700 Mile Club
Discussion in 'Gen 3 Prius Fuel Economy' started by F8L, Jul 16, 2012.
  1. bisco
    51,897
    the problem is, it depends on your driving charging habits. some are getting 4-500 and others 1-2000+. :eek:
  2. Brett.
    Brett. Junior Member
    134
    26
    July in NJ 2012. Unusually high temps. 90's 100's. Driving with windows, instead of AC all but twice.
    Miles: 700.3
    Gallons: 10.464
    Displayed: 69.8
    Actual: 66.92
    At 608 miles, the last bar began to blink. The display read 68.8mpg and the "To Empty" read 25 miles.
    At 641 miles the "To Empty" read 0 (Zero) miles to go. The display was reading 68.8 mpg.
    10.464 gal (US)
    8.71 gal (Imp)
    39.61 L
    352.64 kWh
    66.92 mpg (US)
    80.4 mpg (Imp)
    3.51 L/100 km
    1.49 gal (US)/100 mi
    503.56 Wh/mi
    Techniques used "N" coasting, "D" gliding, Driving with load, never letting the HV battery get low enough to force the engine to turn on, 99.99% of the time not letting the PWR bar light up at all, even on hills.
    At the rate I was consuming fuel, I could have emptied the tank at 796 miles. Tomorrow I'll be driving roads which I could probably have edged my mpg up to 69 or so, giving me an 800 mile tank. Now that's a goal.
    walter Lee likes this.
  3. fuzzy1
    10,437
    Just to demoralize regular mortals (which includes me), here are some aspirational targets --
    Are you ready to hear about 1800 miles, in a Gen2? (note that the Japanese Gen2 lacks a bladder, so has a larger tank.) New World Record Challenge: over 50km/L(117mpg) tank
    For a list of previous annual records, see: 77.7 Miles per Gallon for 13 miles
  4. F8L
    19,011
    4,083
    Grass Valley, CA.
    Good job, Brett! That's any excellent tank. Thanks for posting your techniques too.
  5. Ferls80
    Ferls80 Performing some hypermiling techniques.
    66
    Padova, Italy
    Oh my god, this man is a maniac! I had a VERY HARD work to keep that f.e. (50 km/l) and just for 35 km!!!
    I really can't imagine how he could keep that value for something like more than 3000km... Wow!
  6. markabele
    5,084
    1,782
    Nebraska
    Ferls80,
    How many roundabouts compared to regular stop lights do you have on your regular commute?
  7. Ferls80
    66
    Padova, Italy
    Hi there!
    I have just one stop light and something like 8 roundabouts.
    You're right markabele: roundabouts helps a lot!
  8. markabele
    5,084
    1,782
    Nebraska
    Yes! There are finally starting to be more in my city but unfortunately none on my commute or regular driving areas.
  9. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    I have 3 roundabouts on my commute. The only issue I have with them is that other drivers (not as experienced and don't know roundabout rules/eitquette) sometimes screw things up, mostly when they have the right of way, stop in the roundabout because they don't trust me to stop. Now that I'm forced to stop, they then proceed and my roundabout has been reduced to a 4 way stop. Ugh. Fortunately, it doesn't happen too often.
    I have no issue with PIP prius in the 700 mile club, they just need to identify themselves. My mileage would be better with a PIP, but my commute is too long for it to really shine. My wife's 2 mile commute would be friggin' awesome with a PIP.
  10. walter Lee
    1,126
    376
    Maryland
    The real challenge to the 600 mile or 700 mile range is the fact a 2nd/3rd gen Prius is limited to 11.9 gallons.
    The challenge is greater for a Prius c which has 9.5 gallon fuel tank.
    The challenge is also greater for the Prius v which is heavier.
    A PiP use two energy sources so to identify its achievement properly we need to record not just the gasoline used but the total amount of KwH used to recharge the HV Li-ion batteries and starting SoC between the distance travelled.
  11. F8L
    19,011
    4,083
    Grass Valley, CA.
