Slight Front End Shaking 63-69mph ?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Azfalconfixer, Jun 30, 2012.
  1. Azfalconfixer
    Azfalconfixer Junior Member
    46
    Peoria, AZ
    From day one my 2012 Prius 3 has had a shake that starts at 63mph and goes away at 69mph. Sometimes it's worse then others. I can feel it in the steering wheel and the floor broards. I took it back to the dealer and they said they felt it but couldn't find anything wrong. They actually put new wheels and tires on it! It seemed alright for while but I noticed it again the other day, I don't drive that speed that often. I'm either below or above it but the other day I got caught in traffic doing 65 and noticed it right away. I made a new appt this next week at the dealer again. It's not real bad just more annoying then anything. I searched on here but couldn't find anything, has anybody had or seen this?
  2. mygen2
    mygen2 Junior Member
    17
    I've seen wheel bearings causing that.
  3. The Critic
    The Critic Resident Critic
    3,193
    2,330
    CA
    Likely a wheel balance problem.
    iPhone ?
  4. Big Steve
    Big Steve ramblin wreck
    402
    39
    Richmond VA
    I vote for balance given a range of speed causing the vibration, some harmonic thEre. Had that with another car once. Strange that they changed wheels and tires and it returned. Do you drive on rough ground that could screw with tires?
  5. Azfalconfixer
    46
    Peoria, AZ
    I drive 50 miles a day on smooth highways. I first time I took it in they chacked the balance and all four tires were good. They still could duplicate it and that's when they changed the wheels and tires. I'll see what they say tomorrow.
  6. Mikawa
    Mikawa Junior Member
    32
    Rancho Palos Verdes, Southern California
    Whenever I drive at 60mph and above I would feel a few slight lateral jerks on the car. It's kinda annoying but I am attributing this to the new tires on its breaking-in phase, that is oils in the new tires hasn't been completely removed yet from repeated driving.
    If this persists for a few more days I would have to bring the car back to the dealer for a look-see. Fyi, just got the car 13 days ago.
  7. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Make sure they used the correct stick on weights when they balanced the tyres. Maybe get them checked somewhere you trust? If they'd been sloppy there might be a valve cap inside the tyre causing a wobble. If after having the tyres checked and they're fine I'd check the side walls very carefully for signs of damage as that can cause vibrations.
    Whilst at it, maybe get the rears checked too as sometimes it can feel like the front when it's a rear tyre causing the issues, especially if the vibration through the steering wheel is faint.
    Have you had any suspension damage? I see you have a new car but one big pothole can cause issues if you hit it hard enough.
  8. prj
    prj Member
    OH
    I have the same wheel out of balance vibration, most noticeable at 64-66 mph. The dealer rotated and balanced the tires at 7000 miles. It helped a little, but the vibration is still there. I'm planning to take it to a tire store to see if they can do better.
    Even with no other fixes, at 12000 miles, the vibration doesn't seem as strong. Maybe I just don't notice it as much.
    When my 2011 was new, I thought it didn't track easily on the highway, I would need to do lots of tiny steering corrections to stay in the lane. That also seems to be better.
  9. Azfalconfixer
    46
    Peoria, AZ
    It's done it from the day I drove it off the lot. I took it in Monday and rode with the service tech. He could definitely feel it. They did a road force balance and said all the tires were within limits but worked to get them better. It does feel better but it's still there. The first time I took it in they change the wheels and tires and this time they did the road force balance.
    As I was leaving I asked the service manager what if it still does it? He said they don't know what to do next.
  10. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Replace your wheels with a demo off their lot. If the problem goes away then you know the issue. If it doesn't then you've at least discounted the wheels/tyres.
    I'm trusting the tyres are at correct pressures? Some dealers like to top them off at 30 psi or so.
  11. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Since they already put new tires and wheels on it, I think that possibility is low. I am thinking a manufacturing defect in the suspension somewhere... possibly bearings. You might test the temperature of the hubs with your hand after a commute.
    Also, you might have them run it through an alignment... it was free up to 12k miles/1 year on my 2010.
  12. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    691
    151
    Seattle, WA
    New possibility: toe-in alignment is off, perhaps on one wheel. The crabbing it causes forces that tire to loose grip/regain grip/loose grip, leading to an oscillation or vibration. A resonance with speed might be possible.
  13. taxachusetts
    taxachusetts Junior Member
    39
    Boston
    My wife’s 2011 Prius 4 and my 2012 Prius 4 do pretty much what you are describing. The only difference is that the ’11 shakes between 59 and 62 mph, and the ’12 does it at between 63 and 65 mph. (My wife’s ’08 (4) and my ’10 (4) had no such problems.) I brought the ’11 back a few days after I bought it and the ASE certified geniuses at the dealership told me it was road conditions. When the ’12 exhibited the same symptoms, I didn’t bother to bring to the dealer. When I put new wheels and snow tires on the ’11 I assumed that the shaking would end, but it didn’t – same shaking at the same speeds. At times I think it could be an engine vibration, because we have never felt any shaking in the steering wheel on either car - only the body shakes. It’s possible that some sort of increased tire wear will be a consequence of the shaking, so we avoid driving at those speeds.
  14. hlunde
    hlunde Member
    419
    75
    A defective wheel bearing should deteriorate fairly quickly. Other possibilities are imbalance in components other than wheels/tires --perhaps a brake rotor.
    If the vibration occurs mostly on smooth roads then I would vote for possible binding (static friction) in a McPherson strut. This is a well-documented problem with early McPherson struts and it's the reason that front coil springs are always offset --- to reduce the side thrust on the strut. I'm also thinking that this problem would be worse with LRR tires since they have lower intrinsic damping.
  15. prj
    prj Member
    OH
    I was going to take my Prius to an outside tire store to get the wheels rebalanced, to see if they could do a better job. But the vibration isn't as strong as it was when the car had 5,000 miles. I don't think it's due to just getting used to it.
    Now I have 12,000 miles on the car. I'm going to leave it alone for now.
  16. Jason dinAlt
    Jason dinAlt Member
    183
    61
    If balance and/or alignment does not fix it, check wheel run-out and concentricity as well as tire roundness.
  17. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Rotors are warped. Somebody did a hard pull down on a demo.
  18. Accordlayingkit
    Accordlayingkit Senior Member
    1,616
    1,747
    377
    Colonial Heights, Va
    Whatever came out of this? I'm having this issue now with my 2012
    Merchants tire jus re balanced all my wheels today (18 inch that they newly did a month ago) and I'm still having the bad vibrations... I would say it was happening above 55mph but now tonight on way to work it was happening around 45-50mph! The tires aren't but a month old. This didn't start happening till after Toyota did a full alignment Wednesday. I made sure to have wheels rebalanced today so when I take it to Toyota they don't try to say it's the Balancing of the wheels!
