plugless PHV driving stories
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by john1701a, Jul 28, 2012.
  1. tpilkington
    tpilkington Junior Member
    We just traded in our 2005 Prius with 184,000 miles...the car was perfect and with no problems. We now have purchased a Plug in. On the 2005 we averaged 42-44 MPG. To get to our house, you drive up a five mile road where you gain about 1500 ft in elevation. That said, we are milking the downhill road in EV and going back up in ECO...on the first tank of gas, we averaged 55 MPG...second tank we are averaging 65 MPG with about 200 Miles so far on the tank. We are finding that we leave the house with a 13 Mile EV range and get to the bottom of the hill with close to the same (coming down the hill in "B)". On several trips, we have driven around town on EV, driven back to the hill, switched back to ECO, and had enough EV charge left to repeat the process...something like 25 miles of EV
    Interesting thing we are finding is that we are getting, the uphill does not seem to be having as much effect in drawing down the MPG as the old Prius. On the old one, we would see a 4-5 mpg drain with about the same miles on the tank...on the PIP we are seeing about 2.
    We love it!
    john1701a likes this.
  2. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    Thanks! I had actually forgotten about that online version, especially being so busy collecting data still and scrambling to document observations shortly after they occur. Fortunately, the User-Guide already has it.
    As for the abbreviation itself, that's how Toyota refers to the plug-in model online here. In Japan, they actually get that emblem on the car itself. So, having PHV in the thread title will hopefully attract some who discover it from searches outside the forum and entice them to join in the discussion... new owners especially!
  3. Three60guy
    Three60guy -->All around guy<-- (360 = round) get it?
    918
    Racine, Wisconsin
    Not to belabor the point but what does PHV stand for? Plug-in Hybrid Vehicle?
  4. john1701a
    12,817
    5,303
    58
    Yup, so we'll see the same show up later on Camry... Prius c & v are likely candidates as well. It's easy to see Ford supporters endorsing the same, since they'll have a Fusion plug-in hybrid at some point.
    My interest is making it clear that the traits Prius without a plug delivers were not sacrificed for the sake of a plug. You still get outstanding MPG even without plugging in. You still get an ample amount of storage area for cargo. And the emission-rating is still top notch.
  5. bfd
    bfd Plug-In Perpetuator
    659
    172
    Close to SDSU in the Far Southwest Corner of Cali
    HV - Hybrid Vehicle
    PHV- Plug-in Hybrid Vehicle
    PHEV- Plug-in Hybrid Electric Vehicle
    Also:
    EV - Electric Vehicle
    HEV- Hybrid Electric Vehicle
    PHEV - Plug-in Hybrid Electric Vehicle
    There are so many equivalent terms, that it's hard to keep track. Definitions - in a quickly changing hybrid/electric landscape - are difficult to pin down.
    For example: California Air Resources Board calls the Prius Plug-in a OVCC (off-vehicle charge capable).
    That's one I hadn't heard before. There has been a thread or two here discussing the various names for the plug-in Prius.
  6. drinnovation
    drinnovation EREV for EVER!
    2,027
    586
    65
    CO
    Thanks.. interesting. Sounds like a run you would have likely made in the regular Prius many times. Do you have data from a similar temp/speed run to the airport in the regular prius?
  7. Tideland Prius
    16,554
    There is a 1 Min Consumption Screen in the 2010.
  8. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    Well, it's actually a periodic consumption screen that you can switch between 5 and 1 minutes by holding down trip or display (can't remember which one).
  9. Three60guy
    918
    Racine, Wisconsin
    Is switching between 5 and 1 minute options available on the PIP? Been looking for that ever since I got this vehicle.
  10. bisco
    51,897
    aren't they 2 separate screens on the scroll thru?
  11. john1701a
    12,817
    5,303
    58
    I forgot about that, since it's so different. The scale is smaller and you can't see that at the same time as anything else. Having 3 seperate displays (HUD, HSI, MFD) in the Advanced model sure makes information gathering and system observation easy...
    Tideland Prius likes this.
  12. How many electrons are we talking about, all errant electrons must be forced to go stand in the corner.
  13. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    Another remarkable trait I've found driving the PiP in HV mode is how little impact plugless driving has on my tank MPG average. I can have a tank average of say 88 MPG, and wind up having to drive, uncharged in HV for significant distances, and the tank average is impacted very little if any.
  14. bisco
    51,897
    my point is, this thread is about hv driving with an 'empty' battery. down to the point where it is like a standard prius. if you have any juice above that (from plugging in) you get some benefit from it in mpg's. it doesn't save all the electrons for ev, just most of them.
  15. ProximalSuns
    ProximalSuns Senior Member
    1,877
    PNW
    So what was the EV mode battery capacity when you were done with the 37 mile drive? Did 37 miles of regular driving leave you with a bonus of some EV miles?
    I'm considering a plugless PHV existence. I can't plug in at home. I will be able to charge up at work and get 20(?) EV miles which would be 25% of my daily commute. I figure if I get 56-58 mpg in my regular Prius for that commute, the EV, plugged in a work, would get me to the 70 mpg range.
  16. bisco
    51,897
    that sounds a bit optimistic, unless you're including the plug in juice in the 70mpg's. can you rent one?
  17. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    When you are on the MID consumption screen, hold and press the Display button on the steering wheel. It will toggle between the two on the MID. Alternately, hit the Car button on the MFD and select the Consumption screen and it will show you the 1 minute average for the last 30 minutes, including data from the previous driving session. It mostly mirrors the MID 1 minute screen, but I've noticed some discrepancies between the two.
  18. devprius
    devprius /dev/geek
    979
    291
    No. It's a toggle between the 5 min / 1 min consumption. Press and hold the Display button on the steering wheel to toggle between them.
  19. Three60guy
    918
    Racine, Wisconsin
    Sorry to consume bandwidth on this but what is MID? Also, "hit the Car button"? What is the "Car" button?
  20. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Mid is multi information display, the vacumn fluorescent display atop the dash. In the gen II the touch screen was called a mfd, or multi function display.
    I do not know car button but he means goto the one minute display on the touch screen.
