Is it a "V" or a "5" ?
Discussion in 'Gen 3 Prius Main Forum' started by Jon Hagen, Aug 1, 2012.
  1. Jon Hagen
    Jon Hagen Active Member
    336
    136
    North Dakota
    Was discussing Prius models with another Prius liftback owning relative.
    I called the new station wagon like model the "V" the other fellow said that it is not V, but Roman numeral 5.
    Now I read on this site that the Roman numeral designation was only used on the 2010 models.
    Someone correct me on this so I can call it by the correct name, is the wagon version of the Prius a "V" or a "5" ? TIA.
  2. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    The wagon version is a v (small v, pronounced vee, which apparently stands for versatile). The 2010 V is roman numeral 5.
  3. jsfabb
    jsfabb Active Member
    617
    156
    Medford, NY
    Viva la difference!
  4. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    In 2010, the Prius liftback had packages designated I, II, III, IV, and V (Roman Numerals).
    When the Prius v (vee) station wagon came out, the Prius Liftback packages were designated 1, 2, 3, 4, and 5.
  5. WE0H
    WE0H Senior Member
    3,247
    528
    They should'a called it the Prius W :)
    Mike
  6. bisco
    51,872
    dislike all of it. worst designations in the history of cars. it's hard to be old and confused, then they throw this foolishness at you.
  7. WE0H
    WE0H Senior Member
    3,247
    528
    Ahh, you can't be that old as your still here :)
    Mike
  8. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    Correct on the 1st point. For reference, for the OP, Toyota Vehicles : Toyota Announces Prices for 2010 Prius / Toyota uses the Roman numerals. Prius I, and Other News | PriusChat still used it, since it was still MY 2010.
    The changeover to the 1,2,3,4,5 or One, Two, Three, etc. actually happened before the Prius v wagon was announced. See MY11 Prius | PriusChat.
    At the time, we all thought nothing of it... It made more sense once the v wagon was announced later.
    Codyroo likes this.
  9. 50324prius
    50324prius Junior Member
    39
    iowa
    Prius 1-5 plus Prius v is just as confusing as the other manufacturers and their XTS, MKZ, CTS, STS, MKS...........
    Codyroo likes this.
