After starting my Prius the engine was knocking and shaking
Discussion in 'Gen 3 Prius Technical Discussion' started by yahal, Jun 30, 2012.
  1. yahal
    yahal New Member
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    This is a much discussed, known problem. Toyota has two TSB's out on this for repair but most dealerships require either a DTC code to be set or be able to duplicate the issue before repair.
    Typically this happens when car started, driven a short distance, shut off before completion of warmup cycle and then cold-soaked overnight. There have been other reports that do not fit the above scenario, though.
    Search on here for engine knocking and you will find multiple threads.
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Welcome aboard and join the knock club. Be sure to read the threads on the issue and be squeaky wheel at the dealer(s) to have the T-SBs implemented.
  4. bisco
    51,851
    :) this is an option with no extra charge.
  5. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    What does the TSB entail? Has the fix been implemented on the newer models?
  6. Saphteemon
    Saphteemon Junior Member
    36
    Orange County
    It has happened to me 3x when it was cold......
    Took it to the dealer because I'm on vacation this week and they said they couldn't do anything because they were not able to recreate it and that no codes were tripped.
    Damn..... Even though there's a TSB on it. I'm very disappointed......
    Oh well......it's still a good car.....not sure what else I can do....
    Lucky for me that I live in So Cal so temperatures under 40 degrees is rare......
