Will a 205/70/15 tire fit on my 2012 Prius?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by dj7u, Jul 3, 2012.
  1. dj7u
    dj7u Junior Member
    28
    Long Beach, CA
    I got new tires which are Yokohoma AVID Ascend size 215/70/15 yesterday:
    Tire Details - Discount Tire Direct
    Giving a whopping about an entire one inch increase in ground clearance.
    Which are new long lasting & (LRR) low rolling resistance tires. A rare combo since LRR tires almost always don't last long so you normally until now made that sacrifice. This model tire just came out in first quarter of 2012. It's about the same width (5.9" vs 6.2") as stock 195/65/15 just taller with more sidewall which improves ride quality. Side benefit is you're less likely to scrape the front end parking or when there's any dips in a road since these are slightly higher off the ground. Hence, bettter ground clearance.
    I know with my previous 2007 Prius. I went from stock 185/65/15 to 195/65/15 just fine.
    I went from a OEM tire size of
    195/65/15:
    Overall Diameter: 25.1"
    Overall Width: 8.0"
    Tread Width: 5.9"
    Weight: 20.9 lbs
    Rim Width allowed: 5.5"-7.0"
    Max load: 1279 lbs
    Revs per mile: 828
    TO:
    215/70/15:
    Overall Diameter: 27.0"
    Overall Width: 8.6"
    Tread Width: 6.2"
    Weight: 24.8 lbs
    Rim Width Allowed: 5.5"-7.0"
    Max Load: 1653 lbs
    Revs per mile: 770
  2. F8L
    19,011
    4,083
    Grass Valley, CA.
    Why not just get the same tire in a 195/65/15?
  3. F8L
    19,011
    4,083
    Grass Valley, CA.
    FWIW, the top LRR tires in the OE 15" size have a 65,000+ mile warranty. That is pretty good. :)
    The size you listed is significantly larger than the OE tire. I would check your speedometer against a quality GPS and check your odometer against mile markers after install so you know where you stand. MPG can no longer be taken at face value with the typical 5%-6% error either.
  4. dj7u
    dj7u Junior Member
    28
    Long Beach, CA
    I prefer more ground clearance which is without any doubt a benefit. Plus, the tires will last longer with less revolutions per mile being taller.
    The 2012 Prius has quite a bit of empty space available for a taller tire when looking at the stock tires.
  5. dj7u
    dj7u Junior Member
    28
    Long Beach, CA
    AVID ASCEND Tire Details
    states:
    Gets 20% easier rolling vs conventional tires and 11% easier than Michelin HydroEdge.
    Saving $382 annually over conventional tires and saving $204 annually over Michelin HydroEdge.
  6. Jason dinAlt
    Jason dinAlt Member
    183
    61
    The 5% increase in diameter will not only throw off mpg calculations, but by, in effect, decreasing the gear ratio, make the engine work harder under all circumstances - dropping fuel economy.
    The 13% increase in weight will hurt ride quality, but more importantly, there will be sizeable increase in rotational energy which will further hurt fuel economy.
    And that increased ride height you want will also hurt fuel economy.
    Seems to me that what you really want to do is trade in your Prius on a Ford Escape Hybrid.
    Edit: You are comparing apples and oranges. The OEM tires on the Prius are already LRR tires. The construction on the Ascend is irrelevant to the discussion. You need to compare it to other LRR tires - and you need to consider that size is a completely separate issue.
  7. xliderider
    xliderider Senior Member
    8,085
    3,237
    Honolulu, HI
    You are putting a larger, heavier tire on though, that will decrease any mpg benefits. Also, there are warnings on the tire size calculators to stay within 3% of OEM tire diameter or brake failure is a possibility, with the obvious inaccuracies in the speedometer and odometer. The odometer error alone would make it illegal, I'm sure, if uncorrected.
  8. dj7u
    dj7u Junior Member
    28
    Long Beach, CA
    The 3 lbs per wheel in weight increase won't do anything to the brakes that last forever anyways due to the regenerative braking.
    Increasing tire size isn't illegal. By law, you're not even required to have a speedometer at all. It's not "legally" required equipment like a horn, bumper, etc. My knowledge of California traffic laws are better than most California lawyers. I've even beat my last four CHP speeding tickets in California. California is generally the strictest state for everything including traffic laws.
    Obviously, taller tires lower gear ratios beneficially increasing speed and top speed. Speedometer might be about 2mph off which is typical in many cars stock.
    The 2010-2012 Prius would still get much better mileage with these tires than a 2004-2009 Prius. The 2004-2009 Prius gets terrible mileage driving 80-90 MPH due to the weaker smaller 1.5L engine requiring higher revs. After owning a 2007 Prius, I wouldn't even recommend someone by unless its a 3rd generation Prius having owned both now.
    DAFTEK likes this.
  9. F8L
    19,011
    4,083
    Grass Valley, CA.
    The Ascnd is going to provide similar fuel efficiency to the OE Yokohama S33D. I would not go into this expecting to gain fuel efficiency.
  10. dj7u
    dj7u Junior Member
    28
    Long Beach, CA
    True never said it would being the same tire brand and both being low rolling resistance tires.
    Two big differences:
    1. Tread rating on OEM tire has only a 320 tread rating. Ascend model has a 800 tread rating. Double the life.
    2. The OEM tires are more expensive even though less than half the life.
    Best deal I could find online for both is below.
    205/70/15 is $400.00 FREE SHIPPING:
    195/65/15 OEM: $432.00 PLUS SHIPPING:
    Tire Search Results
  11. F8L
    19,011
    4,083
    Grass Valley, CA.
