Peak oil, peak coal, green house gasses
Discussion in 'Environmental Discussion' started by austingreen, Jul 28, 2012.
  1. austingreen
    austingreen Senior Member
    13,671
    4,209
    Austin, TX, USA
    Its usually a combination of propane and butane. It typically comes from oil wells and is also called natural gas liquids.
    When we get natural gas at our homes it mainly methane. That's the stuff they are flaring in the mid west, and fracking for all over the country. Its illegal to flare natural gas in texas unless its for safety reasons. They need to get similar laws on the mid western oil fields.
    bwilson4web likes this.
  2. icarus
    icarus Senior Member
    4,884
    976
    earth
    liquified petroleum gas (l/P or propane) is NOT liquified natural gas. L\P comes from refining liquid oil.
    Liquefying Nat. Gas is another animal. What you do, in short, is liquify methane, by dropping it's temp to very cold, and then compressing it. In liquid form it is ~1/600th the volume of gaseous gas. It is expensive, and quite dangerous to do and transport.
    It is easy to confuse the two, since they add a similar odor to both, so they can be easily mistaken one for the other, but they are not cross usable. Propane appliances use different deliver pressures and orifices than do Nat gas, and fueling a device with a the wrong fuel is a recipe for disaster.
    Icarus
  3. hill
    8,794
    I throw up my hands at the thought of fracking coupled with flaring. Even as a kid in the late 1960's I recall the bright night sky in the So Cal basin caused by flarring - thinking, "that seems awful wasteful" . . . . . then along came its similarly wasteful cousin, "corn ethanol". Sheeeez. Tons of energy to pump water to the crop ... tons of energy to make petro fertilizer & petro pesticides for the crop ... tons of energy to grow the corn ... tons of energy to harvest & separate out the chaff ... tons of energy to ferment the alcohol etc etc. Never mind the CO2. Meanwhile 60% of the U.S. is in a drought, and much of the world starves. Yet we turn food into gas for the suburban, while some folks go hungry. The corn fuel lobby advertise that grain fuel gets better mpg's and saves energy .... they brag with badges on cars touting "flex fuel" and call it a good thing .... because for mileage counting purposed, we only count the gasoline part of the ratio of the flex fuel-alcohol blend, and not the food based alcohol part ... even though in reality this flex-fuel gets worse mpg's. boy-o-boy ... Reality: What a wacky world. The good news is we may finally be getting a handle on this nutty concept of green energy ... finally.
    http://www.nytimes.com/2012/07/31/opinion/corn-for-food-not-fuel.html?_r=1
  4. hill
    8,794
    oops - yet another double post
  5. tochatihu
    tochatihu Senior Member
    9,765
    3,765
    Kunming Yunnan China
    2001 Prius
    INATM's @40 last sentence was very 'deep', and I hope all take a moment to re read it.
    All youse others are being deep too, don't get me wrong. But over all these matters, one casts a long shadow. The global fossil energy market is hugely distorted by pref. tax and subsidy policies. The world's most profitable industry needs this?
    And people believe that?
    Market, bah. Wealth transfer to oligarchs.
    And we chat about which fuel is a bit better, or how much CO2 makes climate a little bit worse.
    Gettin played, boys N girls...gettin played.
  6. austingreen
    13,671
    4,209
    Austin, TX, USA
    flaring is typically burning the natural gas from an oil well. They have been fracking since the 40s, but it has nothing to do with the flaring. Its better than letting the gasses escape, and needs to be done sometimes for safety. Right now though they are doing it for speed. It takes time to build pipes to take the natural gas out of the wells, and many states don't have laws requiring it. Extremely wasteful, but helps with the profits this quarter, even while hurting them years from now.
    Agree with you 100% there.
    Now hold on a second with knocking flex fuel vehicles. We should have them, as they have the ability to change fuels over. Flex fuel should also include methanol, which it did before the corn lobby started working on it. Ethanol does not need to come from corn, and in bumper crop years there is no reason not to use some for ethanol. It is rather crazy to plant so much corn, and have food prices go up in tough years like this one, because it is being mandated for fuel not food.
