Loud droning sound from under hood during hot weather.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by co_prius_3, Jul 29, 2012.
  1. co_prius_3
    co_prius_3 Member
    174
    32
    Colorado, USA
    I've noticed a loud droning or fan noise coming from under the hood. It's loud enough to be heard inside the car with the hood closed. It usually happens when the car is just started and the outside temperature is in the high 90s. I assume it's one of the cooling fans, but it seems louder than one would expect. Has anyone else noticed this? I haven't tried turning the AC off to see if it is associated with that.
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    It is most likely the AC. Try turning it off to verify. It is a variable frequency motor so what you are hearing is the electric switching frequencies.
  3. LulzChicken
    LulzChicken Prius Enthusiast
    791
    135
    Alabama
    It's the A/C compressor.
  4. co_prius_3
    co_prius_3 Member
    174
    32
    Colorado, USA
    Yeah, I just tested it by turning the AC off. The droning sound stopped. It seems louder than it was when it was new, or at least I never noticed it. It shouldn't be that loud IMO. I'll have them take a look at it when I bring it in for the next oil change.
  5. LulzChicken
    791
    135
    Alabama
    The noise usually starts loud when you first turn the AC on, but gradually gets softer. The more the AC works the louder the noise is. I wouldn't worry about it. It's more than likely normal. It seems a little loud to me too, at times.
  6. jdcollins5
    5,131
    1,346
    Wilmington, NC
    If the noise really bothers you, there is a customizable configuration that your Toyota dealer can change to reduce the noise. The tradeoff though is that the unit loses some efficiency.
  7. co_prius_3
    co_prius_3 Member
    174
    32
    Colorado, USA
    Thanks. It's not so much the noise, but the concern that something was faulty. If it's normal, then I won't worry about it.
    I can always turn up the radio. ;)
    jdcollins5 likes this.
  8. wls
    wls Junior Member
    sf bay area
    This happen to my prius too, ac compressor noise, the dealer replace my compressor unit, you should take it back to your dealer while still under warranty, this not cheap to replace dowm the road. picking up my car tomorrow.
  9. co_prius_3
    co_prius_3 Member
    174
    32
    Colorado, USA
    I will mention it to them at the next oil change. I didn't remember it making that noise a year ago.
  10. macman408
    1,179
    368
    One other recommendation - if you're not doing so already, try using A/C in Auto. Specifically, set the temperature to whatever level makes you comfortable, and adjust it up or down in lieu of adjusting the fan speed. If you manually set the temperature very low and the fan speed very low, it will run the compressor very hard (to reach the desired temperature) even though it's not providing much cooling (because the fan speed is set low too).
