2010-2012 Prius major design flaw !
Discussion in 'Gen 3 Prius Main Forum' started by civicdriver06, Jun 28, 2012.
  1. civicdriver06
    civicdriver06 Active Member
    797
    324
    Germany
    I have finally purchased a 2012 european Prius and i absolutly love this car exept for a major design flaw it has .
    Every time i drive in rain or on wet streets the doorsills get messed up !
    I just can´t believe that Toyota didn´t notice this on several testdrives before bringing the car to market .
    I never ever had this in any car i drove before !
    I own a blizzard pearl and it´s very annoying !
    Has anybody found a solution for the problem ?
    Bgmacon likes this.
  2. F8L
    19,011
    4,083
    Grass Valley, CA.
    Additional weather stripping along the door channels? Another member did this to reduce wind noise. I noticed it too and it is very annoying.
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Our 97 Camry did the same thing... in fact all my Toyota's have.
  4. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    I've noticed it on my BP Five too.... annoying? Yes. Major design flaw? Hardly.
    Big Steve, xpcman and F8L like this.
  5. WE0H
    WE0H Senior Member
    3,247
    528
    Anyone got a picture to show what your talking about? I don't drive my car in the rain but my wife will be driving her's next season rain or shine. If there is a mod to do I would like to see what needs fixing :)
    tnx,
    Mike [​IMG]
  6. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    Yep, same here. 99 Camry, 2010 Camry, and 2011 Prius all get dirty door sills after driving in the rain. Our 98 Nissan Pathfinder and 2004 Quest also had this problem.
  7. RRxing
    RRxing Senior Member
    2,545
    1,821
    NEPA
    Dirty door sills? Oh, the humanity!
    Codyroo and Silver bullit like this.
  8. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    How! terrible! for! OP!
    kc5dlo and Teacake like this.
  9. yeldogt
    yeldogt Active Member
    810
    313
    NE
    Some cars do this better than other by having two weather strips -- this keeps the inner ring around the door clean so you don't get dirty when you enter/exit. Years ago this was less of an issue because the doors were larger and the sill was higher and smaller. With the lower rail on some many cars growing they should have a second seal.
  10. xliderider
    8,140
    3,276
    Honolulu, HI
    There are drain holes on the bottom of the doors to drain away water that runs down the windows and gets by the "felt" seal at the top edge of the door. If there are seals down at the bottom of the door, the water will get trapped there and not drain out.
    Jason dinAlt likes this.
  11. TWong1200
    TWong1200 Junior Member
    26
    Corona, CA
    Yeah, I'd like to know too. Unsure what's being described here.
  12. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Pic attached. This is really clean for mine, but you get the idea. 20120629_061754.jpg
  13. katiesdad7
    katiesdad7 Member
    172
    25
    Stuart, FL
    That's nothing compared to the dirty floor mat. :)
    Braddles.au likes this.
  14. The Broz
    The Broz Junior Member
    30
    So is the complaint that rain causes that area to get dirty? If so, my 2000 Camry has this as well - I guess I kind of thought that all cars did. If that is the issue, take a wet rag to it and get over it. Chalk it up to stuff getting dirty sometimes.
  15. xliderider
    8,140
    3,276
    Honolulu, HI
    I know right? A lot of cheese could be served with the whine in this thread.
  16. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    Funny! "I drive my car in the rain and it gets dirty." Well Duh!
  17. car compulsive
    car compulsive Active Member
    741
    274
    Michigan
    Many cars have this design as the door sills have become wider due to side impact protection. Some sills get dirtier than others. I wash the sills every time I wash the car.
    Bluegrassman likes this.
  18. jabecker
    jabecker driver of Prii since 2005
    448
    78
    Portland, Oregon
    I drive in the rain pretty constantly. I take my car to a car wash where they go over it, inside and out, including the sills. The only time I see the sills is when the doors are open and I'm getting in or out, and I'm not usually looking in that direction. If someone else sees my sills and thinks "ewwwww dirty!" then I have a few most unladylike phrases for them. :D
  19. Tideland Prius
    16,549
    Yeah it is annoying (though it shows up less on my Blue Ribbon Metallic). It's just the design of the door. I suspect it may be for side impact protection (a reinforced side sill). Toyota has a few models that do have the door go over the sill (the current Highlander IIRC).
  20. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Hmm...judging from the picture, I'd be forced to say that almost every vehicle I have ever owned has evidently had this "Major Design Flaw". Guess I always just thought of it as "Life".
    My expectations are not that the closed space between the door and the interior will remain pristine and clean. I don't consider that a visible part of the interior, even if it isn't a visible part of the exterior most of the time, therefore, I wouldn't expect Toyota to go to the trouble of adding weight, or designing protection to keep that area clean.
    But I suppose you or anyone are free to be annoyed by this....My solution would be....a rag or sponge applied occasionally.