    I hear ya. I'm not saying don't do it. I just wanted to go into this with as much knowledge as possible. :)
    I'm pretty familiar with the tire. Yokohama AVID Ascend Review | PriusChat
    I think you are cherry picking your tire prices to favor the size you want. TireRack has the 195/65/15 for $348+shipping and the 205/70/15 for $368+shipping. Shipping in many cases is $40-$43.
  12. Den49
    Den49 Member
    498
    272
    Maryland
    Below is a website I found on another car forum that is very useful for comparing tire sizes when considering tire and wheel plus sizing.
    Tire Size Calculator - tire & wheel plus sizing
    If you do upsize your tires, keep us informed of the effects on mileage, etc. It would be interesting to see. I think most of the effects will be negative because the stock 15" tire size is integral to the optimimal car design.
    McLintock! likes this.
  13. eldersciii
    eldersciii C3PO
    32
    Sacramento
    Long and short of it... No they won't. Too big and your odometer will be off.
  14. dj7u
    dj7u Junior Member
    28
    Long Beach, CA
    The more affordable Discount Tire Direct website that sells the Yokohama AVID Ascend doesn't sell the cheesy OEM tires (like most OEM tires) so not cherry picking. Going by most affordable to most affordable available. The more expensive site TireRack.com wants $61.50 for shipping not the $40-$43 you said. So, for OEM S33D is $432 plus $61.50. Almost $500 for the OEM tire with a 320 tread rating is pathetic.
    How can I take my car back to the dealer like you did and try getting at least 195/65/15 AVID Ascend? My car has just under a 1,000 miles and have had less than 2 weeks.
  15. F8L
    19,011
    4,083
    Grass Valley, CA.
    The AVID Ascend I listed is not the OEM tire. The Ascend was never offered as an OE tire for the Prius. TireRack is often comparable in price to Direct Tire. Shipping must be more for you given your location. For me it is only $40. So as I said, the price (between the same tire and size) is still comparable even at the $60 shipping price you quoted. $348+$60= $408 for the 195/65/15 Ascend. I originally missed where you were comparing the S33D price to the Ascend so i appologize. I agree that the Ascend is a much better deal. :)
    I went to America's Tire Company and they helped me file a claim with Yokohama to get the tires replaced. Unfortunately I hear it is becoming harder to get a claim for these tires now. :(
  16. dj7u
    dj7u Junior Member
    28
    Long Beach, CA
    I was only talking about the S33D tires when saying OEM.
    There's a Discount Tire (Same co. as America's Tire an Discount Direct) within 5 miles of me. I might ask just to see what they say. Otherwise, I'll just wait a few months with these being 320 tread rated tires I know I'll need new tires soon.
    I see that you have the same exact car as me. Good taste :)
    What month did you do that Yokohama claim?
    Noticed the Sacto location. I was born & raised in Roseville within 2-3 miles of the Roseville Galleria mall. Now, the largest mall in Northern California they say since their additions. Lived there until June 2008.
  17. dj7u
    dj7u Junior Member
    28
    Long Beach, CA
    Fuel-efficient tire test: Michelin Energy Saver A/S and Cooper GFE
    states:
    Only up to 2% increase. So, people are wasting their money buying a Michelin Energy Saver. 40.8 MPG vs 40MPH or 51 MPG vs 50MPG. That's all a 2% increase is. Plus, that tire doesn't even have a tread wear warranty. Any money you save you're just paying in buying the tires more often. Just choosing who to give your cash to is all. But, you have to get gas always anyways. Nobody wants to have to buy tires every 1.5-2 years like I did in my 2007 Prius with Goodyear Fuel Saver tires. Never again.
  18. F8L
    19,011
    4,083
    Grass Valley, CA.
    I'm sorry. I don't want to sound like I am picking on you but you really should do a better search for this kind of info. :(
    The Energy Saver A/S comes with a 65,000 mile warranty. Energy Saver A/S | Michelin Tires
    It also out-performed other LRR tires in a test in 2009 conducted by TireRack.com. It out-performed non-LRR tires by 3.8mpg. My personal experience has been a 2-3mpg gain over the AVID Ascend which makes them the least cost per mile tire that I know of. The Ascend is still a great tire and I'm not trying to down it but I have direct experience with both tires.
    Tires : Test Results : The Tire Rack
    Michelin Energy Saver A/S Review | PriusChat
    Total lifetime cost for fuel and tires over 150,000 miles | PriusChat
  19. F8L
    19,011
    4,083
    Grass Valley, CA.
    I knew you had to be from the area when you called it Sacto. :) Do you like your new area better?
  20. dj7u
    dj7u Junior Member
    28
    Long Beach, CA
    I like the winters. Which is why the Phoenix area is the fastest growing area in the US.
    But, I'm thinking of buying a 2-3 bedroom condo in Anaheim soon. It's rated #1 in 2009 CNN Money Magazine best places for healthy retirement. But, in 2011 CNN Money magazine says it's the #3 most eexpesive housing market higher than San Diego. That way the weather is great year round. Maxing out at 85 degrees instead of 115:
    Best places for a healthy retirement - Anaheim, CA (1) - Money Magazine
    10 most expensive housing markets - Anaheim, Calif. (3) - CNNMoney
    A big lession I learned was having my 2007 Prius so long. So, I had to pay a decent difference (About $16K) to buy my new 2012 Prius. I'm going to buy a new Prius every 2-3 years for now on. That way I only need to pay $6K-$10K max more for a new one. Plus, an extended warranty is never even needed if you don't go over the 3 years/36K miles.
    I was thinking of getting the plug-in model but I'm glad I didn't. Cause the rumor is the 4th Gen. Prius will all be plug-in's and will go about 37 miles without any gas vs the current 12 miles. Plus, will be about $26K total no $32K ($6K premium) that you pay now for the plug in.