    Oh my god. Hypermiling is so boring. I'm at 560.8 miles and 67.1 miles per gallon. I've been dongoing a pulse and glide session for almost 2 hours. Ugg
  12. Codyroo
    1,826
    515
    Pleasanton, Ca
    You need better music for your Ipod! I don't mind slow and go traffic a bit if I've got some good music on. Rock on!
  13. Brett.
    134
    26
    If you look at my previous tanks, you'll notice I hypermile 1 tank, then go crazy the next. Then hypermile, then do 2 crazy tanks. Then hypermile 1, then 3 crazy tanks. I just hypermiled 1, now I need to floor it for 4 tanks. I really get crazy sometimes going so slow. It's a real test of patience, hypermiling is.
    F8L likes this.
  14. F8L
    19,011
    4,083
    Grass Valley, CA.
    654 miles. Dte = 18! Wish me luck
    Codyroo likes this.
  15. markabele
    5,084
    1,782
    Nebraska
    You should have 700 no problem then!
    Codyroo likes this.
  16. F8L
    19,011
    4,083
    Grass Valley, CA.
    I did it!
    *collapses from exhaustion*
    With the weekend coming up I wasn't sure I'd have another chance to pull off a 700 mile tank. So starting from a low of 63.5mpg (indicated) I decided to go for a short pulse & glide session to bring my average up before driving to the Bay Area tomorrow. The P&G session was tedious and sometimes nerve wracking because of other motorists but after awhile it felt like second nature. I spent time on the phone troubleshooting a computer virus problem for a friend. Then The Critic called and we BS'd about all thing Prii for awhile. Next thing I know I am at 700miles. It only took like 6 hours of doing circles around the airport to do it. *face palm*
    Miles: 702.5
    Gallons:10.171
    Displayed: 71.7mpg
    Actual: 69.07mpg
    Methods:
    Type: Normal commute of 98% highway and some rural road driving up to 470miles or so. The remaining miles were pulse & glide (41mph to 26mph)
    Mode: Eco
    Weather: cool to warm 50s to 80s.
    A/C: never!
    Tires: Energy Saver A/S at 46/44psi
    Here is what the trip from work, to the pulse and glide location then back home looked like.
    PriusBull, PaulHS and Codyroo like this.
  17. Codyroo
    1,826
    515
    Pleasanton, Ca
    Gadzooks! That is awesome. When I saw your initial post that you were pulsing and gliding, I thought you meant that you were driving home from work and were trying to Pulse and Glide due to traffic. I didn't realize you meant that you were actually trying driving trying to get your tank to 700 miles! Well, the scientist and adventurer in you has won again. You now can cross that off your bucket list (until you start the 800 mile club....do yourself a favor.....don't start a 800 mile club!).
    And you have done better than a goodly portion of the PIP Prius owners with that 69.1 calculated (71.7 mpg displayed) tank. I don't think I can beat your tank!
    Have fun in the Bay Area! Wave as you pass Pleasanton!
  18. Ferls80
    66
    Padova, Italy
    Congrats F8L, another stunning tank achieved. Keep the nice goin'!
    I also liked the 2nd pic u posted, a sum of a trip I guess. I don't have it in my 2010.
  19. F8L
    19,011
    4,083
    Grass Valley, CA.
    Thanks, brother! Didn't have anything else to do last night so I said heck with it. I learned quite a bit and as usual I have a bunch more questions now. I'll start a new post for those. As for my high tank, I thought you had one that was higher? Either way mine is a one-off deal. Driving in a giant 13mile loop for hours doesn't count. LOL
    I have a whole new level of respect for Wayne and those Japanese hypermilers. This is hard work! At least I had little hills and turns that made it more interesting and driving along the Sacramento river half the time was nice.
  20. F8L
    19,011
    4,083
    Grass Valley, CA.
    Thanks! The second picture is a trip summary screen they added to the 2012 models. It is very helpful in checking your results for each trip instead of having to guess. It makes analyzing the effects of driving technique, weather conditions and modifications much easier!
