Water Pump only lasted 70k
Discussion in 'Gen 2 Prius Main Forum' started by kammssss, Aug 2, 2012.
  1. kammssss
    kammssss Member
    287
    86
    SoCal
    I can't believe my water pump only lasted 70k. My original one that came with the car lasted 145k. How long did your second one last? And I did use OEM parts. How do I know that my water pump is failing? I see the pink stuff.
  2. a_gray_prius
    2,927
    783
    IL
    I just had mine replaced at ~121k. We'll see how long it lasts.
  3. kammssss
    kammssss Member
    287
    86
    SoCal
    Just ordered a new one off ebay. Brand is AISIN (Oem supplier for Toyota/Lexus). This one is made in the USA. Let's hope it lasts longer than the Japanese version. Only $45 with free shipping. Stealership wanted $111...suckas. Will keep you posted...hopefully it can take me to the 300k mark.
  4. Patrick Wong
    18,200
    6,491
    At 130K miles, the shaft bearing on the original engine coolant pump on my 2004 is starting to seep so I bought the correct replacement pump in mid-July and will change the pump soon. It cost $69.26 plus shipping at toyotaworld.com
  5. AzWxGuy
    AzWxGuy Weather Guy
    1,023
    515
    Tucson, AZ
    2021 Prius
    I replaced mine myself just after I purchased my 2008 used in May 2011 with 67K on it. Saw the pink stuff and figured it was shot. Replaced with an AutoZone unit and was able to reuse the OEM gasket. Since then I've put on 40K plus and have seen slight seepage from the gasket (ends up on the inside of the bell pulley) a couple of times. Just a little spritz. The bearing must be far enough away from the weep hole to not be affected. Which makes me think I probably didn't need to replace the original.
  6. wjtracy
    wjtracy Senior Member
    11,358
    3,606
    Northern VA (NoVA)
    Well I am milking my original water pump.
    I had the pink salts leaking out...looked like this: :p
    And I was down on coolant, so I put more Toyota special coolant in and now its holding at ~110K miles