  7. ProximalSuns
    ProximalSuns Senior Member
    1,877
    PNW
    It's three very big problems.
    1. $500B a year oil import trade deficit is a tax on US economy.
    2. $1.4T a year for the last 21 years fighting Middle East oil wars is a tax on US economy and 100% of current US debt.
    3. Global Warming. US is biggest polluter on a per capita basis and it is because we are 50% less energy efficient than more advanced economies, the economic and national security cost of imports.
  8. wjtracy
    wjtracy Senior Member
    11,366
    3,608
    Northern VA (NoVA)
    Correction...I had meant to say LNG way back, dang it
  9. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    Maine
    Mathematics does not allow that you can have a constant rate of consumption of a limited resource without consuming it all, unless that rate is zero. All the rest is sophistry.
  10. austingreen
    13,671
    4,209
    Austin, TX, USA
    Say you have a 300 yeaer supply at current rate, and you increasee consumption for 20 years to 20% more than you were doing, then you decline slowly to a rate of 80% for 40 years, then 60% for 20 years, then slowly wind down for the next 50 to 20% of what you were starting at. Do you some how use it all up quickly? Do you fall off a cliff? Or can you continue to produce for a very long time?
    Numbers do matter. What are your numbers that say we are going to fall off a cliff.
  11. Corwyn
    2,171
    659
    Maine
    Surely, you can do the math for your own invented numbers, for yourself. A careful reading of my posts will show that I don't ever say we are going to fall off a cliff.
    Do you have any examples of energy consumption EVER decreasing?
  12. austingreen
    13,671
    4,209
    Austin, TX, USA
    You did at the beginning of the discussion, I'm glad we are on the same page vis a vis the cliff. A limited resource can be used at a low level of consumption for a long time. I asked you to show your numbers, because you seem to be arguing that the world would need to go to zero oil use soon. The numbers for unconventional oil reserves are the important ones. I assume we are working off the same page on conventional reserves. It is not a bad theory to assume that oil will get so expensive or better substitutes - wind, sun, into better batteries - algea and switch grass into bio fuels that we drop consumption. Certainly it is possible to have a low level, say 10%-20% of what we use now, for hundreds of years before substitutes drop it to near nothing. I certainly was not saying that we can use a large percentage of the oil being used now for thousands of years. Was that your point?
    US oil consumption is decreasing right now. I expect that to continue. China and India will rise to a level then decline.
    The US economy can not afford to keep oil consumption at these levels, given estimates of what prices would do if we continue on this path.
    I don't think energy use will decline much in the US, but the sources are changing and continue to change. In North America today that means less oil and coal, more methane and wind. Since methane can be produced in sustainable ways in the future, this is a move to sustainability. Coal substitution is all about costs including environmental ones, and nothing about a scarce resource. Germany seems determined to drop energy use, and it will be interesting to see if they can do it.
  13. hill
    8,794
    Yea, flex fuel as in corn only ... that is my pet peav. If/when we ever have surplus corn again ... turn it into syrup ... sweetner .... dry it, can it, send it to homeless shelters (our neighbor used to get surpluss cheese that way) ... do anything to help humans . . . . but making it into a "hidden pea under the shell game" by claiming corn based fuel gives you higher mileage - that's what chafs my hide. I LOVE true flex fuels. Our backup gen/inverter is mod'ed to run gasoline/LP/natural gas . . . . bring that on.
  14. austingreen
    13,671
    4,209
    Austin, TX, USA
    I'm with you there. Given the land use questions, the fertilizers, water, pesticide, it doesn't do much. I don't think surplus cheese was more than a government milk subsidy scam. Let's not force corn into everything.
    No one controls the weather though, nothing wrong with taking surplus crops and doing the most good with them. I don't think corn syrup is the most good. In the founding of our republic people made whiskey, but the government no longer likes that idea, so fuel is as good as anything.
