Question regarding stock speakers
Discussion in 'Gen 3 Prius Audio and Electronics' started by Lordkifar, Jul 3, 2012.
  1. Lordkifar
    Lordkifar Junior Member
    53
    I tried a search but could not find exactly what I was looking for unless it is hidden in some threads so I do apologize in advance if this has been answered before.
    I have a 2012 Prius liftback (base model in Canada). What is the brand of the stock speakers that come with it? I have the 6 speaker base system (no XM or Nav).
    Cheers :)
  2. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    oops... just realized you said no nav.
    Some 2012's have the JBL "green edge" speakers.
  3. Lordkifar
    53
    hmmmm....no idea if mine are JBL's....Short of taking off the door panel, not sure which ones I have....
  4. ikagan
    ikagan Junior Member
    61
    Aventura, Florida
  5. Lordkifar
    53
    I see.... Great to know. thanks.... Time to replace speakers I guess.... Sigh..... Need more money :)
  6. F8L
    19,011
    4,083
    Grass Valley, CA.
    Why would the brand be a reason you should or shouldn't replace the speakers? The decision should be based on whether you like the sound or not. :)
  7. Lordkifar
    53
    Not a question of brand, just wanted to know what is in there to begin with and the model meaning if the speakers in there are decent enough to begin with, perhaps I need to tweak my settings better (not that there is much to tweak really aside of fade and balance). From ikagan's reply, it seems to be a generic brand.
    I listen mostly to hard rock and heavy metal and I don't think they sound good. Most stock speakers don't....my older car had some bose speakers and those were decent so I kept them....will eventually change those. For normal radio listening they do the job but not for my tastes.
  8. ny_rob
    1,968
    813
    L.I.- NY
    If you're satisfied with the mid-range and treble from the stock speakers- you could always add a powered sub for base.
    I have this one (Amazon.com: Infinity Basslink 200-Watt, Dual 10" Powered Subwoofer System (Black): Car Electronics) in my CRV- using the the stock speakers for everything but base. The infinity Basslink gives plenty of base to round out the system.
    If you're not happy with the treble and mid-range from the stock speakers- you could replace them with the JBL speakers (plenty of treble/mid-range from them) and then add the powered sub for punch.
  9. Lordkifar
    53
    Thanks for this info. That might be an interesting option indeed. I know my wife has a Rav4 and she also was not too happy with the sound....perhaps a sound overhaul is needed in hers too. I think this sub would probably be more for her as she prefers more hip hop and dance music. I might only in my case upgrade the speakers and when more funds become available go for the bass unit.
  10. yyyiiikes
    yyyiiikes Junior Member
    84
    Austin, TX
    I didn't realize the Prius II came with speakers.
    But that WOULD explain the irritating noise coming from the dash and door panels.
    ultraturtle, Lordkifar and ikagan like this.
