs and computers in the car.
    After some initial and near instantaneous system and safety checks, the car
    uses the 12V battery to power the relays that bring the HV battery on line.
    Power from the HV battery is used to power one of the two Motor/Generators
    to spin up the ICE -- no real "cranking" involved.
    3. Sure. But this time do a better job of getting the + and - leads properly
    hooked up. FWIW, newer "battery minders," "trickle chargers" have circuitry
    that prevent activation if the +/- leads are hooked up backwards.
    Good luck.
  8. tinmanchris
    2001 Prius
    Thanks for that info Rokeyby. Right now they have charged me $410 to change the 100Amp fuse and after calling around the other dealership I found that I have been taken advantage of. First dealership said it would cost $20 for the labor, the other one said they would do it for free. /sigh... so stressed... at least the battery charge of $200 is reasonable but I'm probably going to ask for my original battery back so I can try trickle charging it first.
  9. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    At least you now know where to take your car next time!!! H:)
  10. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    Yep. I think the OP did reverse the polarity, despite the denial.