    Exactly. Lets make the fleet flexible enough to burn E25 or M25, then we can switch to the best fuel for the time. Estimates are it would cost less than $100/car. M25 is less expensive today. There is no reason to require ethanol on a bad corn year. M25, gets about 14% of its power from methanol. It reduces oil usage chiefly by substituting natural gas and biogas from garbage, without affecting crops.
  15. tochatihu
    9,765
    3,765
    2001 Prius
    US ag outlook:
    http://www.usda.gov/oce/commodity/wasde/latest.pdf
    Wheat OK; the other products slimmer. Corn->etoh? doesn't look like a good year for that.
    Has it escaped notice here that we are talking about this or that temperature history, while the US in is a whacking drought?
    I cannot even imagine how to run for president. The things that seem important to me are so different from the newsy things.
  16. austingreen
    13,671
    4,209
    Austin, TX, USA
    Its the worst corn crop since the late 80s and worst drought since the late 50s. That is interesting for a couple of reasons. The first is a good one, much worse weather but higher yields. That dovetails nicely into our peak discussion. In the '70s, I think that was the time, people were talking about peak corn and other malthusian positions that would cause catastrophic starvation. What happened to that peak? Technology in the green revolution. The other thing is a repeat of some very bad drought conditions, we have grown complacent as to the natural cycles. Yes these are changing, but the 50s were not a good climate time. The late 50s had the combination of horrible Chinese agriculture policy with bad weather to have a huge famine where an estimate of 15 millions starved to death.
    That should breed both some hope and fear. Bad government policy in the face of climate change can be catastrophic. It would be truly horrendous if to save us from the ghg, governments made people starve, so that we can farm for fuel. Brazil at least has a much better EROEI with their ethanol crop, and the government suspends food diversions in bad crop years. We can hope crops with better EROEI get used in the US in the future. These are fast growing woody plants like switch grass, and fast growing fatty crops like algae.
    We did have some foolishness that came up in the past. There was a plan to tax "windfall profits" at a high rate and use the money to pay for synthetic fuels from coal and for a solar bank. Now the stupidity of this plan had many problems. The easy one to consider today, is environmental, which was talked about even back then in 1980. When you convert coal to gasoline, you create even more ghg than even just burning it to make electricity, and that gasoline is quite expensive. I guess if you are running out fast, you say screw the environment, but this plan was to transfer tens of billions of dollars to the coal lobby from oil companies and consumers. Better would be to have flex fuel vehicles that could burn methanol which can be created from renewable sources as well as from natural gas or coal. Flex fuel vehicles allow easy liquid fuels to be burned. But, back then the fear was running out of natural gas too, so it was prohibited from being used in base load power plants. Somehow in the '90s the ethanol lobby got very strong, and methanol is not part of vehicle flex fuel systems, even though it is likely the least expensive liquid fuel today and may be in the future.
  17. Corwyn
    2,171
    659
    Maine
    Corwyn said:
    A careful reading of my posts will show that I don't ever say we are going to fall off a cliff.​
    You mean when I said, "You can have a plateau followed by a cliff if you really want."? I was describing one (extreme) possibility. I amazed that anyone could mistake that for a prediction.
  18. Corwyn
    2,171
    659
    Maine
    Do you have the figures for yields per gallon of fuel used to produce them? Yields per acre would seem to be a separate issue.
  19. austingreen
    13,671
    4,209
    Austin, TX, USA
    I was talking about food yields being higher after the green revolution. That is one reason droughts cause less starvation than they did in the past. Another reason is better, but still not good government policies. Peak food that was to have most of the world starving by now was grossly exagerated.
    If you read my posts, you will notice I am against government policies for a large contribution of corn for fuel. I take it from your question you agree with that opinion.
  20. Corwyn
    2,171
    659
    Maine
    My question is how are you measuring food yields? I am interested in food yield per gallon of fuel used to produce it.
