oil change lab results
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by has been, Jul 13, 2012.
  1. has been
    has been vote for anyone except Trump
    254
    46
    pacific n'west
    Thought I would post this quick info cut/pasted from Blackstone Labs.
    Replaced my oil at 3500 miles and sent it in for a look.
    In the comments section they said:
    Has Been : The high wear metals and silicon are not unusual finds in the oil from your new Toyota. In fact, we
    would have been surprised if we didn't find them. The wear is high due to break-in of new parts, while silicon
    is from sealers and sand-casted parts. Universal averages show typical wear metals for oil from this engine
    after 5,500 miles use. We expect your engine will look that good or better in two or three more oil changes.
    Toyota engines tend to wear very nicely, and yours will too once it's past wear-in. Check back to see improvements.
  2. LTZR1
    LTZR1 Member
    134
    31
    Midwest
    The meat of the Blackstone report lies in the NUMBERS moreso than their comentary. Post the entire report. That will be more helpful to those who can read and understand UOA's.
  3. has been
    254
    46
    pacific n'west
    And for those who are not interested in UOA's it's a simple and positive summary/observation.
    I dig the technical, but it seems that (in my life) the more detail I go into the quicker I lose my audience.
    To not exclude the tech-savvy, attached please find yet another oil test sheet of results.
    pjksr02 likes this.
  4. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    Thanks for that. Did you see any visible metal particles in your filter element at 3500 miles?
  5. has been
    254
    46
    pacific n'west
    I was dragging a relatively weak magnet thru it after I drained it.
    Mag broke off from my holding device and sits in bottom of container.
    Drained it into a clear plastic container to watch it settle over time.
    Installed mag-plug to case pre-refill.
    Have filter and oil with mag in container but have not looked at it closely yet.
    Will do it though as (obviously) I'm the curious type.
    After changing been on road until today so we'll look and report back.
  6. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Unfortunately their commentary is of highly variable quality.
    And, what's with their "should be" 100C viscosity for 0W-20? It doesn't agree with the SAE spec.
  7. has been
    254
    46
    pacific n'west
    the SAE spec for what?
  8. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    The spec is SAE J300
  9. has been
    254
    46
    pacific n'west
    Yeah.
    What's up with that?
  10. LTZR1
    LTZR1 Member
    134
    31
    Midwest
    You might want to ask Blackstone "what's up" with the oil shearing a full 20% ! VOA of the Toyota 0W20 specs 8.54cST at 100C vs your reported 6.81. That makes the fuel reported highly suspect. It is more than likely much higher and contributng to the 20% oil shearing which is quite a bit for the low mileage being reported. With that much shearing, one might also question the flash point being reported. Also, a TBN, TAN, and Particle Count makes a UOA much more meaningful.
  11. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Those are valid concerns, but to put things in perspective.
    The subject UOA was done on factory fill based on the oil and unit life both being 3500 miles. If the VOA wasn't from factory fill, then its viscosity is of limited value.
    A couple of years back on BITOG I noticed that Blackstone particle counts for several oil samples from different cars had exactly the same ratio of particle counts between different particle sizes. That meant that Blackstone wasn't doing particle counts, they were running some sort of test but then assuming some standard distribution of particle sizes. Unless that has been fixed there isn't much reason to waste your money on a Blackstone particle count.
    To be fair, I do think their other testing (but not their comments) is adequate and on par with other companies low priced UOAs
  12. gliderman
    gliderman Active Member
    751
    225
    What companies UOA's would you recommend?
  13. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    For the basic numbers, but not particle counts I think Blackstone if OK. I haven't had any UOAs done in at least couple of years so haven't kept up with who is good now.
    To clarify, particle count is not the "parts per million" numbers in the above report. A particle count is something different.
  14. LTZR1
    LTZR1 Member
    134
    31
    Midwest
    With the Prius being manufactured in Japan, the factory fill is Idemitsu's 0w20 made for Toyota in Japan. It's 100C cSt is 8.86 which is very close to the XOM manufactured US SN Ow20. That being the case, the viscosity comparisons are of complete value. In fact, the low miles on the oil makes the shearing issue more of something to keep an eye on. Frequent short trips without complete ICE warm-up are more than likely causing excessive fuel dilution, which is not showing up in Blackstones testing.
    Blackstone utilizes ISO 4606 testing to quantify particle contamination. They have updated equipment and procedures. We have done comparison testing of the same oil from three different labs and have found their testing to be consistent. The best results and interpretations for our purposes have been those which have been done by TerryDyson at Dyson Labs.
  15. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Until we know the tolerance on Idemitsu's and XOM's spec, the nominal viscosity doesn't mean much.
    ISO 4606 looks like a typo, it has nothing to do with oil particle contamination. It's a glass textile woven fabric spec. Do you have the correct spec?
  16. LTZR1
    LTZR1 Member
    134
    31
    Midwest
    Tolerance ? The Idemitsu 100C cSt is 8.86...That's the factory fill. ( The US Toyota SN 0w20 1ooC cSt is 8.54 ) The Blackstone 100C cSt analysis of the factory fill came back 6.81. Nothing more is needed. That's a whopping 2.05 difference. Do the math....thats over 20% shear for an oil in use only 3500 miles .
    Look up ISO 4406 standard which utilizes a three number standard to classify cleanliness.
  17. LTZR1
    LTZR1 Member
    134
    31
    Midwest
    Tolerance ? What tolerance ? Idemistu's 0W20 FF 100C cST is 8.86. The US 0W20 Toyota SN is 8.54 but it's not the factory fill. Blackstones analysis reported a 100C cSt of 6.81. Thats a whopping 2.05 cST differance, over 20% shearing in just 3500 miles. That's all that's needed to determine shearing. We're not talking about "nominal viscosity" here, we're talking specifically about 100C cST viscosity.
    Look up ISO 4406 standard which utilizes a three number system to classify cleanliness.
  18. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    If you think there isn't a tolerance on the Idemitsu manufacturing and testing viscosity and Blackstone's viscosity test results I have long orange bridge near San Francisco I would like to sell you.
    ISO 4406 tell how to derive a three number cleanliness interpretation of particle count tests, it doesn't tell how to do the test. that's a big difference.
    If you take a look at the Blackstone UOA report at
    2006 Tundra, 6K mi, Mobil 1 EP 5W-30, UOA #18! - Bob Is The Oil Guy
    Then divide each 2 micron count number by the 5 micron number below it you will see that the ratio always falls extremely close to 2.70. This is on a vehicle that had particle tests done over a 5 year period and 76000 miles using different oils and different filters. That's not how the real world works, those numbers are not actual particle counts, at best they were dry labbed from some simplified test that approximates particle counts. It's a shame that Blacstone is still doing this after they were called on it over 5 years ago.
    I have no objection to them doing a simplified test and reporting an 4406 ISO number based on that, but dry labbing particles counts is shady.
  19. gliderman
    751
    225
    So what labs can you name that do it the right way? Thanks!
  20. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    OK, what happened to the magnet in the oil?
